#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
2004 V8 4.6L right time to timing chain/band change?
Reply
Thread Tools
Old 09-08-2011, 01:03 PM   #1
Col
Bogota, Colombia
Limited V8 2004
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hello guys, as you saw in the Subject I need to know if tje V8- 4.6L 2004 Explorer has a timing Chain or timing band?.. How many miles to have a preventive change?, if the band or chain breaks the engine will be rip off?....
Thanks for your help!!!!..
Col. AKA: JorgeA
Col is offline   Reply With Quote
( Join the Elite Explorers )
Old 09-08-2011, 01:07 PM   #2
Turdle
Move along people
nothing to see here
Turdle's Avatar
2000 Mounty
Vehicle Specs
Quoted: 654 Post(s)
Lot's of good info in here
http://www.explorerforum.com/forums/...g+chain+whoops
__________________
Jon
9 mile skid, on a ten mile ride. Hot as a pistol but cool inside.
2000 Mountaineer
1998 Mountaineer "Turdle"-gone
1993 Convertible "Vitamin D Wagon" Sold also
Turdle is offline   Reply With Quote
Old 09-10-2011, 05:17 AM   #3
Col
Bogota, Colombia
Limited V8 2004
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks Turdle, i saw it and the engine has chain so it is not like small cars with belt timing with high risk to break and damage the internal parts of the engine.
Col.
Old 09-10-2011, 07:48 AM   #4
n2epv
Pittsfield, MA
04 XLT 4.6, 01 Jetta VR6
Vehicle Specs
Quoted: 1 Post(s)
Just curious - is replacing the timing chains something a 'shade tree mechanic' could do? It looks like a 4.6 timing set (chains, sprockets and guides) plus gaskets is less than $300 in parts. I've done a few timing belt replacements - it's time-consuming, but always turned out OK - just took my time and made sure everything was positioned correctly before bolting the covers back on.
n2epv is offline   Reply With Quote
Old 09-11-2011, 10:06 AM   #5
jayton
Jefferson, GA
02 XLT V8
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Yes, it is something a shade tree can do. You have to remove a bunch of stuff that takes about 3 hours or so, depending on your pace. I wouldn't worry about the chains if I were you. I would just change out the guides, the tensioner, crank oil seal, and gaskets.
Harbor Freight has a real cheap and easy to use power steering pulley remover that helps.
You will also need two special tools to set the timing correctly. They are OTC 6020 and OTC 6009. When you take off the chain, the cams become spring loaded sheers just waiting for the perfect opportunity to take one of your fingers off clean. Experienced career technicians can come up with alternatives, but for a shade tree, don't mess around with this one without getting those two special tools.
__________________
jayton
2002 Explorer XLT, 2WD, 4.6L SOHC
1996 Mustang GT, Convertible, 4.6L SOHC (I have two of these)
1993 Grand Marquis
2001 BMW 325i Sedan
jayton is offline   Reply With Quote
Old 10-16-2011, 01:50 PM   #6
2002GreyHD150
DFW, Texas
2004 Mountaineer 4.6L AWD
Vehicle Specs
Quoted: 1 Post(s)
Jayton, OTC 6020 & 6009 are what tools exactly? by description? is one the engine holding fixture? and the other the rocker/lash adjuster removal tool?
its not a difficult jobm just time consuming and requires some dedication to accuracy, I am about to mine next weekend once all the parts arrive.
Rob
2002GreyHD150 is offline   Reply With Quote
Old 10-16-2011, 01:52 PM   #7
2002GreyHD150
DFW, Texas
Vehicle Specs
Quoted: 1 Post(s)
http://www.amazon.com/OTC-6020-Camsh.../dp/B000OCIW0E
foudn it...
Rob
Old 11-29-2011, 11:29 PM   #8
Intenseman
Denver, CO
2002 Explorer
Vehicle Specs
Quoted: 1 Post(s)
Tools
On the amazon link above it also mentions an otc 6024 (crankshaft positioning too). Is this another necessary tool?
Also, which timing set did you guys buy and from where?
Thanks in advance.
Michael
__________________
Michael
2002 Explorer
1995 Safari
1977 Scout
2001 Uzzi SL
Intenseman is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Transmission Cooler V8 4.6L 2004 Col Stock 2002 - 2005 Explorers 13 07-20-2012 09:07 AM
Newbie to Explorers/Ford, looking at used 2004 v8 SAABturbo Stock 2002 - 2005 Explorers 5 10-04-2010 06:05 PM
Performance radiator and electric fan suggestions for a 2003 4.6L V8 BAUER markmconnolly Modified 2002 - 2005 Explorers 12 07-24-2008 09:31 AM
2004 V8 4.6l lonboy Stock 2002 - 2005 Explorers 5 02-16-2008 03:06 PM
How do I adjust timing on V8 Explorer/Mountaineer? jjue Under the Hood 7 12-06-2000 12:18 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
