Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Ford Explorer Sport Trac Forums > 2001-2005 Explorer Sport Trac
Notices
2001-2005 Explorer Sport Trac All questions related to the 2001-2005 Explorer Sport Trac model.
Heater not working??
Reply
Thread Tools
Old 09-09-2011, 05:45 AM   #1
Goodman Racing
Hazleton, IN
2002 Explorer Sport Trac
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Unhappy Heater not working??
Hey everyone! I have a 2002 Sport Trac 4X4, 4.0L and cannot get the heater to work! With it being so hot here in Indiana until recently, I had not had to use it, but I can crank the dial all the way to full heat and it does not change temp at all in the cab??
I have checked to make sure the coolant is full, but that's about it. Was needing some advise on where to start...
Thanks!!
Goodman Racing is offline   Reply With Quote
( Join the Elite Explorers )
Old 09-16-2011, 06:12 AM   #2
Goodman Racing
Hazleton, IN
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I was really hoping that someone would have some basic info, etc on this issue?? Guess I'll just start at the switch, but am not sure how it operates the ventwork?? If ANYONE has any guess to where I should start, please let me know
Old 09-16-2011, 07:59 AM   #3
ncranchero
Co-moderator
Denver,NC
ncranchero's Avatar
'94 F150 4x4 SWB 4.9L
Vehicle Specs
Quoted: 28 Post(s)
I sent you the complete diagnosis from the 2002 manual. Post back with questions and/or findings. Check the knob to be sure it's actually turning the control and not slipping.
__________________
'14 Transit Connect 2.5L 16 Valve DOHC Duratec
'02 Escape XLT 3.0L 24 Valve DOHC Duratec 160k
'94 F150 4x4 4.9L/5-speed 160K miles,
How to post photos
ncranchero is offline   Reply With Quote
Old 11-02-2011, 07:44 AM   #4
beauj2000
Vehicle Specs
Quoted: 0 Post(s)
heater not working
Quote:
I have the same problem, don't know where to start. I can't find anything in the owners manual under the fuse section for a fuse that powers the actuator. I have an 07 sport trac. There is no clicking sound indicating a bad actuator, don't really want to pull the actuator just to find out its not getting power.
Help please
Jack
beauj2000 is offline   Reply With Quote
Old 11-30-2011, 12:30 PM   #5
Tracker Niven
Oshkosh, WI
2002 Sport Trac
Vehicle Specs
Quoted: 1 Post(s)
2002 Sport Trac - no heat
A few things first.... Does the fan work, but only blow cool air? do both heater core hoses feel different temperatures? Did you look behind your glove box and watch your blend air door on the right side move as you moved the heat control? If so, you may have a blocked heater core. Buy a flush solvent and in-line flush kit and flush it out. Run it a while with the solvent in it until you feel heat blowing again. Just did this this week in my 2002 Sport Track and it worked great. Utube has a video showing unblocking a heater core with a garden hose technique. I just figured, might as well flush the entire system while I was at it.
Tracker Niven is offline   Reply With Quote
Reply
Tags
heater problems
Similar Threads
Thread Thread Starter Forum Replies Last Post
05 Sport Trac A/C, heater, and the fan are not working. No climate controls working. Cgamm 2001-2005 Explorer Sport Trac 3 09-05-2009 10:09 PM
New Member.. Heater Question! Turbo306 Explorer, Ranger, A/C & Heater systems HVAC 7 08-08-2009 06:57 AM
2000 Explorer Limited Seat Heater not working bragl123 Stock 1995 - 2001 Explorers 3 02-09-2009 08:03 AM
Heater not working the best. Mneofreek Stock 1995 - 2001 Explorers 1 12-07-2005 04:55 PM
heater core? clutch fan? radiator? HEATER PROBLEMS FrankX570 Under the Hood 3 02-18-2004 05:57 AM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
