EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Power Distribution box keep blowing fuse???
Reply
Thread Tools
Old 09-10-2011, 11:17 AM   #1
TheDodgeWraith
Ft.Lauderdale FL
04 Exp
Vehicle Specs
(Original Poster)
Hey guys, I have a 1997 ford explorer 4.0sohc thats completly stock. The other day the fuse number 10 which is a 30amp in the power distribution box blew. I then tried to replace it but as soon as the new fuse went in, it blew. At the time, the window was down and the fuse that continues to blow, controls the windows,door locks, and dash lights. So just tryin to get the window up I used a 50amp fuse, which did nothing but get hot. I tried using a 20amp fuse and that blew too. I tried doing some research but found little. One thing I read said I have to check the circuit. Not really sure how to do that. Any suggestions????? Thanks
TheDodgeWraith is offline   Reply With Quote
Old 09-10-2011, 11:04 PM   #2
TheDodgeWraith
Ft.Lauderdale FL
04 Exp
Vehicle Specs
(Original Poster)
Nobody has a answer???
Old 09-10-2011, 11:19 PM   #3
tgreene92
south jersey
'98 XLT x2
Vehicle Specs
check for shorts in the wire or bad grounds, there is a ground wire that runs right off the box, check that first. then your gonna have to get a wiring diagram and find out which wires are the ones that run out the box to all the accessories, find them and check for obvious flaws such as tears in the wire and other miscellaneous grounds. If all that fails then you'll need a circuit tester. And BTW never put a bigger fuse in, the 30 amp is a 30 amp for a reason there's an obvious flaw in the system and that fuse is doing its job by blowing, putting a 50 amp in could cause you to burn up your window motors, locks etc...
__________________
98' XLT, 4.0 SOHC, war shackles 2 in TT, 31" destination AT's,cherry bomb vortex, Aussie locker, Custom snorkel. Basketball pole front bumper.
98 XLT, 4.0 being parted out, pm me for parts>>>. My ex-build thread-http://www.explorerforum.com/forums/...d.php?t=311851
tgreene92 is offline   Reply With Quote
Old 09-11-2011, 09:18 AM   #4
budwich
Ottawa, Ont
96 XL
Vehicle Specs
Although putting in a 50amp is NOT a good idea (as suggested), it does tend to indicate that your short is NOT a "casual type thing" like a little piece of wire or such lightly touching ground and would have melted or "smoked" itself. Its a HARD short, a bare power wire touching metal somewhere. You have to start unplugging things... start by unplugging the battery saver and accessory delay relay.... these will "break" some of the circuit paths eliminating some of the wiring. IF your fuse stays OK (hard way to test but that's another story), then you know your problem is in the wiring after those relays. IF it still blows, you know the problem is before. Most likely place for your problem is under the dash going toward the relay module in the IP (mid center).
budwich is offline   Reply With Quote
Old 09-11-2011, 12:03 PM   #5
TheDodgeWraith
Ft.Lauderdale FL
04 Exp
Vehicle Specs
(Original Poster)
Cool thanks guys, i will give it a shot and let you know of my findings. Thanks again for your help.
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Power distribution Box 95 Ford explorer 4.0 N2bnfunn Stock 1995 - 2001 Explorers 10 08-01-2012 11:08 PM
Ford Explorer PCM Power Procedure 2000StreetRod Under the Hood 1 08-12-2011 09:59 AM
How to get fuse box apart? briwayjones Stock 1995 - 2001 Explorers 0 11-12-2005 01:35 PM
Problems making connections with the fuse box Nozler Performance Lighting 3 12-06-2001 11:16 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
