Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Classifieds: Explorer / Ranger / Bronco II Parts For Sale and Wanted > Auto & Truck Parts For Sale > Parts and Vehicles Wanted
Notices
Parts and Vehicles Wanted Need a part for your Ford Explorer, Ranger? Looking for a special vehicle? Looking for a house, a dog, or an RV? This is the place to ask.
Front driveshaft
Reply
Thread Tools
Old 09-11-2011, 11:04 AM   #1
RockRanger
Elite Ranger
Fresno CA
RockRanger's Avatar
86 ranger no more
Vehicle Specs
Quoted: 132 Post(s)
(Original Poster)
Front driveshaft
I need just the pinion side of a front driveshaft for a TTB ranger or explorer.
How much shipped to 93727.
__________________
1993 Ranger build thread
RockRanger is offline   Reply With Quote
( Join the Elite Explorers )
Old 09-11-2011, 01:17 PM   #2
DB_1
Elite Ranger
La Quinta, Ca.
DB_1's Avatar
97 SC Ranger xlt
Vehicle Specs
Quoted: 72 Post(s)
So basically the short part of the d-shaft with the u-joint?
DB_1 is offline   Reply With Quote
Old 09-11-2011, 01:41 PM   #3
RockRanger
Elite Ranger
Fresno CA
RockRanger's Avatar
86 ranger no more
Vehicle Specs
Quoted: 132 Post(s)
(Original Poster)
Yes. The female section of the slip yoke and the the part where the ujoint gets pressed in. When I did the three link I needed to extend the front shaft a few inches. Instead of lengthening the driveshaft, I found a different slip yoke that would fit that was a bit longer. Now I redid my links a bit to get caster better and I need to get in back shorter. I cant find my original yoke currently.
__________________
Old 09-13-2011, 12:36 PM   #4
kbabiak
folsom,PA
91 to 04 Explorer
Vehicle Specs
Quoted: 2 Post(s)
Smile
hi i have one from a 92 explorer 20$+10$ shipping thanks,karl
kbabiak is offline   Reply With Quote
Old 09-13-2011, 01:19 PM   #5
Dannyboy
Other Make & Models Mod
4348′48″N 9113′59″W
Dannyboy's Avatar
91 4 do'
Vehicle Specs
Quoted: 6 Post(s)
didn't I sell you a drive shaft LOL?
Dannyboy is offline   Reply With Quote
Old 09-14-2011, 02:36 PM   #6
Maniak
Moderator-Stock 91-94
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Quoted: 213 Post(s)
What slip yoke did you use and will it fit a Dana 35 TTB pumpkin? And how much longer was it?
~Mark
__________________
Click HERE to see our Explorer Specs
Maniak is offline   Reply With Quote
Old 09-14-2011, 03:34 PM   #7
RockRanger
Elite Ranger
Fresno CA
RockRanger's Avatar
86 ranger no more
Vehicle Specs
Quoted: 132 Post(s)
(Original Poster)
Quote:
You sold me a rear driveshaft. I still need to modify it to make it a spare.
Quote:
~Mark
Yes it will fit the dana 35. I do not remember the part number. I went here
http://www2.dana.com/expertforms/demenu.aspx?prod=JOI
I found one that had the dimensions I needed and started calling driveshaft shops to see if they had what I needed. My driveline is no longer balanced but then again neither are my tires either.
And DB1 is sending me what I need so I no longer need it.
__________________
Old 09-20-2011, 12:12 AM   #8
jd4242
va beach
jd4242's Avatar
92explorer&94 ranger
Vehicle Specs
Quoted: 353 Post(s)
I've never heard of anyone having to extend a front drive shaft.how did it extend it?how much lift do you have?and what are you going to do with the old one?
__________________
92 xl 5.5"duff arms,3"BL,PJ 36x14.50,wrapped headers,side dump exhaust,.20 over,HF oil pump,422cam,45cc 95tm p+p 10.67:1 heads,p+p lower manifold,75mm TB,90mm maf,36lbs injectors,P+P GM M90 Supercharged & intercooled!!SCT tuned!!electric fan,4.88s aussie locked front & back!!next NOS&W/M
http://www.explorerforum.com/forums/...=double+vision
jd4242 is offline   Reply With Quote
Old 09-21-2011, 09:39 AM   #9
RockRanger
Elite Ranger
Fresno CA
RockRanger's Avatar
86 ranger no more
Vehicle Specs
Quoted: 132 Post(s)
(Original Poster)
I have extended the front a few different ways. When I first did the SAS I cut it in half and sleeved the shaft with a larger tube to make it a few inches longer. When I added the doubler I took it to a driveline shop and had it lengthen about 6 more inches. When I redid my front suspension I swapped the ends to make it a bit longer.
__________________
Old 09-21-2011, 09:40 AM   #10
jd4242
va beach
jd4242's Avatar
Vehicle Specs
Quoted: 353 Post(s)
O wow
__________________
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
2001 - 2003 Ford Explorer Sport Driveshaft FRONT 1ATony Explorerforum Vendors 0 10-27-2010 10:37 AM
4406 front driveshaft orientation and U-joint Trolling Explorer & Ranger Transmissions, Transfer Cases, & Differentials 7 08-12-2010 10:08 PM
Front Driveshaft jurick Modified 1995-2001 Explorers 15 11-13-2008 05:36 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
