Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Modified 1991-1994 Explorers
Notices
Modified 1991-1994 Explorers Questions concerning modifications to the 1991-1994 Explorer, Mountaineer, Ranger and Navajo. Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, lift kits, engine swap, transmission swap.
Looking to Lock...
Reply
Thread Tools
Old 09-23-2011, 07:34 PM   #1
redneckin
Cape Coral, Florida
1994 Mazda Navajo 4x4
Vehicle Specs
(Original Poster)
Looking to Lock...
ok, im not quite sure on this, so this is why i am asking. i searched up and down the forums for an answer to this question and i cannot find the answer which is why i am asking right now. what is the axles called (the actual gearing 8.8 and such) because im not really sure and im looking to buy some lockers for the front and rear and need to know what axles my '94 Navajo 4x4 has. any help is appreciated.
thanks,
Eric.
__________________
-Eric
redneckin is offline   Reply With Quote
Old 09-23-2011, 07:57 PM   #2
redneckin
Cape Coral, Florida
Vehicle Specs
(Original Poster)
also while im in the same topic, where do you guys get them prerunner style fiberglass fenders for the first gen's? would like to purchase those as well.
__________________
-Eric
Old 09-23-2011, 07:58 PM   #3
Maniak
Moderator-Stock 91-94
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
You have a Ford 8.8 rear axle and a Dana 35 TTB (Twin traction beam) reverse rotation front axle.
For the gear ratio, unless someone already changed the ring and pinion (the gears) you can look at the tag on the axle, or look at the door tag. Then search for Axle codes and you will be able to decipher them.
~Mark
__________________
Click HERE to see our Explorer Specs
Maniak is online now   Reply With Quote
Old 09-23-2011, 08:02 PM   #4
redneckin
Cape Coral, Florida
Vehicle Specs
(Original Poster)
my truck is bone stock aside from my cb radio and PA Speaker.
__________________
-Eric
Old 09-23-2011, 08:08 PM   #5
Maniak
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Then look at the door sticker for the axle code, or if thats gone, look for the tag on one of the bolts on the front or rear axle. The axle tags will have the code and even have the number listed..
Here is one of the places on here that you can find the axle codes..
http://www.explorerforum.com/ntrprize/Axle.htm
~Mark
__________________
Old 09-23-2011, 09:05 PM   #6
redneckin
Cape Coral, Florida
Vehicle Specs
(Original Poster)
how about the prerunner fenders? where can i get them?
__________________
-Eric
Old 09-23-2011, 09:22 PM   #7
RangerX
Moderator
Elite Ranger
Omao, Kauai
RangerX's Avatar
'93 Ranger XLT 4X4
Vehicle Specs
http://www.mcneilracinginc.com/off-r...orer-2-door-2/
__________________
Bill Collins
93 Ranger XLT 4X4
"Beauty is only sheet metal deep."
RangerX is online now   Reply With Quote
Old 09-29-2011, 06:46 PM   #8
jd4242
va beach
jd4242's Avatar
92 SC
Vehicle Specs
what ever you do dont buy from glassworks unlimited!!!
http://www.explorerforum.com/forums/...d.php?t=319979
and this is where i get my gears,i suggest Yukon and aussie lockers
http://www.accuautoparts.com/
http://www.aussielocker.com/
__________________
92 xl 5.5"duff arms,3"BL,PJ 36x14.50,wrapped headers,side dump exhaust,.20 over,HF oil pump,422cam,45cc 95tm p+p 10.67:1 heads,p+p lower manifold,75mm TB,90mm maf,36lbs injectors,P+P GM M90 Supercharged & intercooled!!SCT tuned!!electric fan,4.88s aussie locked front & back!!next NOS&W/M
http://www.explorerforum.com/forums/...=double+vision
jd4242 is online now   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
How To: Install an electric tailgate lock korey89 Ford Ranger - Mazda B-Series Forum 3 09-05-2011 12:16 PM
1996 Ignition Lock Cylinder replace surfcjw Stock 1995 - 2001 Explorers 0 06-22-2010 09:28 PM
Door lock Actuator problems fixed. junglejet Stock 1995 - 2001 Explorers 0 02-11-2008 11:40 AM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
