| Stock 2011 - 2014 Ford Explorer Discussion 2011 - 2013 Ford Explorer problem solving, maintenance, TSB, service bulletins, owner reviews, specifications, Ecoboost. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Monahans Texzas
2011 Ford Explorer
Where is fuse box?
Where is passenger fuse box? The manual said under and to the left of the steering column and by the brake-I cant find it. 2011 Ford Explorer
#2 |
2012 Explorer Limited
You and me both. I hear its a pain to find, but I spent 5 minutes looking all around the break and up under the steering column and couldn't find it. Might have to start removing trim pieces.
#3 |
2012 AWD Explorer Limited
This thread has a picture and description of location of fuse box:
http://www.explorerforum.com/forums/...e+box+location |
#4 |
Ok Found it on my 2012. There is NO way I can get to it. I'd have to remove the break peddle just to get my head in a position to see what I'm doing. It looks to be a mile behind a trim piece, do you have to remove this?
#5 |
2011 Ford Explorer
Fuse box
No trim pieces have to be removed for the 2011. Great prior thread. Put seat all the way back. Get a flash light and put your head in front of the break pedal. Shine your light up and towards the exterior of the car right above a couple electrical plugs. Very small panel. Pull the cover and grab the white pinchers off the inside of the lid. I found the hardest part is reinstalling the tiny fuse after you pull it. Good luck.
#6 |
This is what I see laying on my back.
![]() This is what I can barely see with my head on the break pedal all the way forward. ![]() If this is the same for the 2011 as it is MY2012 then I'm going to ask the dealer to do it because there is no way I can get a flashlight and my hand to see what I am doing up in there. I am hoping that the last piece of black trim in the first photo is new on the 2012s and that I'm not just missing some sort of acrobatics that I need to know how to do. |
#7 |
2011 Ford Explorer
We don't have that black trim piece on the 2011.
#8 |
South Florida
I wanted to get to the fuse box this weekend to install a radar detector, my 2012, has the trim piece pictured... there are two small bolts that hold it in place with a plastic push on, on the left side, if you remove the bolts and pull it gently off the plastic push on, you will have easier, but not easy access to the fuse box...
It's a poor design, what if you had to change a fuse and didn't have any tools to remove the bolts etc, plus it's in a terrible location... The drivers seat track will dig into your back, you should put a towel, or something soft over it to help with that...
#9 |
Toyota Highlander Convert
Ottawa, Ontario area
2011 Limited AWD
I think my dealer has a pet monkey that they've trained to work on the fuse box.
__________________ Peter Explorer Limited White Platinum Tri-Coat,340A (Rapid Spec 302A).Previous rides;'99 Windstar; '02,'06 & 09 4WD Toyota Highlander Limiteds |
#10 |
Rochester Hills, MI
'11 explorer XLT 202A
The fuse box location on the ex is one of the poorest I have seen.
My 2005 passat wagon has a removable plastic cover on the side of the dash panel were all the fuses/relays can easily be accessed. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Touch Screen - FUSE BOX. | nj2nh | 2011 - 2013 Ford Explorer In Vehicle Technology (IVT) Sync, MFT - MyFord Touch | 5 | 03-22-2012 01:26 PM |
| Have you ever heard of this? Fuse box | mrwhipper | Stock 1995 - 2001 Explorers | 2 | 09-04-2008 09:03 AM |
| explorer fuse box where is it? | mazzasec | Stock 2002 - 2005 Explorers | 3 | 01-02-2008 11:09 PM |
| Problems with DEFECTIVE PRO COMP Tires | Z71sc | Ford Explorer - Ranger Tires & Wheels | 11 | 08-23-2004 09:40 AM |
| Thread Tools | |
