| EF Swag Store | 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Amherst, MA
'03 Sport XLT
Issues about Emission and U-Joint
1. I failed state inspection due to emission test failure. The machanic couldn't tell what it is because I recently changed my battery. However, I have had check engine light on for a while and once a mechanic said their diagnosis system stuff indicated that it was about the fuel system. I have been having some problems about the rough idling(frequently) and stalling(just two times). I researched and found that it was a common symptom of bad fuel filter. But could it be the cause of failure of emission test?
2. After searching through the internet I think that the cause of noise from under the body was a u-joint problem that the car makes squealing noise at low speed and a deep low booming noise with vibration(not from the steering wheel) at high speed (above 60 mph), no sign of hard shifting with clunks from park to reverse or drive. I lifted up the rear only and tried to hear if there is any noise in drive and reverse. I couldn't hear any. With all four wheels on the ground, the rear DS didn't move at all while the front DS moves(rotational) about 1.5 inches that I could hear a slight clunking noise rotating the shaft by hands. Is it normal or possibly the front u-joint gone bad? Please help me. |
#2 | ||
Anchorage, Alaska
'97 Explorer XLT AWD 5.0L
Quote:
This is most likely the reason you failed. As for the mechanic saying something about the fuel system, it's possible that was a pending code and would not have caused a CEL. You need to get it scanned when the CEL is on to see what the codes are, which will help pin-point the issue you've been having. Quote:
It's also possible it could be the cv-joint at the t-case end of the front driveshaft. But a bad u-joint can cause a constant vibration. __________________ Daily Driver: 1997 V8 Explorer - K&N FIPK, Granatelli MAF, 3" Body Lift, WAR-153 Shackles, Torsion Twist, custom-built skidplate. 4.56s, Ion Alloy 133's, 33x12.5 Interco TrXus STS. 1986 Bronco2: RIP |
#3 | |
Toronto, ONT
'96 XLT , '00 Sport
Quote:
Just one thing I have to comment on, lose that mechanic. What mech gives a generic fuel system error and doesn't tell you what's wrong. When I failed the etest in canada we got a piece of paper with the NOX , CO and HC readings .. My fail was the NOX and changing the DPFE fixed that problem by over 1000 points. CO can be reduced with an additive and a plug change. HC I think is the CAT/ I don't know what system you guys have there but we can have a check engine and still pass. I was driving my 96 at the end of its life with a bunch of tranny codes and a half broken tranny and it still passed. __________________ '96 XLT 4DR <<< RETIRED '00 Sport 2DR Signature modified by Moderator Last edited by G-96XLT; 10-04-2011 at 12:11 AM. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| OBD-II Diagnostic Trouble Codes (DTCs) | BobWiersema | EEC V | 8 | 03-26-2013 10:22 PM |
| Cold Air Intake emission testing | Athlonman | Canadian Explorer Owners | 3 | 04-07-2007 11:27 AM |
| 92 no egr or codes fails NO emission | fredjr | Elite Explorer 911! | 7 | 10-27-2004 11:17 AM |
| Failed Emission Test (EGR) | Wordwoman | Under the Hood | 5 | 06-26-2004 01:38 PM |
| V8 swap Emission Testing: The FACTS from Arizona | asp84 | Offroad Explorer - Ranger Projects | 4 | 09-02-2002 12:17 AM |
| Thread Tools | |
