Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Cracked head or injector problem?
Reply
Thread Tools
Old 10-02-2011, 05:40 PM   #1
toomanyfords
Rockville,MD
98,93,and 91 explorers
Vehicle Specs
(Original Poster)
question for you guys, i've learned alot from this site but unfortunately I cannot find a complete answer for my question using the search function so any help is much appreciated. First let me tell you this is a 98 xlt 4.0 ohv. A couple months ago i started experiencing a cold start shake for about the first 15 seconds. Well thursday when I was leaving work the shake didnt stop and turned into a constant misfire and "bucking" while trying to drive home. Friday I pulled plugs and found cylinder 3 plug to be black and fouled up. compression test shows 111 on that cylinder, around 130 for the other five. leak down test showed 9% leak down on cylinder 3, air leaking through throttle body. other cylinders were less than 5% leaking through crankcase (normal in my eyes for 154,000 miles). I have been slowly losing coolant over the past few months but didn't think much of it. I do have spark and have tried swapping wires etc. No codes and for some reason my scanner is showing -100% fuel trim so it seems I can't check that. So I wanted a second opinion on this, either my head is cracked and leaking down through the intake valve, or I have an injector problem and excess carbon causing the valve to not seat. Sorry for the long post but wanted to provide details. any help is much appreciated, thanks again
__________________
98 xlt ohv tt&shackles/aal on 31's flowmaster delta 40, 93 xlt ohv 5 speed stock ,
91 sport lift springs&aal on 31's cragar soft 8's, built engine with comp cam, smith bros pushrods, delta cam rocker arms, comp springs, headers, flowmaster delta 40
toomanyfords is offline   Reply With Quote
Old 10-02-2011, 06:56 PM   #2
toomanyfords
Rockville,MD
Vehicle Specs
(Original Poster)
just wanted to also say I performed a combustion leak test through the radiator and the head gasket seems to be ok. Vacuum is also a steady 17 in. at idle regardless whether its missin or not. thanks in advance for any replies
__________________
Old 10-03-2011, 07:19 PM   #3
toomanyfords
Rockville,MD
Vehicle Specs
(Original Poster)
well in the event that someone is reading this thread i figured I'd post an update. just replaced the fuel injectors and re-torqued lower intake. I had the injectors sitting around, and decided why not. Well it stills runs like crap and still misses, exhaust is smoking and smells like unburned fuel. I'm about ready to take the shotgun approach and put heads on it. I have fuel, spark, and decent enough compression on all cylinders to where it shouldn't be misfiring, only thing I've found that is odd is leakdown through the throttle body on cylinder and 3 and semi-low compression, but doesn't seem like enough to create a misfire. If anybody has had any similar experiences or has any advice at all please let me know. thanks in advanced
__________________
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Cracked Head 5.0 (pics) spacecadebt Stock 1995 - 2001 Explorers 9 08-08-2011 10:04 PM
head unit and sub output tgreene92 Explorer Audio & Navigation 0 01-10-2010 07:53 PM
Something is broken Cracked Head or Cracked Block bzack Under the Hood 3 02-27-2008 10:40 AM
HELP.. replaced stock head unit then every thing went hay wire kkp402 Explorer Audio & Navigation 11 12-20-2007 07:27 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
