Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Where is the Crankshaft Sensor located at?
Reply
Thread Tools
Old 10-10-2011, 12:00 PM   #1
N2bnfunn
1995 Explorer
Vehicle Specs
(Original Poster)
Thumbs down Where is the Crankshaft Sensor located at?
Hello so where is the Crankshaft Sensor located at on a 95 Explorer 4WD 4.0L EFI
N2bnfunn is offline   Reply With Quote
Old 10-10-2011, 02:42 PM   #2
BIGTREAD
COLUMBIA MD
2000 XLS
Vehicle Specs
That thing is located at the back of the engine jambed close to the firewall. Oops, was thinking of the CAMSHAFT sensor! Sry.
BIGTREAD is offline   Reply With Quote
Old 10-10-2011, 02:54 PM   #3
2000StreetRod
Greenville, SC
2000StreetRod's Avatar
2000 Sport SOHC 2WD
Vehicle Specs
CKP location
The crankshaft position (CKP) sensor is mounted on the engine front timing cover. It senses the teeth on the trigger wheel attached to the harmonic dampener. Because of being located near the bottom of the engine compartment it is exposed to road grime and water, etc. and the electrical contacts may get corroded. Disconnecting and reconnecting the electrical connector several times cleans the contacts.
__________________
My Helpful Threads, Registry, 16.4/23 mpg, 3900 lbs, 5R55E, 3.73:1, 175 rwhp, Henson custom tune, CAI, Spectre air filter, Lightning 90mm MAF, 75mm throttle body, A/F ratio meter, synthetic oils, Accusump, 2 row radiator, 3+1 leaf springs, .75 inch drop, Edelbrock IAS lowering shocks, engine oil & ATF temp gauge & remote filters & coolers, remote crank
2000StreetRod is online now   Reply With Quote
Old 10-10-2011, 03:43 PM   #4
N2bnfunn
1995 Explorer
Vehicle Specs
(Original Poster)
Quote:
Ok I think I know where you are talking about if I get under the truck and where the belt goes around the crankshaft puller it is plug beside it? Is that where it is at?
Old 10-10-2011, 04:26 PM   #5
2000StreetRod
Greenville, SC
2000 Sport SOHC 2WD
Vehicle Specs
correct
Quote:
Correct
__________________
Old 10-10-2011, 04:31 PM   #6
N2bnfunn
1995 Explorer
Vehicle Specs
(Original Poster)
Correct
Ok I thought that was it, I just can't get the wire plug off, with out breaking it? What is the best way to unplug it with out breaking the plug?
Old 02-20-2012, 01:20 PM   #7
Youngcheezy
Manawa, WI
97 E.B. Exp 5.0L AWD
Vehicle Specs
I just replaced my crankshaft position sensor on my 97 Explorer 5.0. The sensor is right in the front by the water pump and the fan. The best way, well what I found out the hard way, to replace is to take of the belt. It gets in the way a little bit. The bolts are 8mm (I found that 5/16 fits more snuggly and that is what i used in the end.
The problem i ran into is my 8mm socket was cracked and i didn't know this until i was trying to get that dang bottom bolt out and ended up stripping it! Don't strip it (obviously) it is a pain in the arse!! by far the worst!
so easiest way, remove the 2 bolts (top and bottom) easiest way you can; crawling under, laying on the engine, ect.. then just unplug it. it came right out for me, well after the back-breaker of removing my stripped bolt.
then plug the new one in. My explorer started right up after that!, well i had to reset via taking off the battery terminals and waiting 10 seconds
PS i also, while turning the key over, i didn't initially "start" the vehicle, i waited until i hear the fuel pump actually pump fuel, then turned off. I repeated that 3 times so i had plenty of fuel in there then she cranked right over..
I should say that my initial problem and why i had to replace the sensor is because one morning she just decided not to start... go figure it happened to be the day i needed her the most haha!! i narrowed it down to the crankshaft position sensor then replaced.
Youngcheezy is offline   Reply With Quote
Old 02-20-2012, 01:22 PM   #8
Youngcheezy
Manawa, WI
Vehicle Specs
remove the bolts, then unplug her.. pretty straight forward. nothing should break, well at least nothing broke on me.
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
MOAB EXPLORER EXTRAVAGANZA 2001 HIX Offroad 4x4 Runs Planning and Discussion 595 05-22-2001 12:16 AM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
