Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
Transfer case interchangability question
Reply
Thread Tools
Old 10-10-2011, 06:47 PM   #1
electronicsguy
Bowling Green, MO
95 Explorer XLT 4.0 4wd
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I have a 95 explorer XLT 4.0 electronic 4wd and my transfer case is doing that thing to where it makes a horrible spinning sound when i let off the gas at over 30mph and sometimes i have to put it in 4 low to get reverse to engage without making that noise. A friend offered to sell me a low mileage known good transfer case for $50, he has 2 to choose from, one is a 4405-12 and the other is a 4405-09. Mine is a 4405-07. One of his is out of a 97 and the other is out of a 2000, is there anyone that knows if these will interchange? He has matching driveshafts, wiring etc. for his in case I would need some of that stuff to make it work.
Thanks,
Mike
electronicsguy is offline   Reply With Quote
( Join the Elite Explorers )
Old 10-10-2011, 06:51 PM   #2
drdoom
VA
2005 Eddie Bauer 4.6L 4X4
Vehicle Specs
Quoted: 350 Post(s)
Is your '95 a Control Trac? Also, check the output flanges, to see if they match. I have a 4405-9 and it has the six-bolt cup flange on the front, and speedometer gear at the rear output. I think that is the only stuff you have to match.
drdoom is offline   Reply With Quote
Old 10-10-2011, 07:05 PM   #3
electronicsguy
Bowling Green, MO
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
i think its a control trac, it has the automatic 4wd. i havent had my tcase out yet cause my explorer is all i have to drive so im tryin to find out before i get the other tcase cause i have to drive 2 hrs to pick it up
thx
mike
Old 10-10-2011, 07:29 PM   #4
ziggyofthenorth
PA just outside of the Burgh
88 Bronco II/96 5.0
Vehicle Specs
Quoted: 0 Post(s)
If the 4.0 is like the 5.0, the 2000 will not work. 95 thru 97 the speedo hooked up to the t-case. 99 up to 2001 the t-case has no place to attach the speedo cable. 98 I'm not sure about, but it is easy to see if the case is machined to accept a speedo cable. I have been told the newer ones sense the speed off of the ABS system, but mine is a 96 so I never looked into it past what fits mine.
ziggyofthenorth is offline   Reply With Quote
Old 10-10-2011, 10:21 PM   #5
IZwack
Moderator Emeritus
Germantown, MD
IZwack's Avatar
1998 Ford Explorer
Vehicle Specs
Quoted: 2 Post(s)
So are you 100% certain that the problem is indeed the transfer case?
__________________
...how'd the moon get there, how'd the moon get there?
IZwack is offline   Reply With Quote
Old 10-11-2011, 08:54 PM   #6
electronicsguy
Bowling Green, MO
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
My mechanic seems sure, it did it right after i took it out of 4 low and forgot to put it in neutral first. I tried like hell to properly disengage 4wd after that in case it was partially stuck with no luck. I had only had the explorer 2 days when this happened. He said the tcase had been leaking fluid from the front and was low on fluid, hard telling for how long. I had read somewhere that some of the 95 explorers had a different front connection, some were cv and others were something different that I cant remember, I can get the front driveshaft to go along with whichever tcase I get from my friend if that will make it work, but I dont know. I hate to pull the tcase out and get someone to take me 2 hours away to see if it will work then put the bad one back on if it wont so i have something to drive til i get one. I tried finding a way to access the hollander interchange guide online but it said I have to subscribe to it
Old 10-11-2011, 09:14 PM   #7
drdoom
VA
Vehicle Specs
Quoted: 350 Post(s)
You could just get the 4405-09 and use the output shaft out of your 4405-07 (if it is good). It would be a good opportunity to inspect & overhaul the transfer case, you know a seal kit and a shift fork upgrade. You would probably want to check the speedo gear as well, in case the 4405-09 build uses a different color gear. Heck, for $50.00 you could just use those cases for parts, and fix the one you have.
Old 10-11-2011, 10:08 PM   #8
gmanpaint
Torsion Bar Free
since 2010
gmanpaint's Avatar
94 XLT-95 FX4
Vehicle Specs
Quoted: 302 Post(s)
You can use a 4405 t-case from 95-96-97. But that's it.
95-96 uses a 4405-CA, 97 uses a 4405-GA. The only difference between these are the front output for the drive shaft. If you use a 4405-GA, you must use the front shaft that came with it. These cases have the VSS in them, 98+ do not, and those years use the ABS sensor in the rear diff case for the speedometer.
The other option you have is to use a manual 1354 TC (with a VSS) for a direct bolt in, and is actually a strong upgrade as it is a gear driven case, not a clutch driven, like the 4405 is.
__________________
The Black Hole
Pugly
gmanpaint is offline   Reply With Quote
Old 10-11-2011, 10:46 PM   #9
electronicsguy
Bowling Green, MO
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
awesome! thx so much for the help, ill buy the one from the 97 and get the front driveshaft with it
Old 02-16-2012, 11:59 AM   #10
Steeda04SVT
Kansas City, MO
1997 Eddie Bauer Explorer
Vehicle Specs
Quoted: 34 Post(s)
To piggy back off of this, my tcase is making noises and will a tcase from a fellow 97 5.0 work? Wasn't sure if the tcase was the same between the 4.0 and 5.0? Thanks for any input.
__________________
Former USAF AC-130H Spectre Gunship Crew Chief ('02-'12)
BNSF Railway
2004 Terminator Cobra - Sold
1997 XLT Explorer 5.0 - Project Car
2005 Acura TL - Daily Driver
Steeda04SVT is offline   Reply With Quote
Old 02-16-2012, 12:01 PM   #11
IZwack
Moderator Emeritus
Germantown, MD
IZwack's Avatar
1998 Ford Explorer
Vehicle Specs
Quoted: 2 Post(s)
The transmissions behind the 4.0L and 5.0L engines are different (different tailshaft housing patterns) so that a transfer case from a 4.0L will not bolt up to the 5.0L, and visa versa.
__________________
Old 02-16-2012, 12:49 PM   #12
Steeda04SVT
Kansas City, MO
Vehicle Specs
Quoted: 34 Post(s)
Quote:
But it's the same for the 4.0 SOHC and 4.0 OHV?
__________________
BNSF Railway
Old 02-16-2012, 12:59 PM   #13
IZwack
Moderator Emeritus
Germantown, MD
IZwack's Avatar
1998 Ford Explorer
Vehicle Specs
Quoted: 2 Post(s)
Quote:
Yes - however there are differences between generations (91-94 vs 95-01) and also a few differences within the 2nd gen models. GIJOECAM explains the differences in this thread: http://www.explorerforum.com/forums/...d.php?t=203441
__________________
Old 02-16-2012, 03:26 PM   #14
Steeda04SVT
Kansas City, MO
Vehicle Specs
Quoted: 34 Post(s)
Sweet, thanks for the link.
__________________
BNSF Railway
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
01 x, 4wd wont engage offrdsnwbrd4 Modified 1995-2001 Explorers 11 12-08-2015 12:22 PM
1999 XLT transfer case question rarx Stock 1995 - 2001 Explorers 2 12-20-2014 07:35 PM
Transfer case Question TIMBELL99 Explorer & Ranger Transmissions, Transfer Cases, & Differentials 2 06-30-2009 08:45 AM
transfer case question please help me anybody kgb424 Modified 1991-1994 Explorers 6 10-01-2008 12:46 AM
Transfer case swap question adarkang Explorer & Ranger Transmissions, Transfer Cases, & Differentials 3 03-14-2006 05:15 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
