#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
2002 explorer rear diff fluid change
Reply
Thread Tools
Old 10-15-2011, 02:04 AM   #1
ivrb
southern cal
2000 xls
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Any one have an idea the steps to change diff fluid from the rear diff, its independent suspension
ivrb is offline   Reply With Quote
( Join the Elite Explorers )
Old 10-15-2011, 08:20 AM   #2
my1zamboni
Maine
2002 Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
http://www.explorerforum.com/forums/...ar+diff+change
my1zamboni is offline   Reply With Quote
Old 10-15-2011, 10:39 AM   #3
esclamada
KCMO
'02 Mountaineer AWD V8
Vehicle Specs
Quoted: 28 Post(s)
http://www.facebook.com/media/set/?s...2348605&type=3
this pump actually makes the filling much easier since you don't have to be under the truck. It's available in Walmart and any Auto parts store. Way cheaper in Harbor Freight ($4-$6 depending on the coupon)
http://www.facebook.com/photo.php?fb...type=3&theater
MY MOUNTY
http://www.facebook.com/diyfordexplorer
esclamada is offline   Reply With Quote
Old 10-15-2011, 12:33 PM   #4
Exproblems
Orchard Park, N.Y.
'05 Explorer XLT 4.0L
Vehicle Specs
Quoted: 67 Post(s)
Quote:
Besides the info you got from other people in here on this rear diif fluid change job, you will need to find out if your rear diff is a "Limited Slip" differential. If you DO HAVE a Limited Slip Diff, you will need to add 4 ounces of Friction Modifier along with the new gear oil. Rear Diff holds approx 1.60 to 1.75 quarts of oil, so 2 quarts of new gear oil will do the job, Mobil 1 75W-140 Full Synthetic or equivalent brand. Friction Modifier comes in a squeeze tube and costs about $6-$7 in a parts store or buy Fords own brand from a Ford dealership. Ford recommends this additive BTW for Limited Slip diff's.
Exproblems is offline   Reply With Quote
Old 10-16-2011, 10:29 AM   #5
Thomas Mackin
Eagle River,Wi
2002 XLT
Vehicle Specs
Quoted: 1 Post(s)
Ford also recommends changing what they called for to the heavier oil. I have had great luck with Amsoil 75-140 which is thetype Ford now recommends. Also I used the Amsoil friction modifier because I have the limited slip. If you do the front one use the 75-90 and no modifier but you will have to use your pump to suck out the old through the fill port because ther is no drain. A good idea if you have high mileage and use the 4x4. Do not forget to put a sealer on the threads of the plugs.
Thomas Mackin is offline   Reply With Quote
Old 10-17-2011, 09:20 AM   #6
RickM
'02 Explorer 4.6 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
I don't have limited slip but I do suffer from the all-to-common rear end whine. I filled with one bottle of Ford's heavier diff oil and a bottle of Lucas oil treatment. The whine is about at 1/3 the level it was before. Better than I expected.
Lucas states that one could use their "additive" exclusively in a diff. Not sure if this would result in better performance or a quieter ride.
Also, the stuff is a real bear to pump due to its honey-like viscosity.
__________________
'02 XLT 4.6 4x4
'85 Carrera Flatnose
'71 280SL Pagoda
RickM is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Rear Diff Fluid Change AgExplorer 2001-2005 Explorer Sport Trac 7 05-03-2011 11:59 AM
Day off tomorrow. Few projects for my new 2002 Ford Explorer XLT. Anything else? kdoggy Stock 2002 - 2005 Explorers 10 03-03-2011 12:22 AM
98 xlt 4wd 4.0 sohc rear diff fluid change jm Explorer & Ranger Transmissions, Transfer Cases, & Differentials 4 06-02-2006 03:55 PM
2002 Rear Diff Fluid? newtek007 Under the Hood 4 03-15-2005 10:30 AM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
