Broken radiator drain plug | Ford Explorer Forums - Serious Explorations
Joseph Tilghman
Huntersville, NC
2003 sport trac 2w Drive
For those of us that get heavy handed and break off the drain plug, the old one can be removed with a 5/16 allen wrench. I just picked one up from the dealer. I wasn't sure about an after market piece 8.97 at the dealer.
I'm surprised they had one. Must be a common breakage issue then. Sure beats a radiator replacement!
Surprised me too when I called the dealer. It must be a high brakage item, I watched him get the part he didn't have to go back in the corner it was right up front. lol
I had mine break a while back, got it out with an allen wrench, but I got my replacementfrom autozone for like 3 bucks, and its got a thumbscrew on it (looks kinda like a wing nut) unlike the old one.
I changed mine this weekend used a 5/16 allen socket maybe should have goten an aftermarket piece but didn't know if the thread size was the same.
Service manual says just pull it out.
I tried pulling it out and it wont come all the way out. I bought a new drain plug because my old one is leaking. Is there a special tool to use? Thanks!
I broke the factory plug on my 03 STR I backed it out with a 5/16 allen socket (allen wrench will work) and just pulled it out after the threads were completely out of the radiator.
Try squezing the tang that goes into the radiator.
I broke my 04 ford explorer drain plug. Is it 5/16? because the entire top portion of the plug came out. and the rest is stuck inside the drain plug. I'm just glad i was screwing it in when it broke, so no coolant is leaking.
