Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Heater not working/making clicking sound when heat is on
Reply
Thread Tools
Old 10-19-2011, 06:45 PM   #1
DirtySanchito
San Diego, California
'04 Ford Explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hey guys, I know my truck has a lot of problems, but thanks for sticking with me and giving me great advice! now, that being said, I have a big problem with the heater. I got the t-stat fixed, and now that i finally need to use my heat because i'm in illinois and its extremely cold right now, i noticed that it is not working! when i turn the dial to heat, it makes a weird clicking noise and wont turn hot, and the defroster doesn't seem to heat up either. now, i talked to a family friend who happens to be a mechanic and he had said that a gear that switches the cold to heat is stripped out and that is what is causing the clicking noise. But i figured that i would get on here and ask advice from the people who always seem to have great advice about everything imaginable! So, anyone know if this is the true problem? And if it is not, does anyone know what the true problem is? And how an inexperienced DIY can do it himself? And a second question, the vents for the second row of seating (located on the center console above the cup holders) doesn't blow out any air at all. so i was wondering if anyone knew how to fix that as well.. i appreciate any help that can be given! thanks guys!
DirtySanchito is offline   Reply With Quote
( Join the Elite Explorers )
Old 10-19-2011, 08:00 PM   #2
lcars
Mid-Michigan
'02 XLT
Vehicle Specs
Quoted: 0 Post(s)
No heat and clicking
"i talked to a family friend who happens to be a mechanic and he had said that a gear that switches the cold to heat is stripped out and that is what is causing the clicking noise. But i figured that i would get on here and ask advice from the people who always seem to have great advice about everything imaginable! So, anyone know if this is the true problem?"
He is correct mine did the same thing, you will need to follow this procedure by BigRondo and remove the air blend actuator - I didn't cut the panel (there are pictures on Page 8 that shows the teeth sheared off of the gear that is turned by the worm gear (brass gear) motor:
http://www.explorerforum.com/forums/...highlight=heat
Once removed, look at the code similar to this code (my code on my '02 Explorer) 2L2Z-19E616-CB (no longer produced). Go to:
http://www.dormanproducts.com/gsearc...&type=parttype
If you have manual controls, compare the picture and ensure the stems and connector match. I bought mine for $49.99 at O'Reilly as they priced matched Autozone. Unless you want the Ford part for about double the price.
lcars is offline   Reply With Quote
Old 10-20-2011, 05:39 PM   #3
Exproblems
Orchard Park, N.Y.
'05 Explorer XLT 4.0L
Vehicle Specs
Quoted: 85 Post(s)
Quote:
Sounds like you have a bad "blend door actuator". A cheaply made, small plastic gear inside of this actuator breaks off a few teeth and stops rotating the blend door when you switch from cold to hot temp settings. Do you hear a thumping or clunking noise coming from behind the dashboard when you switch from cold to hot with the defroster on? If you do, it's the actuator. Below is a link to a great post and photo's by "BigRondo" on how to replace the blend door actuator. The part/ blend door actuator cost around $80- $90 at a Ford dealership. BTW, this actuator tends to fail while set to the cold side temp setting, thats why you don't notice it till you switch over to the hot side for heat. Also, I recommend you buy a Ford actuator, not many good reports on the aftermarket ones, and use your VIN number when purchasing it from a Ford dealership. Your VIN ensures you get the right part for your vehicle.
http://www.explorerforum.com/forums/...d.php?t=294140
Try this link below for the blower vent problem you have.
http://www.explorerforum.com/forums/...d.php?t=284042
Exproblems is offline   Reply With Quote
Old 10-21-2011, 08:32 PM   #4
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
I concur with Exproblems!
__________________
Rondo - USMC, Combat Engineer, 1983-1996
Click here for a list of my write-ups!
Quote:
Originally Posted by FIND on 4-22-13
Don't mess with Boston. They will drop everything, hunt you down, and then go on like you never existed once they are done cleaning up the mess.
BigRondo is offline   Reply With Quote
Reply
Tags
air vents, heater problems
Similar Threads
Thread Thread Starter Forum Replies Last Post
Rear AC / Heat making clicking sound tominjax Stock 2002 - 2005 Explorers 4 05-11-2015 10:33 AM
No Heat and no flow to the heater core MtrJunkie Explorer, Ranger, A/C & Heater systems HVAC 3 02-25-2012 04:34 PM
Heater Problems/ Heat clicks loud when cool air is mixed yaneev Stock 2002 - 2005 Explorers 12 03-27-2011 02:57 PM
Clicking sound coming from the rear. kbucci Stock 2002 - 2005 Explorers 10 06-09-2006 09:23 AM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
