Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
PO471 Code?
Reply
Thread Tools
Old 10-25-2011, 09:57 AM   #1
Texaswildman
KY
2000 Merc Mounty 5.0
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
PO471 Code?
Hey guys, love these forums. I have a 2000 Mountaineer that I just picked up and it has some issues that I am working on.
Had a code of PO471, symptoms are sluggish acceleration. Idles fine, runs fine, achieves speed fine if given steady slow acceleration. But at WOT it almost is sluggish.
Any help is appreciated.
Guy at Advance Auto said it's the Cat.
Texaswildman is offline   Reply With Quote
( Join the Elite Explorers )
Old 10-25-2011, 10:05 AM   #2
drdoom
VA
2005 Eddie Bauer 4.6L 4X4
Vehicle Specs
Quoted: 343 Post(s)
Wildman, can you get someone to check your cats with an infrared tester? That is a simple way to see if they are working correctly. From your symptoms, maybe the cats are clogged???
drdoom is offline   Reply With Quote
Old 10-25-2011, 02:14 PM   #3
Texaswildman
KY
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
Thanks Doc. I think I can. Can this also be accomplished with a thermal laser type thermometer (I have one of those) and just look for excessive heat in the cat? If I recall the code was something like Excessive Pressure in Exhaust or EGR?
Also, how many cats are on this thing? I've never seen an exhaust with so many cat/resonator looking things. lol I am guessing the cat (if it is a single cat) is directly after the 02 sensor?
Old 10-25-2011, 08:40 PM   #4
swetrid
Reading Pa
1999 Eddie Bauer
Vehicle Specs
Quoted: 4 Post(s)
P0471 doesn't exist? Sure its not p0174?
__________________
Resident Ford Tech for the last 17 years, 1999 Eddie Bauer Explorer, 1987 Mustang GT, 2013 Focus ST
swetrid is offline   Reply With Quote
Old 10-26-2011, 07:26 AM   #5
Texaswildman
KY
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
I'm pretty sure that is what it said. I've worked on a ton of vehicles and have seen most codes and this one threw me too. Researching on the net the code is most common with diesels, which the below may be referring to.
Now I'm wondering now if the DPFE could be the issue and could it make it actually run that bad?
EDIT EDIT: This is for a diesel. Now I'm really confused...lol
Here is a link about that code: http://engine-codes.com/p0471_ford.html
Copy/paste:
P0471 FORD - Exhaust Pressure Sensor Range/Performance
Symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
Possible causes
- Exhaust Back Pressure Sensor
Possible solution
Replacing the exhaust back pressure usually takes care of the problem
When is the code detected?
An EBP signal that is detected out of range (high or low) by the PCM will cause the engine to ignore the EBP signal and disable exhaust back pressure operation.
P0471 FORD Description
The exhaust back pressure (EBP) sensor is a variable capacitance sensor that, when supplied with a 5-volt reference signal from the Powertrain Control Module (PCM), produces a linear analog voltage signal that indicates pressure.
The EBP sensor's primary function is to measure exhaust back pressure so that the PCM can control the exhaust back pressure regulator (EPR) when needed.
Last edited by Texaswildman; 10-26-2011 at 07:29 AM. Reason: Code seems to be for a diesel.
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
P0304 error code on a 98 Ford Explorer 4.0L OHV. karen27 EEC V 5 02-08-2011 08:13 AM
I thought I might share my 214 code story & solution camsdad Stock 1995 - 2001 Explorers 2 10-21-2009 07:25 PM
Code 53 not clearing from EEC-IV X-North Explorer, Ranger - Computers, Chips, Tuning 0 02-08-2008 06:41 AM
engine codes with code reader LS431o28 Under the Hood 2 12-20-2001 12:04 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
