Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2011 - 2014 Ford Explorer 5th Generation Explorer > Stock 2011 - 2014 Ford Explorer Discussion
Notices
Stock 2011 - 2014 Ford Explorer Discussion 2011 - 2013 Ford Explorer problem solving, maintenance, TSB, service bulletins, owner reviews, specifications, Ecoboost.
Will 2010 Explorer 17" wheels fit the 2011 Explorer?
Reply
Thread Tools
Old 10-26-2011, 08:39 PM   #1
nextreme
Ottawa, ON
2011 XLT
Vehicle Specs
(Original Poster)
Hey,
I'm looking at buying a winter/wheel package from someone that was from a 2010 Ford Explorer. The tires are 245/65/17 and the bolt pattern is 5 x 114.3.
Does anyone know if the hub and offset will fit?
Thanks
__________________
nextreme is offline   Reply With Quote
Old 10-27-2011, 08:21 AM   #2
MikeFreas
VA Beach VA
2012
Vehicle Specs
Not sure if the hub pattern is the same but you need to make sure the overall diameter of the wheel/tire combo is the same as it may screw up the computer if it's off.
MikeFreas is offline   Reply With Quote
Old 10-27-2011, 08:28 AM   #3
tucker_bmd
2012 XLT AWD
Vehicle Specs
Quote:
Originally Posted by nextreme View Post
Hey,
Thanks
Offset should be fine, what's a few millimeters between friends. It's the center bore that is different. I'm 99% sure that the 2010 center bore is bigger than the 2011, so the wheel will fit. But this will make it lug centric and not hub centric. I bought 2010 17" Flex wheels, fit perfect.
Wikipedia wheel info. http://en.wikipedia.org/wiki/Wheel_sizing
tucker_bmd is offline   Reply With Quote
Old 10-27-2011, 11:40 AM   #4
peterk9
Toyota Highlander Convert
Ottawa, Ontario area
peterk9's Avatar
2011 Limited AWD
Vehicle Specs
Hey,
Thanks
I asked the parts manager this question back in March and he said he didn't know for sure but the part numbers for 2010 vs the 2011 are completely different.
I just had the Winter wheels/tires installed on my Limited yesterday. I went with the base model 17" steel wheel and a 245/65R17 BFGoodrich Winter Slalom KSI tire + TPMS. The OEM were the 20" wheels.
__________________
Peter Explorer Limited White Platinum Tri-Coat,340A (Rapid Spec 302A).
Previous rides;'99 Windstar; '02,'06 & 09 4WD Toyota Highlander Limiteds
peterk9 is online now   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Ford Explorer & Ranger Solid Axle Swap - SAS - Registry Index Randall Explorer/Ranger Solid Axle Swap Registry 16 05-13-2011 02:20 PM
Edmund's review of the 2011 Explorer JDraper Stock 2011 - 2014 Ford Explorer Discussion 0 01-27-2011 07:15 PM
will 94-01 mustang GT (non cobra) 17" wheels fit an AWD X? Mr.Moore Street Trucks 5 02-28-2009 01:08 PM
16" & 17" wheels, what tires fit? SC4x4Sport'96 Ford Explorer - Ranger Tires & Wheels 0 04-02-2004 11:11 AM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
