#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Intermittent starting problem 99 XLT
Reply
Thread Tools
Old 10-28-2011, 04:05 PM   #1
bfiek
99 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Happened yesterday after sitting for 7 hours after a 8 mile drive....
Starter engaged fine, but I ended up having to pump the gas pedal quite a bit to get it to turn over. One it was running, I has to nurse the gas just to keep it running. It has started about 6 times since then with no problems at all and seems to be fine.
Any ideas folks?
bfiek is offline   Reply With Quote
( Join the Elite Explorers )
Old 10-31-2011, 04:43 PM   #2
jonsey142
Toronto Ontario
1999 Limited
Vehicle Specs
Quoted: 0 Post(s)
Had an almost similar issue with my explorer. Got off one day after work and it wouldn't start. Once I got it running I had to two foot drive to keep it running. I've got a 1999 Limited 4.0L V6. Took off all in intake piping from the air filter to the manifold. Sprayed out all my carbon buildup (brake cleaner) and haven't had an issue since. I now make it part of my regular maintence and tune up routine. Hope it helps.
jonsey142 is offline   Reply With Quote
Old 10-31-2011, 05:09 PM   #3
yavapaires
Dewey, Az
1996 XLT
Vehicle Specs
Quoted: 0 Post(s)
I guess I am just plain stupid, but why would pumping the gas pedal cause the engine to turn over? Or did you mean it would turn over and not start? In which case, clean the throttle body, and look into a bad throttle position switch.
yavapaires is offline   Reply With Quote
Old 10-31-2011, 08:19 PM   #4
bfiek
99 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
The engine would turn over but not start until I pumped the gas, would be a better way of saying it I guess. I talked with a friend of mine about his 98 Explorer, he had a similar issue which turned out to be a fuel pressure regulator.
By no means am I an expert on this stuff, but appreciate those with more knowledge than me pitching in. Thanks!
Old 09-04-2012, 02:31 AM   #5
kdspapa
Southern Oregon -Grants Pass
kdspapa's Avatar
99 Mountaineer AWD 5.0L
Vehicle Specs
Quoted: 2 Post(s)
Where on an Explorer is the fuel pressure regulator? How do you test it?
kdspapa is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Intermittent Starting problem, No spark-No fuel JPA EEC IV 4 05-27-2012 10:49 PM
99 EX Sport 4.0 4X4 intermittent battery drain Blueraven Stock 1995 - 2001 Explorers 34 07-27-2011 10:42 PM
93 ranger Intermittant Starting Problem dictatorrj New Member Introductions 1 03-20-2008 11:04 PM
P0406 and P140, Explorer '99 XLT V8 5.0 mfilippa Stock 1995 - 2001 Explorers 4 11-11-2006 03:46 PM
1996 XLT fuel gauge problem dxsza Stock 1995 - 2001 Explorers 0 04-11-2006 08:30 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
