Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Turns over but wont start?!
Reply
Thread Tools
Old 11-01-2011, 03:07 PM   #1
sidneyhop
Orlando, Fl
2000 AWD Limited
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
There was another recent thread that seemed similar but didnt want to hijack it.
Ive got a 2000 limited 5.0 that all of a sudden wont start.
I hadnt driven it in about 3 weeks but before that it ran fine without any issues, hesitation or problems starting. Its getting spark and I checked the fuel pump / PCM relays which were fine. I also jumped the in inertia shut off switch with no luck. I turn the key to on but dont hear the pump (although its hard to hear with the chiming when you turn the key on), and have cycled it on a bunch of time, still no pump sound.
What are the symptoms of a fuel pump / regulator going bad? I was reading on another thread that the regulators on the 2000 limited are in the tank. Whats the best way to test it?
Is it common for a fuel pump to just fail completely like this? Are there any other things I should check before dropping the tank?
Thanks!
__________________
*Current: 2000 AWD Limited {V8 AWD}
*Previous: 1998 Eddie Bauer {V6 SOHC-2WD} (Guy smashed into the back of me-total loss )
*Previous: 1997 XLT {V6 OHV-2WD} (Rolled going 65 on interstate-totaled )
*Previous: 1998 Sport {V6 SOHC-2WD} (Ex wife negotiated ownership :P)
sidneyhop is offline   Reply With Quote
( Join the Elite Explorers )
Old 11-02-2011, 01:14 PM   #2
bobflood
Powder Springs, GA
1997 Eddie Bauer V8 2WD
Vehicle Specs
Quoted: 98 Post(s)
Fuel pumps usually give some warning - but not always. Try disconnecting one side of fuel filter, then turn on ignition and see if fuel squirts out. If not, that confirms that fuel pump is not pumping. Next, check to see that you have voltage at the fuel pump connector at the tank when ignition is on. If yes, replace fuel pump; if no, look further for electrical problem. There are some threads here that show how to cut a hole under rear seat to access fuel pump w/o dropping tank - you may want to consider that.
__________________
1997 Ford Explorer, Eddie Bauer, 5.0L V8, 2WD, 295K+ miles, starting to show its age!
bobflood is offline   Reply With Quote
Old 11-02-2011, 01:18 PM   #3
Turdle
Move along people
Humboldt, KS
Turdle's Avatar
2000 Mounty
Vehicle Specs
Quoted: 700 Post(s)
Does the theft light flash while cranking?
__________________
Jon
9 mile skid, on a ten mile ride. Hot as a pistol but cool inside.
2000 Mountaineer
1998 Mountaineer "Turdle"-gone
1993 Convertible "Vitamin D Wagon" Sold also
Turdle is offline   Reply With Quote
Old 11-02-2011, 02:39 PM   #4
sidneyhop
Orlando, Fl
2000 AWD Limited
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Quote:
Ok, Ill give the fuel filter test and voltage a try. I was looking here and youtube on where the port is to test the fuel pressure but couldnt find a pic for the 5.0. Do you know where it is or where a pic of it is?
thanks
Quote:
No it doesn't. It blinks just when I first turn the key to the on position but after that it stops.
__________________
Old 11-02-2011, 08:53 PM   #5
sidneyhop
Orlando, Fl
2000 AWD Limited
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
does anyone know if the 2000 5.0 awd uses a 'flex line' fuel pump or not?
thanks
__________________
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
1998 explorer xlt sohc, Cold weather(teens) turns but no start astrochimp Under the Hood 0 10-03-2011 12:49 PM
starter turns on its during jump start pmCortez Modified 2002 - 2005 Explorers 2 04-27-2010 09:48 PM
Please help... Engine turns over but wont start HighCotton82 Stock 2002 - 2005 Explorers 8 03-29-2010 09:45 AM
911- Won't start. Turns over and kicks for a second then dies mikeh Elite Explorer 911! 6 10-18-2004 10:19 PM
Escort turns but wont start Pixie_0 Under the Hood 4 11-23-2001 12:50 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
