Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Modified 2002 - 2005 Explorers
Notices
Modified 2002 - 2005 Explorers Questions related to modified 2002 - 2005 Explorers and Mountaineers. For Sport Trac and Sport models use the 1995-2001 forum. Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, lift kits, engine swap, transmission swap.
replacing right rear wheel bearing every 10k.....need help
Reply
Thread Tools
Old 11-02-2011, 01:55 PM   #1
blue_goose
WY
'02 4x4 4.0 200K
Vehicle Specs
Quoted: 5 Post(s)
(Original Poster)
So the original owner replaced both rear bearings at 60k. At 120k the right rear went so I just replaced the bearing, not the hub. At 130k the r rear went again so I replaced the bearing and hub. Now at 144k the right rear is making a low growling/roar noise again.
A mechanic friend said he isn't convinced its the bearing because he said they always have wheel play (this one has no wheel play). I don't know what else the noise could be. It does have the rear diff noise (has for 80k) but I can hear both noises at once so I think that's out. The left rear is quiet as can be with no wheel play. I put 20k on a year in rual MT (we have to drive 2 hours for groceries) so I need it to be reliable.
Any ideas why I keep going through wheel bearings like this????
blue_goose is offline   Reply With Quote
( Join the Elite Explorers )
Old 11-02-2011, 04:15 PM   #2
LeeExploder
Fort Myers- FL
02 Ford Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
Dk Exp
I have an 02' explorer sport 2wd and I have gotten that same noise from the passenger side rear wheel and same problems with the bearings. There's a few things to look at when tackling this problem. First off what grade oil are you using? (Rhetorical) you may need to use a heavier oil for colder weather or vice versa. It its happening over a period of 10k miles then its something that's not going to be visible right away. Next thing would be the axle. That particular side comes apart from the entire axle and you may want to check the axle to see if its 'true'. And the last thing it could be is the suspension tor that side. Check leaf springs and shocks for wear or damage. All these things put together added up to my wheel bearings going every 10-15k miles. It took me a while to figure this problem out and I hope I've saved you even more of a headache.
LeeExploder is offline   Reply With Quote
Old 11-03-2011, 09:24 PM   #3
blue_goose
WY
'02 4x4 4.0 200K
Vehicle Specs
Quoted: 5 Post(s)
(Original Poster)
Thanks for the ideas. Mine has the independent IRS compared to your solid axle so its a different setup but your comment about the suspension got me thinking- the tire is tilted in towards the vehicle with the closest part of wheel being the top of it, I believe its called camber. I am hoping a alignment will fix that. Would that cause the bearing to go bad? Thats my only idea otherwise I'm stumped.....
Old 11-04-2011, 08:25 AM   #4
LeeExploder
Fort Myers- FL
Vehicle Specs
Quoted: 0 Post(s)
Dk Exp
I know the 'camber and toe' is the alignment of your tires but I'm not sure if its adjustable when it comes to the rear tires. Its controlled by your tie rod ends which 'tilts' your wheel in or out. The bearings in the front would go bad if the alignment is off but like I said I'm not sure about the rear end. I just did my alignment with a tape measure after changing upper and lower ball joints and reset torsion bars at 120k
Old 11-04-2011, 03:58 PM   #5
jrford
Birmingham, MI
'10 Sport Trac
Vehicle Specs
Quoted: 2 Post(s)
Quote:
couple of thoughts, on the alignment, you might want to get camber kits before you go. Last one i had done they said they would just set the toe-in as they had no kits. Camber kits from ford are just big washers, not expensive at all. with the kit there will be some adjustment for Toe/Camber/caster, most shops only do 'set the toe and let it go' you might have to 'work' a little to get them to do it.
Bearings, most brands are coming from China, cheap junk, maybe it lasts a year at best. See if you can get 'Timken' bearings, might last a little longer (lifetime). i swear when i did the fronts it did say 'usa' not 100% though.
Torque the big nut correctly, and re-check after 500miles. If not done correctly or with the wrong spec they will fail prematurely.
If all of the above is followed and they still fail, you might want to get a new knuckle? Maybe its tweaked or jacked up some how and no matter what you put in they will fail.
just some ideas, hope it helps.
__________________
Jim
2010 Mercury Mountaineer Premier, V8 AWD, 35k
2010 Sport Trac Limited, V8 4WD, 80k
2004 EB Quad Buckets V8 AWD, 105k
jrford is offline   Reply With Quote
Old 11-04-2011, 07:13 PM   #6
blue_goose
WY
'02 4x4 4.0 200K
Vehicle Specs
Quoted: 5 Post(s)
(Original Poster)
thanks for the help. I will look into the knuckle and also how tight that bolt is. I have been using Timken bearings in it so that rules that out. How do you tell if a knuckle is bad?
Old 12-01-2011, 12:30 PM   #7
blue_goose
WY
'02 4x4 4.0 200K
Vehicle Specs
Quoted: 5 Post(s)
(Original Poster)
Replaced the bearing last weekend. When my friend pressed it out on his shop press we saw that the inside of the housing was corroded, hence all the noise. I replaced it with a timken bearing and hub so hopefully it is good to go. It was an advance auto bearing and hub that went bad so hopefully they're warranty wil cover it. so this is what I know
1.replaced just the bearing at 115k or so, not the hub
2.hub was bad and made the bearing go bad at 128k, replaced both
3.bearing from advance auto corroded from inside out and a faulty part made it go bad
4.replaced with timken and there should be no reason for it to go bad again.
Hopefully this works. I'll keep you guys updated.
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
2002 Mountaineer AWD rear wheel bearing replacement phoenix12321 Stock 2002 - 2005 Explorers 6 12-06-2015 09:24 AM
Wanted Instructions and part numbers for rear wheel bearing replacement. Milt 73 Explorer & Ranger Transmissions, Transfer Cases, & Differentials 2 06-07-2011 03:24 PM
replacing rear wheel bearing need help!! 2002xlt4.0 Modified 2002 - 2005 Explorers 4 03-27-2011 08:17 PM
rear diff or wheel bearing elcapitanmas Stock 2002 - 2005 Explorers 4 04-09-2010 12:00 AM
Rear wheel bearing adjustment? Froggy Stock 1995 - 2001 Explorers 2 11-01-2009 08:00 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
