Go Back   Ford Explorer and Ranger Forums "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
02 Explorer metal on metal rubbing noise when turning
Reply
Thread Tools
Old 11-16-2011, 09:31 PM   #1
BigFellor
Shittsburgh, PA
2002 Explorer XLS
Vehicle Specs
Quoted: 13 Post(s)
(Original Poster)
Vehicle is a 2002 Ford Explorer 4x4. Tonight it developed a metal on metal rubbing noise while turning right. Turning left or straight the noise goes away completely. Turning right and and it gets worse, almost to a grinding noise the further right I turn. Any ideas on what I should look into or what could be causing this?
BigFellor is offline   Reply With Quote
( Join the Elite Explorers )
Old 11-16-2011, 09:32 PM   #2
shooterdude199
Irmo, South Carolina
01 Sport Trac
Vehicle Specs
Quoted: 4 Post(s)
bearings in the cv's?
__________________
My Registry
shooterdude199 is offline   Reply With Quote
Old 11-16-2011, 09:37 PM   #3
imp
Missouri Ozarks
2004 XLT
Vehicle Specs
Quoted: 130 Post(s)
After C-V check, look closely for back side of front brake rotor interfering with the "lip" on the very outer edge of the lower control arm. We had one where the rear braking surface of the rotor had a groove worn in it 1/8 inch deep. imp
imp is offline   Reply With Quote
Old 11-16-2011, 11:44 PM   #4
BigFellor
Shittsburgh, PA
2002 Explorer XLS
Vehicle Specs
Quoted: 13 Post(s)
(Original Poster)
What am I checking and how for the cvs?
Old 11-17-2011, 09:16 PM   #5
imp
Missouri Ozarks
2004 XLT
Vehicle Specs
Quoted: 130 Post(s)
Quote:
Take off front wheels.
A slight area exists on the back side of the brake rotor splash guards where the entire width of the area swept by the pad (on the back side of the rotor) is exposed. Look at that for a groove being cut in the surface. If it's there, steering the wheel is allowing the rotor to rub on the outer edge of the lower control arm
C-Vs tend to make a rather clicking noise when going bad, noticeable when the wheels steer to go around a corner. You can turn each side most easily by hand with the wheels mounted on the car, front end raised off the ground, and the steering wheel rotated into a turning stance. Good C-Vs will feel smooth as they are rotated. There are 2 on either side, front axle; the outer one rotates about the steering axis. imp
Old 11-19-2011, 01:51 PM   #6
Kazer
Sneads Ferry, NC
2001 Excursion PSD
Vehicle Specs
Quoted: 9 Post(s)
I just had this same problem with my truck, grinding when I turned right but nothing when I turned left or went straight. Jack your truck up and check for play in the driver side rear wheel bearing
Kazer is offline   Reply With Quote
Old 11-19-2011, 01:54 PM   #7
Kazer
Sneads Ferry, NC
2001 Excursion PSD
Vehicle Specs
Quoted: 9 Post(s)
http://www.explorerforum.com/forums/...d.php?t=254848
Watch the video I posted and see if the noise is similar to yours. If so, its the driver rear wheel bearing
Old 11-20-2011, 10:37 AM   #8
imp
Missouri Ozarks
2004 XLT
Vehicle Specs
Quoted: 130 Post(s)
What is the explanation for a bad rear wheel bearing making noise when turning left?? During a left turn, the right side wheels turn faster than the left, as they travel a greater distance. Furthermore, turning left increases the weight carried by the right side wheels, and removes weight from the left side, which should make a bad bearing on the left side make LESS noise. imp
Old 11-20-2011, 10:48 AM   #9
BigFellor
Shittsburgh, PA
2002 Explorer XLS
Vehicle Specs
Quoted: 13 Post(s)
(Original Poster)
Tanks for the tips guys. I turned out to be pretty simple; I had new pads and rotors put on the back and one of the backing plates came loose a little and was rubbing on the back of the rotor. Put it back in place and all is well. Whew.
Old 11-20-2011, 11:08 AM   #10
Kazer
Sneads Ferry, NC
2001 Excursion PSD
Vehicle Specs
Quoted: 9 Post(s)
Quote:
I was turning to the right in that video. Turn right, bad rear left, turn left, bad rear right?
Old 03-04-2013, 07:13 AM   #11
brtate80
Nashville,Tn
'02 XLT V8 4x4
Vehicle Specs
Quoted: 0 Post(s)
Grinding while turning right or have car lean right...
What did you find that was causing this? I have a 2002 explorer xlt awd that is doing that. When I turn to the right it grinds. I can even while driving jerk the wheel to the right a little at it will grind. ????
brtate80 is offline   Reply With Quote
Old 03-04-2013, 11:31 AM   #12
Ickey09
Columbus, Ohio
03 XLT
Vehicle Specs
Quoted: 1 Post(s)
its deff a wheel bearing.
Ickey09 is offline   Reply With Quote
Old 03-04-2013, 12:29 PM   #13
brtate80
Nashville,Tn
'02 XLT V8 4x4
Vehicle Specs
Quoted: 0 Post(s)
I replaced the wheel hub assembly, new upper ball joint, and put a new axle in. Nothing changed.
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Top search phrases for this site Rick Suggestion Box - Forum Feedback 11 09-12-2011 09:22 AM
2012 Ford Explorer Overview Rick Stock 2011 - 2017 Ford Explorer Discussion 0 08-04-2011 09:39 PM
02 Ford Explorer XLS 4X4 87k Rear End Noise tkline2908 Stock 2002 - 2005 Explorers 16 11-29-2010 11:27 AM
Front right tire metal rubbing noise Afboy143 Stock 1995 - 2001 Explorers 6 05-19-2010 10:20 AM
More 2002 Explorer info Rick Auto Industry News 12 10-08-2000 11:09 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
