| Ford Ranger - Mazda B-Series Forum Ford Ranger and Mazda B Series forums. The Mazda B2300 B3000 and B4000 are clones of the Ford Ranger, with all systems the same. The only differences are trim and a few body parts. This forum discusses Ford Ranger and Mazda B series specific issues. Owners of the older Mazda B2000 B2200 and B2600 are welcome as well. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Overland Park, KS
2002 XLT 4.0
93 Ranger Transmission
My buddy has a 93 ranger 3.0 4x4 5 speed manual, and his tranny has a pretty decent leak at the top near the shifter. He has filled it up regularly, so it's definitely not low on fluid. When the truck is in neutral and the shifter is to the left (near 1st/2nd), there is a pretty bad grinding noise. Its weird bc the the shifter is still in neutral. Also when shifting into 1st and 2nd it grinds for a second, but drives fine.
Any ideas? Thanks for the help |
#2 |
Omaha,NE.
'93Ford Ranger
tras. noise from D.L.M.Sr.
The noise that you are most likely hearing is the bearings going out.The slight grinding that you are getting is because the syncros are going bad. trans. needs rebuilt/replaced. I had the same problem,did not fix,now looking for replacement. I have told trany has to come out of '91-'94 ranger 3.0 only,or mozda B3000 '94 only. Personaly if I had the money I would try to make another trany fit,after all the 2.9v6 is only 1 10th of one liter smaller, and do not know why Ford would not make the trany fit more the one engine size,espiecally when there are so close to each other.About the leak you my be over filling,or the gasket for some reason or other has gone bad. Check fill level pull fillplug on side of trany,fluid should beable to touch fluid by putting little finger in and bending it.If you can do that it is full,if fluid wants to come out when you open plug it is over filled and will find the easyest way out.
Last edited by D.L.M.Sr.; 03-19-2012 at 09:06 PM. Reason: for got to advise on leak. |
#3 |
Moderator
Elite Ranger Omao, Kauai
'93 Ranger XLT 4X4
This link shows how to fix what is probably your leak: http://www.therangerstation.com/tech...aintenance.htm
__________________ Bill Collins 93 Ranger XLT 4X4 "Beauty is only sheet metal deep." |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Transmission leak at radiator | sabasigh | Explorer & Ranger Transmissions, Transfer Cases, & Differentials | 11 | 02-12-2013 10:51 AM |
| History of the Ford Ranger | Tbars4 | Ford Ranger - Mazda B-Series Forum | 9 | 04-20-2010 09:50 PM |
| Transmission issues in old Ranger | Thelt | Ford Ranger - Mazda B-Series Forum | 6 | 10-21-2008 12:47 PM |
| '93 X motor and transmission replacment | Xplorer92 | Under the Hood | 1 | 05-14-2005 07:39 AM |
| 98 Explorer Rims on a 93 Ranger? | gijoecam | Ford Explorer - Ranger Tires & Wheels | 3 | 07-10-2001 09:51 PM |
| Thread Tools | |
