#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
New Key with VIN number
Reply
Thread Tools
Old 11-22-2011, 11:23 AM   #1
jrobie79
Boston, MA
2002 XLT 4.0 VIN "K"
Vehicle Specs
Quoted: 7 Post(s)
(Original Poster)
I think I left my key for my explorer at the hotel on vacation...obviously they cant find it, so my question is can I go to a ford dealership and have them cut me a key with my VIN number and title (to prove ownership)?? I know for my 1991 BMW I can do this, hoping something similar is available for Ford.
jrobie79 is online now   Reply With Quote
( Join the Elite Explorers )
Old 11-22-2011, 11:47 AM   #2
fifthranger
cleveland, oh
08' Ranger XLT
Vehicle Specs
Quoted: 1 Post(s)
Shouldn't be a problem at all. That is what they do if an owner wants another made, such as when a used car is purchased and only one key is given. The V.I.N. identifies the vehicle, so by proving ownership, I'm sure they will be more than happy to cut a key. Only problem is the expense since I hear they aren't cheap. I would plan on spending $140 or so.
fifthranger is offline   Reply With Quote
Old 11-22-2011, 11:54 AM   #3
jrobie79
Boston, MA
Vehicle Specs
Quoted: 7 Post(s)
(Original Poster)
I just called one place, and they said only for 02+ model years...sounds a little strange, anyone have experience with the 99s?
Old 11-22-2011, 06:23 PM   #4
fifthranger
cleveland, oh
08' Ranger XLT
Vehicle Specs
Quoted: 1 Post(s)
'Google' replacement key or use ebay. It may take some searching, but there are inexpensive ways out there to get a key for your vehicle. You may even try a local automotive locksmith. The good news is you shouldn't have a P.A.T.S. system with a 99', so it will be easier and cheaper to find.
Old 12-13-2011, 12:01 AM   #5
jrobie79
Boston, MA
Vehicle Specs
Quoted: 7 Post(s)
(Original Poster)
well it appears I do have the P.A.T.S. chip key, and I've found prices in the 200 dollar range to get a key made....anyone offer any other advice?
Old 12-13-2011, 01:14 AM   #6
BurnTheLight88
Pittsburgh, PA
'99 Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
Yes all the late 90's have the PATS system. I would call the most rural Ford dealership in your area. Here in Pittsburgh suburbs, I can get a key cut and programmed for about 80. It shouldn't be 200.
BurnTheLight88 is offline   Reply With Quote
Old 12-13-2011, 10:50 AM   #7
jrobie79
Boston, MA
Vehicle Specs
Quoted: 7 Post(s)
(Original Poster)
called two other dealers, both told me the same thing, they can only look up cars from 02+
Old 12-13-2011, 11:36 AM   #8
brewman
Vehicle Specs
Quoted: 0 Post(s)
The way I understand it is the 1997 was the last year that explorer did not use the Pats key system. You received a code tag with the original sets of keys. The dealer or locksmiths could enter the code into the key cutter and give you a new key.
In 1998 the Pats system was used with the chip in the key for all or most Fords. This system needed the two original keys in order to program the chip after a new blank pats key was cut in order for the chip to be programed.
Without both keys.. They will need to erase then reprogram the security system codes.
The dealerships are probably the only ones that have the equipment to do this. I know that all fords made between 1998 and 2001 have the same problems. I think 2002 &> they can look up the vin #
brewman is offline   Reply With Quote
Old 12-13-2011, 12:21 PM   #9
2000StreetRod
Greenville, SC
2000StreetRod's Avatar
00 Sport FI,03 Limited V8
Vehicle Specs
Quoted: 45 Post(s)
PATS Locksmith
A PATS qualified auto locksmith should be able to cut you a set of keys and program them. The locksmith will need access to the vehicle to program the keys. It takes about 20 minutes to program a key if you don't have two. You should always have three keys. That way if you lose one it is less expensive to get a third one cut and programmed.
2000StreetRod is offline   Reply With Quote
Old 12-13-2011, 01:21 PM   #10
koda2000
Georgia
2001 Explorer EB 5.0L
Vehicle Specs
Quoted: 1074 Post(s)
i have an 2001 so i don't know if my experience helps you but... i had only one transponder key so i went to ebay and purchased another online for just under $20 delivered. i then took it to my ford dealership and they cut it and programmed it for $35 no questions asked. just make sure the key you buy looks identical to your original key and don't count on advertised "vehicle compatibility" charts.
koda2000 is online now   Reply With Quote
Old 12-13-2011, 01:55 PM   #11
RomeovilleIL
Illinois
98 LTD, 00 XLT
Vehicle Specs
Quoted: 89 Post(s)
http://www.motorcraftservice.com/vdi...up&kevin=rules
You can verify if you key is available by VIN here. It costs $8 for most locksmiths to use it. Can't imagine the dealership would be unable to run.
RomeovilleIL is offline   Reply With Quote
Old 12-13-2011, 05:39 PM   #12
brewman
Vehicle Specs
Quoted: 0 Post(s)
yeah man on getting a third key made while you have 2! then you can program the duplicate yourself.
My 2001 150 Truck only has one and they want 135.00 at the dealerships for the reprograming fee.
It cost 130.00 for them to even look at your vehicle for normal repairs (Ford Diagnostic testing service fee)
that ebay deal for twenty and 35 to reprogram and cut sounds like a great deal if you can get that done??
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Chassis VIN number help is needed. springers UK Explorer Owners Forum 22 07-02-2013 07:31 PM
03 explorer gas gauge .. slow to respond Trek5000 Stock 2002 - 2005 Explorers 9 02-19-2011 09:48 AM
Vin number locations rhauf Modified 1991-1994 Explorers 3 09-29-2010 11:56 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
