Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Ignition Switch/lock replacement...
Reply
Thread Tools
Old 11-24-2011, 05:51 PM   #1
Zack1978
1999 Ford Explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hi everyone,
I have a 1999 Explorer, and the ignition switch is worn out and broken. The switch is so worn that you can simply pull the key out while the truck is running. Also it is now not returning to the lock position, without force.
How hard is it to replace the ignition switch? What are the steps to doing this job?
What difficulties will I run into since my key has a chip in it, and the truck will not start without the chip key. I was on Rockauto and they have a Motorcraft part for $55.00 with keys (http://www.rockauto.com/catalog/raframecatalog.php). Will that part work on my truck? Will I need to have it towed to a dealer for the keys to be reprogrammed? Any ideas?
Thanks,
Zack
Zack1978 is offline   Reply With Quote
( Join the Elite Explorers )
Old 11-26-2011, 03:46 PM   #2
Zack1978
1999 Ford Explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Bump....Anyone?
Old 11-26-2011, 04:17 PM   #3
drdoom
VA
2005 Eddie Bauer 4.6L 4X4
Vehicle Specs
Quoted: 343 Post(s)
I'll see what I can find out about the R&R, in the meanwhile, have you read up on PATS?
http://www.explorerforum.com/forums/...d.php?t=234975
drdoom is offline   Reply With Quote
Old 11-26-2011, 08:16 PM   #4
RomeovilleIL
Illinois
98 LTD, 00 XLT
Vehicle Specs
Quoted: 89 Post(s)
The replacement is actually very easy, doubt it takes 2 minutes. Look at the bottom of the steering column - you'll see a hole with no screw in it on the passenger side. Place a screwdriver or punch about 3 inches into the hole until it rests on the spring loaded plunger. Turn the key to acc on, push the button up with the screwdriver (1/4" push), then the entire assembly will slide out. New ignition slides in the same way with the key in the ignition turned to acc on. If you already have 2 keys for your truck, you can easily program the new keys. If you only have 1 key, then the dealer or a locksmith with the correct computer will be needed to program the keys.
RomeovilleIL is offline   Reply With Quote
Old 11-27-2011, 01:17 PM   #5
Zack1978
1999 Ford Explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
Thanks! I do have two keys for the truck, how do I use them to program it? Also with the new ign switch, it comes with new keys. I assume that I must use the new keys, but do the new keys usually have the chip?
Thanks,
Zack
Old 11-28-2011, 12:17 PM   #6
RomeovilleIL
Illinois
98 LTD, 00 XLT
Vehicle Specs
Quoted: 89 Post(s)
Quote:
Thanks,
Zack
The new ignition cylinder will come with 2 PATS keys. If you have 2 working ignition keys right now then programming the new ones won't be too challenging. First you need to have all the door closed and locked. Then using one of the working keys, turn the truck to run (don't start). Let it sit until the theft light turns off, maybe 30 seconds or so. Then turn back to off, switch to the second working key and repeat turning to run and waiting for theft light to turn off. You are now in programming mode. Pull the ignition cylinder out, swap in the new one with key and turn from lock to run. When theft light turns off the key is recognized. Turn back to lock and swap in second new key. Repeat turning to run and again wait for system to recognize the key. Start truck to end programming mode and verify keys work. Done in about 4-5 minutes.
If you have trouble trying to swap out the cylinders quickly enough for whatever reason, you can go route 2 which needs a little more prep, maybe 10 minutes: Take off the plastic column shroud by removing the 3 phillips screws from the bottom, unscrewing the tilt lever (its actually a steel bolt with knurled handle), and popping the top/bottom apart. Swap the cylinders as noted before leaving 1 new key in place. Now look at the lock cylinder. You will see there is a green or blue plastic "c"-shaped sensor with a wire running to it sitting on the cylinder. This the PATS key reader. You can pull it off the cylinder and hold it against the keys as you go through the off/on sequence. Start with sensor against the old working keys one at a time, then the new loose key and end by puting the sensor back in place and turning with the new key you have in the ignition. Once finished, snap the column covers back on, replace screws and tilt lever.
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
How to: Quick and Easy 2nd gen Blend Door Replacement Tutorial Magicland Explorer, Ranger, A/C & Heater systems HVAC 127 04-14-2016 11:52 AM
1994 Explorer Ignition cylinder replacement. 94EBOwner Stock 1991 - 1994 Explorers 10 04-25-2015 05:43 AM
Clutch replacement 91 Explorer asymsynap Technician's Tips and Tech 6 07-24-2008 10:12 PM
Where is terminal controlled by ignition? Hudsonator Explorer Audio & Navigation 4 02-06-2005 03:09 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
