Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Ford Explorer Sport Trac Forums > 2007 - 2010 Explorer Sport Trac
Notices
2007 - 2010 Explorer Sport Trac All questions about the stock 2006- 2010 Ford Explorer Sport Trac.
Adrenalin Fog Light Info
Reply
Thread Tools
Old 11-27-2011, 01:15 AM   #1
Skud51
Vehicle Specs
(Original Poster)
Hi All,
After having one of my fog bulbs burn out I've been searching for some decent (keyword "decent") replacement bulbs. Most places (even the manual) list the bulb as a 9145 (or H10) bulb just like all the other Sport Trac models, however the bulb is NOT the same.
Here is what I've found so far:
1) The bulb is actually an incandescent (not even halogen) bulb rated at 24 watts.
2) There are various different part numbers for this bulb: 5202, PS24W, H16, and 9009 are all the ones I've come across. Most people think there are the same bulb, but the H16/9009 only share the same base.
3) The PS24W and the H16/9009 bulb are NOT the same wattage, but they do use the same base and will fit in the housing. The H16/9009 is a 37 watt halogen bulb, but people have been melting their housings with 35 watt bulbs (35-watt HIDs specifically, check out the Camaro forums).
4) It seems a number of manufacturers are using this same housing and bulb in their vehicles. So far I've seen it used in:
- A number of '09-up Chevy products (Avalanche, Tahoe, Acadia, Camaro)
- Dodge/Jeep is also using it
- 07 - 09 Mustang GT500 and '07-up Ford Escape
5) The OEM/factory PS24W bulb has a round, bulbous shape to it, almost like those fancy vanity lights used in a bathroom. The H16/9009 bulbs are more short and narrow like a traditional Hxx or 90xx halogen bulb. Websites seem to use these terms interchangeably even though the wattage is different.
This is a PS24W bulb:
This is an H16/9009 bulb
I've been looking into something better than the stock ones (hey, who isn't) and the only two options I've come across would be to replace the whole units with ones from ebay that say they use an H3 bulb. The H3 bulb is a super common and easy to get bulb in various wattages and colours. However, the most common wattage for the H3 is 35w and 55w. If the stock housings are melting with 35w HIDs then I don't see how these aftermarket ones are any different. I have some questions into the Ebay sellers on this.
Here are the lights on Ebay: http://www.ebay.com/itm/290637865800...ht_5623wt_1396
To make matters even more confusing, look at this product here. It's a fog light for a 2010 escape. It's the same housing and SHOULD use the same bulb, but as you can see from the pictures, the bulb is NOT the typical PS24W bulb, but instead looks like an H3 or H16/9009 halogen bulb. Does anyone have a 2010 Escape they can look at to see what bulb it has?
The other (and last resort) option would be to install a 25w 4300k HID kit, but I don't really want to go this route because of the possibility of glare.
Riley
Skud51 is offline   Reply With Quote
Old 11-27-2011, 01:01 PM   #2
JohnnyO
Sport Trac Moderator
Pittsburgh, PA
JohnnyO's Avatar
'08 Sport Trac
Vehicle Specs
Thanks for the info.
I was not aware that the Adrenalin took a different bulb.
__________________
'08 Sport Trac, Gibson exhaust, K&N, Firestone Destination A/T's, Steelers regalia.
"It is not the multitude of ale-houses that occasions a general disposition to drunkenness among the common people; but that disposition arising from other causes necessarily gives employment to a multitude of ale-houses." -- Adam Smith, 1776
JohnnyO is offline   Reply With Quote
Old 11-27-2011, 01:33 PM   #3
snoranger
Jackson, NJ
snoranger's Avatar
94 limited on 35's
Vehicle Specs
Hyster/Yale uses the ps24w on some of their forklifts as headlight bulbs.
Hyster PN# 1544764
Yale PN# 5800432-07
__________________
94 limited: 4.0l, 5spd swap, 6" skyjacker lift, 35x14.5 thornturds, 4.56s. 5.0 swap started (94 cobra 5.0, zf 5spd, np205)
95 xlt: stockish (SOHC swap, 30,000miles and I blew up the 3rd 4r55e...now collecting parts for a Cummins swap.)
Cummins 4BT swap thread
Ranger bed trailer build
snoranger is online now   Reply With Quote
Old 11-27-2011, 06:41 PM   #4
Skud51
Vehicle Specs
(Original Poster)
Still researching..
There's lots of people in the same position. Looking for better/upgraded bulbs or housings, but there isn't a whole lot of selection out there yet. The whole automotive industry seems to be moving to this housing (fully plastic) and bulb (PS24W).
I came across a posting on a Camaro forum (here). A gentleman there installed a set of the OEM-style replacement housings that some with the H3 bulbs. He's confirmed that the bulbs are 35 watt H3 bulbs.
I think that as long as the housings don't melt, then this would be the ideal upgrade. H3 bulbs are dime a dozen and many different companies make them, the only trick will be to find them in 35w.
I don't know if the Ebay housings are any different than the stock ones. Perhaps they're able to better withstand the heat?
Riley
Old 11-28-2011, 10:22 AM   #5
Skud51
Vehicle Specs
(Original Poster)
So I received a response back on my inquiry regarding the fog housings on Ebay and wattage of the H3 bulbs they come with.
The bulbs are a 20 watt H3 bulb. So, that's no good since that's even less than the stock 24-watt units. It also doesn't bode well for the housings either. I was hoping they would at least be a little better constructed than the stock ones and perhaps could handle a higher wattage bulb without melting, but I don't think that will be the case.
While doing some more reading last night on the Ford Escape forums, I came across a number of people who've had melting issues with the "H16" replacement bulbs from Putco and Nokya in their stock housings. It seems to be a crapshoot though as some have it and some don't.
The only ones not having issues are the ones using an HID retrofit kit that comes with 25w bulbs and 25w ballasts. The kit is from http://www.spencershids.com and called "5202 complete 25w kit". I'm not sure if I want to go with an HID kit though. I don't want the glare associated with it.
Riley
Old 12-18-2011, 08:42 AM   #6
stolen 5.0
bridgeport oh
2010 adrenalin
Vehicle Specs
I ordered HID's for my STA from my Distributor. They are great, I can see much better. no problems of melting in my headlamps or fogs.
I didn't notice any "glare" though.
stolen 5.0 is offline   Reply With Quote
Old 12-18-2011, 09:49 AM   #7
eppd00
Sparta,Ga
08 Sport Trac Adrenalin
Vehicle Specs
Which kit did you end up using?
eppd00 is offline   Reply With Quote
Old 12-20-2011, 09:25 AM   #8
psycareyo
Plattsburgh, NY
2010 STA Supercharged
Vehicle Specs
Need details. This is something I really want to do. Our headlights suck!
__________________
2010 Ford Sport Trac Adrenalin 4.6L V8 AWD
SOS COP 31850, Magnaflow 14236, DMH E-Cutout, SCT Xcal3 ECM Brenspeed Dyno Tune & TCM Tune By Torrie @ Unleashed, Saleen VI.5 Supercharger Conversion by Brenspeed 400RWHP 386RWTQ!
psycareyo is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
2000 Explorer fog light connector ford4joe Stock 1995 - 2001 Explorers 2 08-24-2011 11:22 AM
HELP fog light wireing rjeller09 Performance Lighting 2 03-16-2011 03:25 PM
Rear Fog Light mountainbiker Performance Lighting 0 08-27-2003 01:32 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
