#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
ABS Light P0500 & No Speed O
Reply
Thread Tools
Old 11-27-2011, 01:06 PM   #1
Radioace318
Shreveport Louisiana
1999 Exp XLT 5.0 2WD
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
The saga continues.
99 exp xlt 5.0 2wd auto trans.
Replaced (what I was told is the vss) on the 3rd member.
Replaced both wheel speed sensors on front.
Still ABS light on all the time. Check Engine Light comes on at highway speeds only. OBD II reports P0500
Never had a problem with shifting, OD is not a problem. It runs fine.
I sent this problem to one of those pay for an answer sites. Here was my question and reply(s)
"I have a 99 Explorer XLT 2WD. I replaced the sensor on the 3rd member and both front wheel speed sensors. I still have the ABS light and OBD II Code P0500. and NO Speed-O. What should I do next? A bad module maybe?"
answer:
"My reference material shows the VSS on the side of the transmission. This is the sensor that sends signals to the ecm for the speedometer and odometer. In the overhaul instructions in my reference, it's also called the output shaft speed sensor.
Different sized tires from what the vehicle came equipped with will cause the speedometer and odometer to read incorrectly but as far as I know shouldn't cause the fault code you're experiencing.
Tiny Answered by rivermikerat (expert)
1,052 answers provided "
Keep in mind this was the Free Ask area of the service.
ANy ideas anyone?
Radioace318 is offline   Reply With Quote
( Join the Elite Explorers )
Old 11-27-2011, 02:42 PM   #2
drdoom
VA
2005 Eddie Bauer 4.6L 4X4
Vehicle Specs
Quoted: 304 Post(s)
So you replaced the sensor on the rear differential?
EDIT: I just googled "3rd member", I was not familiar with that term...so that answers my question.
I suppose it could be a wiring problem to that sensor.
drdoom is offline   Reply With Quote
Old 11-27-2011, 02:58 PM   #3
Radioace318
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Quote:
Yes Sir.
The one just to the top of the drive shaft and both on the two front wheels. Dude on the ask me web service tells me the vss in on the tail shaft of the transmission. I crawled under and found a small plate over where the old style speed cable would connect. Nothing connected to it except that little cover plate.
I think I may have confused the vss with the wheel speed sensors. I assume this is two different things so I replaced all 3 sensors. (two on the front wheels & one on the 3rd member)
I did see however a mass of wires connected to the transmission. Unless I overlooked it, I found NO sensor on the transmission.
My little ODB II tool cost me about 60 bucks 4 years ago. I do not get the information as to what sensor it is, just a P0500 (VSS Sensor A Malfunction)
I must be over looking something somewhere. May have a bad module? I'm at the end of my rope here.
Cheers
Rick
PS: I might add, After replacing the sensor on the 3rd member I drove around the neighbor hood never getting over 30mph or so. Should I take it out on the highway to 60 or 70mph and try to give the computer time to "re-learn" (for the lack of a better word) the system is working correctly?
My check engine light WILL NOT come on at slow speeds. Only at highway speed will it come on and return a code of P0500,
Old 11-27-2011, 03:06 PM   #4
drdoom
VA
Vehicle Specs
Quoted: 304 Post(s)
Rick, so you clear the code with your scanner after sensor replacement, and then the light comes back on?
PS: It is my understanding the sensor on the 3 member is VSS and ABS combined. The sensor on the transmission is the OSS (output shaft speed) sensor and is not used for ABS or speedometer.
Can you check voltage at the harness connector for 3rd member sensor?
Old 11-27-2011, 03:13 PM   #5
Radioace318
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Exactly.
I reset the light and will come back on at highway speeds 3 or 4 minutes later.
The ABS light is ON all of that time. Can not get it to go out even with a "clear codes" command. That turns off the check engine light only.
Old 11-27-2011, 03:52 PM   #6
Radioace318
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
I am however trouble shooting ODB II code P0500 (on another thread) I have replaced all three sensors (2 on front wheels & 1 on the differential) to no avail. One web site service tells me the vss is located on the tail shaft of the transmission. BS, Not on this ride.
Rick
Old 11-27-2011, 05:09 PM   #7
SkyJumper
DISABLED AIRBORNE VET
SW Florida
SkyJumper's Avatar
1999 Expedition XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Rick
If it is a 8.8, the VSS sensor is on top of the rear end on the front side above the pinion input. There is a wire running to it. Unplug it and take the one screw out and pull the sensor out. Try cleaning it up and replacing it and see what it does. Before you restart and try it out, reset the ECu though so you are starting fresh on the readings.
PO500 Veh Speed Sensor A malfunction-
A code P0500 may mean that one or more of the following has happened:
* The Vehicle Speed Sensor (VSS) is not reading (functioning) properly
* There is a broken/frayed wire leading to the vehicle speed sensor
* The vehicle's PCM is not correctly configured for the actual tire size on the vehicle
__________________
99 Expedition XLT 4x4- Edge HT/EVO tuned, full Spectre CAI kit, lifted, Rancho RS5000's, 33 Nitto's on 16x10 Pro-Comps, Hooker Aero Chamber exhaust, Black Brush Guard, more to come.
SkyJumper is offline   Reply With Quote
Old 11-27-2011, 05:19 PM   #8
Radioace318
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Thanks for the heads up. What is 8.8? The module?
Old 11-27-2011, 05:28 PM   #9
SkyJumper
SW Florida
SkyJumper's Avatar
Vehicle Specs
Quoted: 0 Post(s)
The rearend, that is the size of rear axle housing you have in that Explorer. So on the VSS it should be on the top of the rearend in front above the pinion. You will see it, it has a plug going to it with 2 wires or one wrapped. The VSS is reading the rotation of the hone ring that is attached to the back side of the ring gear. But if you increase or change the tire diameter then it throws the VSS in a tissy because it can not read the proper speed due to the different tire size. Also they sometimes get caked up with grime on the end of it that is exposed to the oil and grime in the pmpkin, sometimes you can just clean the sensor up and it will read again. The sensor can be bought at any auto store for cheap too.
__________________
Old 11-27-2011, 05:51 PM   #10
Radioace318
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Oh That is the 8.8 info. Well, That was the first thing I did was to make sure all the wires & connections were nice and clean. I did remove the vss and cleaned it up to. That did nothing to address the issue.
That is when I ran down to the local Advance Auto and picked up a new vss and installed it. Still, No Joy.
Then I checked both front wheel sensors with a VOM (Volt Ohm Meter) and found 1.8K on the left side wheel and 1.9 on the right. Did the spin the wheel test and found small voltage on each.
I replaced them too. Still No Joy. I did take note when I bought the suv it had 235/15's on the rear and 205/15s on the front. I may be running in circles here.
Thanks
Rick
Old 11-27-2011, 06:11 PM   #11
SkyJumper
SW Florida
SkyJumper's Avatar
Vehicle Specs
Quoted: 0 Post(s)
Thanks
Rick
What is the middle number on the front and rear tire size?
If you are running 2 different size tires front and back, that should be the culprit there in itself, if the diameter is way off. The front sensors are reading one RPM and the rear VSS is reading another. You need the front and rear to be the same diameter in all. The sizes (width) can be different as many of us have done so in the past or present. But the overall diameter needs to be the same. This points directly to the 3rd bullet in the reasons I posted to you previously.
__________________
Old 11-27-2011, 06:49 PM   #12
Radioace318
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Think you may have hit the nail on the head here. Just went out to the garage to read the sizes of all the tires.
The front has 205/70/15s. The rear has 235/75/15s
Of course the front tires are doing more RPMs than the rear. This could be my problem. I have checked and changed everything I could think of.
Too bad my little Actron scanner did not tell me what all to look for. It was/is just reporting "Sensor A VSS malfunction.
Old 11-27-2011, 06:59 PM   #13
SkyJumper
SW Florida
SkyJumper's Avatar
Vehicle Specs
Quoted: 0 Post(s)
205/70/15= 26.3" height, section width 8.1", section height 5.7"
235/75/15= 28.9" height, section width 9.3", section height 7.0"
First set of numbers, 205 and 235 equals the width of tread in mm's
Second set of numbers- 70 (section height), equals 70% of the 205mm's tread width from rim lip or bead, to the top of the tire, 75 equals 75% of the 235mm's tread width from the rim lip or bead to the top of the tire.
Third set of numbers 15 is the rim diameter
The section width is the width from sidewall to sidewall.
The difference in both these tires is hugh when it comes to the ECU trying to compute what the VSS in the rearend is reading and the speed sensors up front are reading and the two are not compatible to one another. I bet that is your whole issue.
You need to get the same diameter matched tires for the front and rear, one way or the other. Like I said before, you can plus size tires, but the overall diameter needs to be relatively the same within a couple 16th's of a inch.
__________________
Old 11-27-2011, 09:50 PM   #14
drdoom
VA
Vehicle Specs
Quoted: 304 Post(s)
I read somewhere .25" is the tolerance, so that set is badly mismatched.
Old 11-27-2011, 10:22 PM   #15
Radioace318
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Dk Exp
wow! Just 0.25 to play with? Looks to me like just a low tire would flag the light in some cars. Should you have to use a do-nut spare in some cars would screw with your head.
Rick
Old 11-27-2011, 10:25 PM   #16
drdoom
VA
Vehicle Specs
Quoted: 304 Post(s)
A low tire doesn't change circumference much, if any.
Old 11-27-2011, 10:35 PM   #17
SkyJumper
SW Florida
SkyJumper's Avatar
Vehicle Specs
Quoted: 0 Post(s)
Rick
A donut spare is usually the same diameter as the original supplied tire on vehicle, it is just way skinnie and meant for low speed driving temporarily. It does not take much to throw off the VSS and speed sensors in order to throw a CEL. In your case specifically, the difference in diameter from front to rear is almost 3"s which equates to 1.5" in sidewall height. Which is hugh witha computer managed vehicle.
__________________
Old 11-28-2011, 11:43 AM   #18
hworksinc
East Lansing, MI
hworksinc's Avatar
2000 XLT
Vehicle Specs
Quoted: 1 Post(s)
Your mismatched tires are most likely the issue. For a minute, I thought you had the 5.0 AWD, in which case the mismatched tires would be an even larger issue.
I can explain why the code reader was unable to give you more detailed information. The ABS light being on is the key - this indicates codes are present in the ABS module, which cannot be read by a conventional code reader. If you attached a reader with ABS capabilities, you would most likely get an error in the format Cxxxx rather than Pxxxx. In your case, the problem is so bad that the ABS module is sending bad (or no) speed information to the PCM, thus triggering the P0500 code.
After resolving the tire issue, you should swing by Advance Auto Parts, or somewhere else that has readers with ABS capabilities and have the codes cleared (AAP is the only place in my area that has ABS capabilities on their free scanner).
__________________
[strike]Should I buy that Elite Membership...[/strike] I bought that Elite Membership!
hworksinc is offline   Reply With Quote
Old 11-28-2011, 12:15 PM   #19
joecrna
Las Flores, CA
98 XLT 4X4 sohc
Vehicle Specs
Quoted: 28 Post(s)
Finding a free scanner with ABS capability may be very difficult. Unhooking the battery for 20+ minutes may get the light to go out but the code should still be stored. Not that really matters.
That answer site gave you info for a pre 97 Explorer. As you have found, the speedometer/ABS rear sensor is combined on the rear third member.
__________________
Joe
98 XLT 4X4 sohc
TT, Custom Deaver leafs, 31x10.5 BFG's
Custom skid plates, recovery shackles
Defender rack, Warn transformer mount
and winch
joecrna is offline   Reply With Quote
Old 11-30-2011, 09:51 PM   #20
Radioace318
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Red Exp
Update:
New VSS on read end
Both front wheel speed sensors replaced with new ones.
All 4 tires & wheels are the same size now and all correct air pressure
Removed battery cables for over 6 hours in an attempt to reset all modules.
I recall what Joecrna said:
"I can explain why the code reader was unable to give you more detailed information. The ABS light being on is the key - this indicates codes are present in the ABS module, which cannot be read by a conventional code reader. If you attached a reader with ABS capabilities, you would most likely get an error in the format Cxxxx rather than Pxxxx. In your case, the problem is so bad that the ABS module is sending bad (or no) speed information to the PCM, thus triggering the P0500 code."
This seems to be correct. My Actron CP9135 code reader will only delete the P0500 vss malfunction error. It will NOT reset the ABS light or show ANY ABS codes at all.
I did verify all the wiring and connections are in good working order. (short of ohming out from the module to the sensor locations)
I did note today my auto door locks will engage the second I start moving. NOT when I shift from Park to Drive or Reverse. The suv HAS to be moving in order for this to happen. THAT tells me it is getting a sense of movement from somewhere. Could be the VSS or the WSS's on the front. I do not know for sure.
I also noted the am/fm radio DID NOT lose the memory even after the 6 hour absence of B+
So it is off to the local parts house with an ABS scanner to see what I learn from that.
Thank you all so much for your input. It is very appreciated.
Cheers
Rick
Reply
Tags
abs light, no speed o, vss, wheel speed sensor
Similar Threads
Thread Thread Starter Forum Replies Last Post
ABS Light On After Rain Clutchless1995 Stock 1995 - 2001 Explorers 2 04-16-2014 12:02 PM
abs light - hub zpaperboyz Stock 2002 - 2005 Explorers 11 04-25-2012 04:59 PM
how to turn ABS light off? Rich- Stock 1995 - 2001 Explorers 25 01-07-2011 11:59 AM
ABS Light rsilva708 Stock 1995 - 2001 Explorers 3 12-24-2008 05:47 PM
No ABS light but no ABS surf Under the Hood 5 11-13-2006 12:56 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
