Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Fuel Pump Relay, Power Dist. Box, '99
Reply
Thread Tools
Old 11-30-2011, 12:01 PM   #1
tclear4
Seattle
1999 Explorer Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
US Fuel Pump Relay, Power Dist. Box, '99
Hi everyone,
1999 Explorer Eddie Bauer 4.0L SOHC 134k miles
I've been having fuel pump issues of late, but it does not appear to be the fuel pump itself, as the problem is intermittant. It will occasionally turn over but not start (fuel pump silent), but it when it does, it runs flawlessly.
I've been told it may be the Fuel Pump Relay in the Power distribution box by the dealer. I've read that this lies in the #5 position within it. However this position has a narrower relay in it than the one given in the auto parts store. When I found the relay that matched it and replaced it, they said it was the Fuel Injection relay.
There are two relays that match the size given at the parts store, but these are listed as the PCM and Starter.
Any thoughts on this?
Thank you!
Here's the diagram sticky
http://www.explorerforum.com/forums/...d.php?t=180814
tclear4 is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-08-2011, 05:16 PM   #2
JusTheFaxMaam
Brandon, FL
'01 XLT
Vehicle Specs
Quoted: 0 Post(s)
You can swap the relay temporarily with another one in the box (I think the horn relay was the same type) I did this to test my fuel pump relay, since I seem to be having the EXACT same symptoms as you. In my case the relay didn't seem to help at all, still the same (and seems like it's doing it more often as time goes on)
Mine is a '01 xlt 4.0 SOHC
JusTheFaxMaam is offline   Reply With Quote
Old 10-22-2015, 11:00 AM   #3
TheRedBarron
1999 Ford Ranger XLT 4.0L
Vehicle Specs
Quoted: 0 Post(s)
did you...
ever get this resolved? I'm having problems with my 99 ranger ohv 4.0 of the same sort. ECM and FP relays are good. Im not getting power to the fuel pump (or the in line inertia cutoff switch for that matter), but it seems to get worse with time and when the temps are lower.
thanks in advance...
kenny
TheRedBarron is offline   Reply With Quote
Old 02-28-2016, 05:50 PM   #4
FriendGregory
Palo Alto, CA
1999 Ranger
Vehicle Specs
Quoted: 0 Post(s)
I was having every morning "no start" issues where it recovers with a turn ignition to accessory and back, it starts. I danced the relays next to the brake master cylinder and have only had one no start in 2 months but, the 4 wheel high / 4 wheel low started blinking. I need to find the map for the 99 Ranger relays.
FriendGregory is offline   Reply With Quote
Old 02-28-2016, 07:42 PM   #5
morbid81
Keller,TX
1998 5.0L AWD Eddie Bauer
Vehicle Specs
Quoted: 39 Post(s)
your owners manual should give the locations of all the fuse and relays both under the hood and in the cabin
__________________
1998 EX EB AWD 5.0. 157k. Tinted Windows. MAC Cold Air Intake. Clear Tails,Ford Steering Wheel Cover, 12k HID"S, Anzo Smoked Headlights, LED Interior and Exterior Bulbs,LED Reverse Lights, 10k HID Fogs,Seat Covers, Ford Logo Heavy Duty Floor mats, Bull Bar
morbid81 is offline   Reply With Quote
Reply
Tags
fuel, fuel pump, power distribution, pump, relay
Similar Threads
Thread Thread Starter Forum Replies Last Post
Need Help - Intermittent Fuel Pump at Start Up. '99 SOHC KC Under the Hood 26 02-08-2013 09:48 PM
ford manufacturer specific codes whale45714 Stock 1995 - 2001 Explorers 0 04-16-2011 10:03 AM
Fuel Pump has no power dreamin-on Stock 1991 - 1994 Explorers 13 01-17-2011 07:04 PM
Fuel pump relay. Roller2105 Stock 1991 - 1994 Explorers 2 10-07-2009 11:24 AM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
