EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
Upper ball joint keeps coming loose
Reply
Thread Tools
Old 12-01-2011, 06:18 AM   #1
nismotunedgtr
Windham, Maine
'93 XLT 250k miles
Vehicle Specs
(Original Poster)
Hey guys I replaced all the balljoints in my '92 4x4 about 6 months ago. 4 times now my steering gets all loose.
I've jacked it up and the upper ball joint alignment cam is loose in the I beam. The pinch bolt is always tight, I loosen it up and tap the alignment cam back down flush and tighten the pinch bolt.
It will stay tight for a month or so and the same crap happens....
Anyone have this problem? If so, whats the fix?
BTW --> I have the Moog adjustable camber bushings.
Thanks!
nismotunedgtr is offline   Reply With Quote
Old 12-01-2011, 07:01 AM   #2
gmanpaint
Torsion Bar Free
since 2010
gmanpaint's Avatar
94 XLT-95 FX4
Vehicle Specs
Replace the camber bushings.
__________________
The Black Hole
Pugly
gmanpaint is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Replacing Lower Ball Joints & Front Brakes Jerrym Stock 1995 - 2001 Explorers 5 05-13-2011 08:25 AM
Front upper & lower ball joint boots audioholic Stock 1995 - 2001 Explorers 6 04-13-2010 06:53 AM
Ball joint / upper CA part source? Avenger9 Stock 1995 - 2001 Explorers 2 02-12-2008 11:20 AM
Stranded - Upper ball joint from hell halo15 Stock 1995 - 2001 Explorers 6 08-25-2006 03:47 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
