| Modified 1995-2001 Explorers Questions related to modified 1995-2001 Explorer, Mountaineer, Ranger and 2002+ Sports (2dr). Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, torsion twist, lift kits, engine swap, transmission swap. |
Thread Tools |
#1 |
Wannabe Elite Explorer
North Florida
97 Sport
97 Sport, swapped in aluminum head 5.0 with small cam
I have swapped a 302 out of a 2wd 97 Mountaineer (that I added aluminum Y303 heads and a Crane 2031 to) into a 2wd 97 Sport.
I just got it started up today, but it is seeming to run like crap. |
#2 |
97 Explorer 06 Mustang GT
Cool Story Bro.
What ECU are you using, and do you have any sort of Tuner/Tuning software loaded onto it? __________________ 1997 Explorer Sport, FS: http://www.explorerforum.com/forums/...d.php?t=340534 2006 Mustang GT Convertible, 5 speed and loaded to the teeth. |
#3 |
North Florida
97 Sport
I am running the stock 97 5.0 Mountaineer ECU. Tuning none.
I am using the stock Sport underhood harness and alternator harness with the Mountaineer engine harness just plugged in. That shouldn't be a problem should it? I don't know if I let it idle long enough, but it seems that the temp gauge is not working. |
#4 |
Explorer ECUs don't take kindly to cams with an LSA of more than 114 degrees, otherwise check your fuel pressure and for CEL lights/codes.
#5 |
North Florida
97 Sport
What are the simptoms of too much cam?
#6 |
I had been told poor idle and rough running, but there are many things that can cause that. I just brought it up because those stock explorer ECUs cannot handle anything more than a very mild cam without a tune.
I can an mild CompCam in mine without issues Here are my cam specs, and they are about the max that an explorer ECU can handle:
__________________ 1997 Explorer Sport, FS: http://www.explorerforum.com/forums/...d.php?t=340534 2006 Mustang GT Convertible, 5 speed and loaded to the teeth. Last edited by dasfinc; 12-02-2011 at 09:46 AM. |
#7 |
North Florida
97 Sport
UPDATE: All is well now! I believe the problem was the lack off exhaust. All i had on it when I first started it was the headers. I bolted on the convertors and added a gallon of fresh gas and it runs fine now.
#8 |
North Florida
97 Sport
Oh, and the temp gauge does work too. And the V6 body and underhood harness.
The only issues with the swap now to be worked out is the tachometer needs to be swapped from the V8 truck, And I need to come up with a driveshaft solution. |
#9 |
Oregon,OH
1996 XLT - 347 V8
I read on here somewhere that you can use the stock V6 tach but 2 wires have to be changed in the wiring harness that plugs into it. There is a thread on here somewhere about how to do that. I'll look for it.
__________________ 1996 Explorer XLT Supercharged 347 w/ BW4406 Build Thread, 8000K HID Headlights and Fog Lights, Custom electric fans with painless controller, Stainless running boards, etc... 1999 Ranger XLT manual 2WD 3.0L (DD). Window visors, 35% front tint & 20% stock rear tint, 6000K HIDs, 96 explorer rims.. mostly stock 1997 Mountaineer (Swapped 4x4 4.0 OHV from my 96 Explorer) (Sold) |
#10 | |
Oregon,OH
1996 XLT - 347 V8
#11 |
North Florida
97 Sport
^ Thank you so much! I was just begining to think people don't like to help on this sight.
So I am guessing that swapping the cluster wouldn't have even fixed the tach? |
#12 |
Oregon,OH
1996 XLT - 347 V8
You are correct. The tachs for the V6's and V8's are the same part number
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Are you a redneck? | jjue | General Topic Polls | 132 | 04-18-2013 01:38 AM |
| Black Ox Solid Axle Swap 1991 | Randall | Explorer/Ranger Solid Axle Swap Registry | 36 | 03-04-2010 12:45 AM |
| Need some advice from you guys | Rage1973 | Modified 1995-2001 Explorers | 38 | 02-15-2006 01:52 PM |
| Is Bush A Moron?? | ld50 | General Topic Polls | 205 | 02-13-2005 06:24 AM |
| Thread Tools | |
