Go Back   Ford Explorer and Ranger Forums "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Windshield wipers do not work
Reply
Thread Tools
Old 12-04-2011, 03:32 PM   #1
bpasters
ND
1995 explorer eddie bauer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hello all. I have a 95 explorer 2 door that I have been having issues with the wipers on. I had a new multifunction switch put in and I'm on a newly refurbished GEM. The wipers only worked when it was warm out when I first got the car but now they don't work at all. The first GEM I had put in was at the recommendation of a mechanic that did all the diagnostics and determined that was the issue. After the first one the wipers worked for about two days then went out again. They did diagnostics again and said it must have been a bad GEM so I got a new one and they still don't work. I am going to go through all of the wiring with a tester this week and see if I can figure out where the issue is but thus far have had no luck. If anyone has had the same issue or if you have wiring diagrams from the wiper motor all the way through the GEM that would be appreciated. Wiper motor seems fine and it's not burning fuses so I'm not sure where the issue lies. The issue seems to be progressing as now my rear defroster does not work either but my rear wiper and washer work fine. Thanks again and I appreciate any help anyone can give.
bpasters is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-06-2011, 08:59 AM   #2
bobflood
Powder Springs, GA
1997 Eddie Bauer V8 2WD
Vehicle Specs
Quoted: 93 Post(s)
Excellent source for wiring diagrams.
Auto - Online Repair Info
http://search.ebscohost.com/
PW: rebsco
Select: Auto Repair Reference Center
Fill in: Find Your Vehicle
Follow prompts down to Wiring Diagrams.
__________________
1997 Ford Explorer, Eddie Bauer, 5.0L V8, 2WD, 295K+ miles, starting to show its age!
bobflood is offline   Reply With Quote
Old 12-06-2011, 12:07 PM   #3
moogvo
Hazzard County, NC
2001 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
Maybe a bad wiper module? Just guessin'.
__________________
this post contains artificial watermark. Hold at angle to view.
Tom Moog
2001 Ford Explorer Sport
Check out my vehicle gallery!
moogvo is offline   Reply With Quote
Old 12-08-2011, 08:27 AM   #4
rgaluzzi
Santo André , São Paulo
99´ Ford Explorer Limited
Vehicle Specs
Quoted: 0 Post(s)
Hello My friend!
I´m just buy a Ford Explorer Limited, and here comes with the same problem as a gift...
Try to see the relay box under the hood, in my Explorer the problem was a defective relay... i change them and voi lá! Problem Solved
rgaluzzi is offline   Reply With Quote
Old 12-10-2011, 09:00 AM   #5
bpasters
ND
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
update
I appreciate the help so far but still no luck. It's actually really strange. The wipers seem to work fine when the outside temperature (not the engine temp) is higher. I've now replaced the relays, checked all the fuses, replaced the GEM and still no luck. Can anyone think of a reason the wipers would only work when the outside temperature is higher? Thanks in advance for the help.
Old 12-10-2011, 09:29 AM   #6
budwich
Ottawa, Ont
96 XL
Vehicle Specs
Quoted: 0 Post(s)
Even though you seem to be getting some "diagnostics" from your "mechanics" that hopefully you haven't been paying for (or at least not the part "swap"), you likely have to "roll up your own sleeves" and do some measuring of the circuit to see what the electrical conditions are since it appears to be an electrical issue.... that way you are likely to find the problem and then you can address it directly. Check to see if there is voltage getting to the motor and there is a ground.... IF there isn't, then back track to see where it is stopping/not reaching (ie. which relay / wire).
IF you don't want to "roll up your sleeves", then get out your hair drier... :-) you have already stated what makes them work (heat).... go around and blow heat on things and see which item(s) like it... then "Bob's your uncle"... :-)
budwich is offline   Reply With Quote
Reply
Tags
gem, general electronics module, multifunction switch, windshield, wiper
Similar Threads
Thread Thread Starter Forum Replies Last Post
Wipers Won't Work rypp77 2001-2005 Explorer Sport Trac 1 07-16-2010 11:15 AM
2001 ranger Windshield wipers not working Jburdine Ford Ranger - Mazda B-Series Forum 1 01-13-2008 10:04 AM
Windshield Wipers not working at all... Please help quiksilverdh Stock 1995 - 2001 Explorers 2 12-02-2007 09:38 PM
Auto headlights - windshield wipers question x-ing Performance Lighting 2 03-12-2007 08:55 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
