Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Ford Explorer Sport Trac Forums > 2001-2005 Explorer Sport Trac
Notices
2001-2005 Explorer Sport Trac All questions related to the 2001-2005 Explorer Sport Trac model.
Clicker doesn't work and key entry sets off alarm 2001 Sport Trac
Reply
Thread Tools
Old 12-05-2011, 04:15 PM   #1
theshackle
Long Island
2001 Ford Sport Trac
Vehicle Specs
(Original Poster)
I have a 2001 Sport Trac. Today when I got up to drive to class my electronic clicker didn't work. With any other car this wouldn't be a problem but with my Sport Trac, the clicker is the only way to get in without setting off the alarm. The key pad on the door doesn't work, and using the key itself to get in doesn't work either. Once the alarm goes off it kills the ignition. I went out and got a new battery for the clicker but that didn't do anything. I'm the second owner, I believe the alarm is factory installed and not after market, but I'm not 100% sure.
I'm a college student and I don't have any of my tools with me at school, and I am far away from any reputable repair shops, not that it would matter since I can't start the truck as is. I'm having the spare key and clicker sent to me, but that could take a while, any tips or advice on how to remedy this problem in the meantime? Thanks a lot.
theshackle is offline   Reply With Quote
Old 12-05-2011, 04:38 PM   #2
OffTrac
Dublin, GA
OffTrac's Avatar
'01 Sport Trac 4x4
Vehicle Specs
Search for threads about finding keyless entry code; there's a few. Or is the keypad dead altogether? That would be more difficult but this is my first suggestion.
__________________
My Registry
OffTrac is offline   Reply With Quote
Old 12-05-2011, 04:44 PM   #3
theshackle
Long Island
Vehicle Specs
(Original Poster)
Quote:
I have the correct code, but it doesn't do anything so I believe the keypad is completely dead as well.
Old 12-05-2011, 04:51 PM   #4
OffTrac
Dublin, GA
OffTrac's Avatar
'01 Sport Trac 4x4
Vehicle Specs
Try disconnecting the battery for a while (be sure to leave the doors unlocked). Reconnect and try again. If the alarm isn't set when you lock the doors, you shouldn't have a problem using the key in the door.
That would be my next attempt and then I'd probably be waiting for the remote to arrive. Unless someone else here knows exactly how to solve it. I'm sure someone does.
__________________
My Registry
Old 12-05-2011, 05:00 PM   #5
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Welcome aboard!!
I don't know much about the Sport Trac. Having said that, let me toss out an idea.
When I got my '02 XLT 4-Door back in Feb of '10, if the alarm was armed and I pressed a key on the keypad it would set off the alarm.
It turned out to be a broken ground wire in the boot between the driver door and the body. This is a known issue on the third gens.
Hopefully someone with more knowledge about the ST's will chime in.
Good luck with the fix. Sorry I couldn't be more help.
__________________
Rondo - USMC, Combat Engineer, 1983-1996
Click here for a list of my write-ups!
Quote:
Originally Posted by FIND on 4-22-13
Don't mess with Boston. They will drop everything, hunt you down, and then go on like you never existed once they are done cleaning up the mess.
BigRondo is offline   Reply With Quote
Reply
Tags
alarm, clicker, sport, trac
Similar Threads
Thread Thread Starter Forum Replies Last Post
New Viper 2-Way Alarm Installed w/Pics pwscott Stock 2011 - 2014 Ford Explorer Discussion 6 02-04-2013 02:47 PM
DIY How to install a Remote Start Alarm Keyless entry System on a Explorer 1992 pachakutek Modified 1991-1994 Explorers 159 06-23-2012 02:49 AM
Homemade PATS key / PATS key repair techboj Under the Hood 1 02-03-2010 09:24 AM
'01 Sport - theft system but no alarm? john98225 Stock 1995 - 2001 Explorers 11 08-26-2008 08:42 PM
Need alarm that will work with my stock keyless entry trucku Stock 2002 - 2005 Explorers 18 04-07-2008 12:42 AM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
