#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Modified 1995-2001 Explorers
Notices
Modified 1995-2001 Explorers Questions related to modified 1995-2001 Explorer, Mountaineer, Ranger and 2002+ Sports (2dr). Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, torsion twist, lift kits, engine swap, transmission swap.
'96 Transmission Grinds
Reply
Thread Tools
Old 12-12-2011, 03:26 PM   #1
Caponetta
NJ
1996 Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
My 96 ex makes this horrible grinding sound from the trans. It only happens if I put the car in park, leave it running then switch to drive. The grinding lasts about a second and usually happens twice a few seconds apart. So far no issues changing gears, just this disconcerting noise. And ideas on what it could be?
Caponetta is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-12-2011, 04:02 PM   #2
dasfinc
1999 SOHC Exploder
Vehicle Specs
Quoted: 3 Post(s)
Quote:
Something that probably involves the transmission being removed from the vehicle...
__________________
2014 Mustang GT 300a
2013 Cooper S
1999 Explorer
dasfinc is offline   Reply With Quote
Old 12-12-2011, 04:07 PM   #3
Caponetta
NJ
1996 Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
That wasn't condescending.. Obviously removing it is involved, seeing if anyone is familiar with the issue.
Old 12-12-2011, 04:11 PM   #4
dasfinc
1999 SOHC Exploder
Vehicle Specs
Quoted: 3 Post(s)
There is no point in trying to diagnose something like that if the transmission has to come out, and be pulled apart anyways...
I've personally never seen a 5R55E or 4R70W Automatic make grinding sounds prior to failure. Slipping, slamming, lurching, surging, etc, but grinding sounds are more common to brake/differential problems.
Does it make this grinding sound after you go from park to drive even if you keep your foot on the brake? If it does, you've confirmed it is almost certianly a transmission noise, and which case there is probably some form of bearing or clutch pack failure occuring internally.
You need to include as many details as possible also in posts like these, that's why I was condesending.
I have no idea what your truck is (sport, or 4 door), what motor it has (4.0 OHC/OHV or 5.0), or what transmission it is...
I am also unsure what circumstance this sound occurs except for when you go from park to drive it briefly makes this sound (As in only while in the truck is in motion, or even while stationary), and you are stating there are no other symptoms.
Has the transmission ever been serviced? every been replaced? how many miles are on the truck? etc etc?
__________________
2013 Cooper S
1999 Explorer
Old 01-12-2012, 01:38 PM   #5
95LimtedExplorer
Oregon
'95 Limited
Vehicle Specs
Quoted: 0 Post(s)
Speaking of trans problems... I have a 4r55e that after warming up, when slowing down to 15mph, 1st gear drops out partially. If I brake torque it or shift into 2nd or 1st then back into drive it regains 1st gear. Transmission has 168k miles on it and has had only one fluid change.
95LimtedExplorer is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
EEC-IV 2 and 3 digit trouble codes. BrooklynBay EEC IV 16 03-26-2012 10:46 PM
96 Explorer 4R70W Transmission Problem CamDJClimited Stock 1995 - 2001 Explorers 5 05-14-2011 08:43 PM
ford manufacturer specific codes whale45714 Stock 1995 - 2001 Explorers 0 04-16-2011 11:03 AM
96 limited 4.0 transmission no 12v power issue asasial Stock 1995 - 2001 Explorers 1 07-27-2010 10:10 PM
96' Sport with a bad transmission. golden1972 Explorer & Ranger Transmissions, Transfer Cases, & Differentials 3 04-02-2010 03:13 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
