Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
1998 Explorer Trailer Lights
Reply
Thread Tools
Old 12-12-2011, 04:07 PM   #1
Gormy
Arena, WI
1998 Ford Explorer
Vehicle Specs
Quoted: 4 Post(s)
(Original Poster)
Hello everyone,
New to the forum. I have seen many posts for related probelms but not for the one I have. I have a problem that I just haven't been able to figure out in my hours of working on my explorer and several more hours searching the web.
I have a 1998 Explorer and I no longer have left brake/turn signal lights on my trailer (yellow wire). I have the adapter for the factory 4 pole to a four flat that has worked fine for two years, but for some reason it is no longer working. I tested the four flat adapter, as well as the four pole after disconnecting the adapter, with a volt meter and neither have any output from the yellow wire. I also used my brother-in-laws real nice tester and we confirmed that there is no power.
I check my owner's manual and there is only one fuse that it shows for the left trailer lights - a 7.5 amp fuse in the cab. I cannot find any other fuse inside or maxi/mini under the hood that controls this. Anyone have any ideas? I was going to jump it from my tail light (since the truck has 218,000 miles and I don't care if the repair is cheap and dirty at this point) but I don't think that will work since the brake light and signal bulb are separate. Any help would be greatly appreciated since I need this working for snowmobile season. Thanks!
Gormy is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-13-2011, 06:41 AM   #2
Gormy
Arena, WI
1998 Ford Explorer
Vehicle Specs
Quoted: 4 Post(s)
(Original Poster)
If anyone read this and is curious about it I found the problem. I've read several forums and I remember a few where people mentioned that Ford had accuracy issues with certain areas of their owner's manuals on Explorers, fuses being one of these areas. On mine the manual had the left and right trailer light fuses reversed in print from what they actually are in the wiring. My manual said fuse 3, when actually it is fuse 7 (Alldata/Mitchell on Demand has this correct in their information). Found the broken fuse and replaced it - all the lights work great. Hope this helps anyoen else having the same issue.
Reply
Tags
lights, trailer, wires, wiring
Similar Threads
Thread Thread Starter Forum Replies Last Post
Summary; 02-05 Explorer Trailer Wiring GCH Tow Rig Forum 23 04-28-2016 08:40 AM
.:: Ford Explorer Picture Challenge Game ::. FIND Exploring every thing under the sun!! 57 10-01-2015 11:09 AM
New Explorer owner with a question about trailer lights. MDP Tow Rig Forum 2 07-30-2010 02:26 AM
1998 Explorer Sport Issue with Hazards/Turning Lights jskill Stock 1995 - 2001 Explorers 0 07-19-2009 07:35 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
