| Stock 2006 -2010 Explorers Stock 2006 -2010 Ford Explorer Forum. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. |
Thread Tools |
#1 |
Wannabe Elite Explorer
louisville ky
2007
Trailer.. No power for tailights
I have an 07 explorer v8 4wd with the 4 prong blade only. I lost power to the tailights. I checked with test light to confirm. I have power for turn and brake just not the tailights. Tailights on the vehicle still work and i found no mention of this fuse location in the manual. Where does this get its power from?
Thanks Jason |
#2 |
New Castle, Delaware
2004 EB
Do you have power in the vehicle side of the 4-way plug? The brown wire on the trailer side plugs in opposite to the vehicle. I am not sure what the color is on the vehicle side. IF you do not have power on the vehicle side of the 4 way with just park lights on, then you may have a broken wire at the plug. The only fuse in the system is the one powering the vehicle. Skin the park light wire some where between the plug and the vehicle wiring harness and check for power....If you have power at the plug on the vehicle side, then skin the trailer park lights wire a few inches from the plug and check for power. If there is no power at that point you may have a broken wire on the trailer side of plug. Again no power-bad plug. If you have power a few inches from the plug, then your going to have to trace the brown wire to the nearest light. Personally would cut the 4 way off and go to a round plug.
#3 |
2004 EB
Haven't heard back from you, how did you make out with your wiring project.
#4 |
louisville ky
2007
I havent had a chance to check it yet. Wife gets back today i am going to check plug on vehicle side. I expect that to be it. It is the only thing that makes sence. I hope you are correct! I will post back my findings
thanks! |
#5 |
maywood, new jersey
2006 eddie bauer
trailer parking light fuse number 25 under driver side dashboard. 15 Amp. This is not the same fuse as the truck parking lamps, which i believe is # 26. Hope this helps you.
#6 |
louisville ky
2007
Ok obviously this was not a pressing issue for me. I dont pull trailer much and it is our extra vehicle thanks to gas prices. But I did need to get fixed!
I appreciate the help! I used check light to verify no power on either side of the plug. found out It was just a fuse and something i should have found in the book myself. Micheal liobi pointed me out to the fuse location for me that i overlooked in the book. I was looking for the word Trailer tail lamps. I should have spotted the park lamp listing instead.. Thanks again guys!! much appreciated!! |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 93 wiring harness woes - no power | kjhume | Tow Rig Forum | 3 | 07-06-2011 10:39 AM |
| No Power to Power Windows | Rkownurko | Stock 1995 - 2001 Explorers | 9 | 07-17-2008 10:54 AM |
| Installing new power sterring pump | old mechanic | Elite Explorer 911! | 8 | 04-07-2006 06:04 AM |
| No ACC power to new HU | aersloat | Explorer Audio & Navigation | 6 | 10-16-2004 05:24 PM |
| Trailer wheel bearings? | J. Kennedy | Exploring every thing under the sun!! | 7 | 07-13-2004 03:24 PM |
| Thread Tools | |
