Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Modified 1991-1994 Explorers
Notices
Modified 1991-1994 Explorers Questions concerning modifications to the 1991-1994 Explorer, Mountaineer, Ranger and Navajo. Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, lift kits, engine swap, transmission swap.
damn seat bracket torxs bolt wont budge
Reply
Thread Tools
Old 12-16-2011, 05:08 PM   #1
backfrmcolorado
Commerce Twp, MI
'94 Eddie B explodwhore
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Any easy way to get the torxs bolt out from the seatbelt slide on a 92x
__________________
1994 Eddie Bauer Explodwhore Grn/tan.
Nickname (GOLD DIGGER)
http://i985.photobucket.com/albums/a.../SUNP00381.jpg
1992 XLT Exploder 4inch lift w/31s
Nickname (Ticking Timebomb)
backfrmcolorado is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-16-2011, 05:12 PM   #2
Blacksheep Josh
Slinky+Escalator=Fun
Statesboro, GA
Blacksheep Josh's Avatar
'01 Ford Ranger, RIP 93 X
Vehicle Specs
Quoted: 13 Post(s)
Well... I'll tell you what I did...
I had to use a piece of pipe over my wrench handle, only then did it BARELY start to move...
__________________
I haven't been on this forum in a while and I'm trying to work my way back into it. I'm going for Mod or bust!
"Thunder" Registry R.I.P. 2005-2012
2001 Ford Ranger Edge 5.0L Swap Thread
1991 Nissan 240sx Drift Pig
Blacksheep Josh is offline   Reply With Quote
Old 12-16-2011, 05:20 PM   #3
reapereviltwin
Keep on wheelin John Rock
Jonesboro, Tx
reapereviltwin's Avatar
'92 Explorer
Vehicle Specs
Quoted: 51 Post(s)
Yep, had to use a cheater pipe.
__________________
HELL YES I'M AN AMERICAN. I HAVE SERVED MY COUNTRY, NOW I AM GOING TO SEE THIS LAND!!!
The "Dr. Jack"
http://www.explorerforum.com/forums/...d.php?t=257885
Demon4x4.com
reapereviltwin is offline   Reply With Quote
Old 12-16-2011, 05:23 PM   #4
Maniak
Moderator-Stock 91-94
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Quoted: 213 Post(s)
I used an impact gun and it worked on all except 1. The one that it didn't work on it ripped the welded bolt right from the body. I now have a bolt/nut holding that one corner down.
Use a very good torx bit, or it will bend/strip.
~Mark
__________________
Click HERE to see our Explorer Specs
Maniak is offline   Reply With Quote
Old 12-16-2011, 08:42 PM   #5
Jason94sport
South FL
93 Sport 2WD 5 speed
Vehicle Specs
Quoted: 49 Post(s)
I must be lucky. I never had a problem getting mine off on 3 X's. 1/2" socket worked fine.
__________________
1993 2WD Sport 5 speed
BBK TB, Flowmaster Force II Cat Back, CAI
Pioneer HU, Clarion speakers, RF R300 powered 10" sub
Jason94sport is offline   Reply With Quote
Old 12-16-2011, 08:48 PM   #6
tweakedlogic
memphis, tn
'92 XLT
Vehicle Specs
Quoted: 0 Post(s)
crawl under the truck and find where they go through, then spray liberally with Rust off or rust freeze. Let soak and do it again.
You can also use heat from the under side, but you have to be careful of catching the rug on fire.
__________________
2001 4x4 Sport Trac. 265/70/17 @ stock height. Engine coming soon.
1992 XLT 4 door (sold unfortunatly)_ 4WD: 32s on 17" Mustang GT rims, 4.56 w/ modified LS in rear, 2.5" lift from F150 coil springs, F250 shock mounts, shackles, Pro comp shocks, hard way rear disc conversion, Ported and polished intake, Dynomax exhaust, e-fan, + other mods I've done since this edit. (Switches, Black,)
tweakedlogic is offline   Reply With Quote
Old 12-16-2011, 08:49 PM   #7
4x4junkie
So.Calif.(San Fernando Valley)
'94 Ranger, '90 Bronco II
Vehicle Specs
Quoted: 3 Post(s)
Propane torch from underneath
Edit got beat by 1 min lol
__________________
'90 Bronco II XLT
5" lift (Skyjacker jeep coils), locked D35 & 8.8", 5.13s, double T-case, 35x12.50s & cut fenders
'94 Ranger XLT
6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s
4x4junkie is offline   Reply With Quote
Old 12-16-2011, 09:01 PM   #8
tweakedlogic
memphis, tn
'92 XLT
Vehicle Specs
Quoted: 0 Post(s)
Great minds Junkie
__________________
Old 12-17-2011, 12:51 AM   #9
FIND
Vermillion, SD
99 XLT V8 AWD
Vehicle Specs
Quoted: 10 Post(s)
Like tweaked said. Lube from underneath. I like a 50/50 mix of acetone and ATF for freeing up stuck bolts and nuts. I'd get nervous about a cheater bar, I can twist heads off bolts pretty easy.....
__________________
I strongly abide by the motto, "Safety third."
Quote:
Originally Posted by NICE59FORDF100 View Post
Dont forget numbers. Teacher Ladies LOVE numbers
FIND is offline   Reply With Quote
Old 12-17-2011, 09:46 AM   #10
backfrmcolorado
Commerce Twp, MI
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Welll i got the slide bars off...the bolts are still there. I kinda got pissed off and just to a die grinder and air hammer to them. Im just going to drill new holes then reinforce it with big washers from under truck and inside.its not going to be a big problem for now since it will be a few weeks untill it gets plated and i get the engine tick figured out. ( just picked the truck up two days ago for $700...kinda a work in progress...)
__________________
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
