Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
4X4 High Light Flashing
Reply
Thread Tools
Old 12-17-2011, 12:45 PM   #1
Magnatek
IN
2003 Ford Explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I am working on my girlfriends 2003 Explorer XLT. We replaced the transmission and on the test drive after the re-install the 4X4 High light in the dash flashes about 5-10 times every couple of minutes. The buttons on the dash (4X4 auto & high) don't do anything when pressed and the 4X4 low button just flashes 10 times or so when you press it. So, no 4 wheel drive.
We did disconnect the battery cable during the process and I am wondering if that blew the module behind the glove box? I searched the forums and it seems that it may be the cause. Can anyone verify this, or have any other ideas? Thanks for your time.
Magnatek is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-26-2011, 01:01 PM   #2
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
Welcome aboard!!
It's hard to say what the issue is. The only way I know to know for sure what the problem is, besides throwing parts at it until it is fixed, is to get the codes read at the dealer.
I recommend checking all the connections on the the transfer case motor. When my 4x4 lights were flashing, and I had no 4x4, it turned out to be a bad ground on the transfer case motor. I replaced the 4x4 control module and the switch before the bad ground was discovered.
Good luck with the fix and be sure to keep us posted.
__________________
Rondo - USMC, Combat Engineer, 1983-1996
Click here for a list of my write-ups!
Quote:
Originally Posted by FIND on 4-22-13
Don't mess with Boston. They will drop everything, hunt you down, and then go on like you never existed once they are done cleaning up the mess.
BigRondo is offline   Reply With Quote
Old 12-27-2011, 10:24 AM   #3
Magnatek
IN
2003 Ford Explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks for the reply. We test drove it right away after the re-install and that's when the problem developed. We put it back on the lift right away and found the ground wire you are talking about corroded and broken. I soldered on a new connector and hooked it back up. The problem was still there. After about 1 day, it stopped flashing and the button (4X4 high) started working, at least the light on the dash came on when the button was pressed. I tried to get it into low but nothing worked. I assume this means at least the high is working? When you press the 4X4 auto button, the high light goes off in the dash. Does that sound correct?
Old 12-27-2011, 10:39 AM   #4
jaydez
Hartford County, CT
2005 XLT V6 4x4
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Did you put the transmission in neutral, set the parking brake and press and hold the 4x4 low button?
__________________
Jay
2005 Explorer XLT "Sport" 4x4
Apexcone 4300k HID Kit|Airbox Mod|4th gen heated mirrors |Fusion Key|Nitto Terra Grappler AT 265/70R17|Dorman heated seats
jaydez is offline   Reply With Quote
Old 01-10-2015, 07:25 PM   #5
szeiger
Olmsted Falls, Ohio
2003 Ford Explorer Eddie
Vehicle Specs
Quoted: 0 Post(s)
I know the threads are a little old but: Had the same problem with the 9 flashes, did the module swap, negative lead off the battery, etc. and it turned out, as some had post, a bad negative cable. But, this one comes out of the harness and grounds to the transfer case, not from the transfer case to the frame.
I would not have seen it except I decide to remove the transfer case shift motor to bench test it/clean it up. Saw it, spliced it, replace the motor, grounded the spliced cable and back in business.
szeiger is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
OBD-II Diagnostic Trouble Codes (DTCs) BobWiersema EEC V 8 03-26-2013 10:22 PM
4x4 high light is flashing. kevinm1031 Explorer & Ranger Transmissions, Transfer Cases, & Differentials 1 01-03-2011 09:51 PM
4X4 High Flashing dkingcan Stock 2002 - 2005 Explorers 4 12-23-2010 10:06 PM
ABS light is on constantly, but the 4x4 light is flashing. Mr_norm Explorer & Ranger Transmissions, Transfer Cases, & Differentials 3 12-30-2009 10:10 PM
That Damn 4x4 Flashing light problem... WiTcHDoKtoR Under the Hood 3 06-05-2002 07:21 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
