Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Location of ABS sensors
Reply
Thread Tools
Old 12-18-2011, 04:12 PM   #1
leftlane36
maynardville tn
2003 explorer XLT 4X4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I was wondering if any one has Pics or diagrams on where the ABS sensors are located on the front end of an '03 4 wheel drive. I have located the rear. Please any help would be greatly appreciated. RONDO HEEEELLLLPPPPP!!!!!!!!!!!!
__________________
2003 Ex 4.0 auto 4x4auto. Hunter green Stock with 265/75/16 Kellys wrapped around stock wheels
leftlane36 is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-18-2011, 04:18 PM   #2
EXPLORER04
Buffalo, NY
04 XLT
Vehicle Specs
Quoted: 28 Post(s)
It is located in the front hub assembly, #3 on diagram
EXPLORER04 is offline   Reply With Quote
Old 12-18-2011, 04:24 PM   #3
leftlane36
maynardville tn
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks '04 I have been racking what little brain this ex has left me with looking for it.
__________________
Old 12-18-2011, 04:49 PM   #4
EXPLORER04
Buffalo, NY
04 XLT
Vehicle Specs
Quoted: 28 Post(s)
Quote:
Just be careful if you have to remove them. Since they are considered part of the hub assembly they have locktite on them and may break.
Old 12-18-2011, 04:50 PM   #5
leftlane36
maynardville tn
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
ANy secrets on getting them out easier or is it just take time a do it slowly
__________________
Old 12-18-2011, 06:23 PM   #6
SyberTiger
Orlando
2002 Limited 4x4
Vehicle Specs
Quoted: 7 Post(s)
I've heard several people say they had planned to re-use them when they bought new wheel bearing hub assemblies that did not include the sensor. Apparently, they are either hard to get loose or they are brittle because of the comments about them breaking when trying to remove them. However, it you are replacing the ABS sensor then maybe you don't care if you break the old ones. On that note, if you have a bad ABS sensor be prepared to pay within $40 or $50 bucks of what a complete wheel bearing hub assembly would cost including with a new ABS sensor. I was recently quoted around $128 for an ABS sensor by itself versus $170 for a brand new wheel bearing hub assembly that included a new sensor. Lastly, if you are trying to replace a "bad" ABS sensor because you think it will make the ABS idiot light turn off keep in mind that the sensor could actually be good but the wheel bearings are so worn out that the ABS sensor can not register properly.
__________________
2002 Ford Explorer 4x4 Limited
P275/45R20 on 20" Rims
SyberTiger is offline   Reply With Quote
Old 12-18-2011, 06:36 PM   #7
leftlane36
maynardville tn
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I have just installed new bearing on the front and about 3 weeks later is when the light came on. Some one told me that maybe something got on one of them and that may be what is causing the light to come on. That is the reason I am wanting to check them. I figure if it is not to big of a deal I would try to check them and see if that is in fact the problem. If not I will see what else comes up. This thing will be the death of me. Dodge would have been but I got rid of them, best thing I ever did.
__________________
Old 12-18-2011, 06:40 PM   #8
SyberTiger
Orlando
2002 Limited 4x4
Vehicle Specs
Quoted: 7 Post(s)
I assume it is throwing an ABS sensor code for the front left or right sensor?
__________________
Old 12-18-2011, 06:55 PM   #9
leftlane36
maynardville tn
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Havent had the code read just funny that it started right after bearing change
__________________
Old 12-18-2011, 06:59 PM   #10
SyberTiger
Orlando
2002 Limited 4x4
Vehicle Specs
Quoted: 7 Post(s)
Could be the rear ABS so a stop at AdvancedAuto or AutoZone to get the ABS codes will help you get closer to the problem. Let us know what codes you have when you get a chance.
__________________
Old 12-18-2011, 07:05 PM   #11
leftlane36
maynardville tn
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
OK I am gonna try to get to it tomorrow, garage is occupied with the 87 ranger right now. A man and his toys never get rest
__________________
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
6mm bolt location on the front ABS sensor. brians63 Stock 1991 - 1994 Explorers 8 07-16-2011 12:32 AM
Front ABS Sensor Location 03_Black_EB Stock 2002 - 2005 Explorers 3 06-13-2010 06:57 PM
Front ABS sensors 97sprt4x4 Stock 1995 - 2001 Explorers 3 02-06-2009 08:19 PM
abs sensors peter freeman UK Explorer Owners Forum 2 06-28-2008 03:43 PM
Rear ABS sensor location IZwack Offroad Drivelines 16 08-30-2006 10:35 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
