Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2011 - 2014 Ford Explorer 5th Generation Explorer > Stock 2011 - 2014 Ford Explorer Discussion
Notices
Stock 2011 - 2014 Ford Explorer Discussion 2011 - 2013 Ford Explorer problem solving, maintenance, TSB, service bulletins, owner reviews, specifications, Ecoboost.
Courtesy lights
Reply
Thread Tools
Old 02-01-2012, 11:45 AM   #21
ExploreThis2012
2012 Limited
Vehicle Specs
Quote:
Originally Posted by Hunter32 View Post
if you think about it, all you would need to do is find the switch inside the door that turns the lights on when you open the door. Once you find that switch, add a separate switch in the circuit that can disable/enable the lights to turn on.
Seems simple enough but i havent checked my X to see if its possible.
You would have to check, but the dome lights may have a separate fuse. If so, you could easily wire a switch in series with the fuse and then be able to turn the lights off from a switch installed on the lower dash.
__________________
Best Thread Subject I've seen so far:
my Ex has developed the phantom wipe
ExploreThis2012 is offline   Reply With Quote
Old 02-01-2012, 11:54 AM   #22
cnsheets
Anaheim, California
11' Explorer
Vehicle Specs
Our 2001 explorer has the dome light switch tied into the door latch mechanism in the door.
cnsheets is offline   Reply With Quote
Old 02-01-2012, 04:55 PM   #23
VinceL
Spring, TX
2013 Explorer Limited
Vehicle Specs
If I read the 2012 owners manual correctly, this is all on one fuse:
Interior courtesy lamps (overhead console, 2nd row, cargo), Puddle lamps, Console bin LED, Backlighting
And this is on another:
Interior demand lamps (overhead console, 2nd row, cargo), glove box lamp, 2nd and 3rd row seat release, visor lamps
Decipher away....
__________________
We just bought American!
She got the 2013 Ex
Meet the Gray Ghost HERE
Check out the Gray Ghost on Fuelly.com
Average Mileage: 21.3
Best Tank: 26.5
VinceL is offline   Reply With Quote
Old 02-02-2012, 12:25 PM   #24
gpzrider
Los Angeles, CA
2012 Limited 4x4
Vehicle Specs
Being the master of the cheap fixes, I simply put a piece of black electrical tape over the light. My wife sits back there with our baby and pulls it to expose whatever amount of light she wants. It would always wake up our baby when I opened the doors. Now sleeps like a champ.
gpzrider is offline   Reply With Quote
Old 02-02-2012, 12:34 PM   #25
peterk9
Toyota Highlander Convert
Ottawa, Ontario area
peterk9's Avatar
2011 Limited AWD
Vehicle Specs
Quote:
Are you planning on taking out a patent on all these fixes.
__________________
Peter Explorer Limited White Platinum Tri-Coat,340A (Rapid Spec 302A).
Previous rides;'99 Windstar; '02,'06 & 09 4WD Toyota Highlander Limiteds
peterk9 is offline   Reply With Quote
Old 02-02-2012, 12:34 PM   #26
cnsheets
Anaheim, California
11' Explorer
Vehicle Specs
Maybe you should look into a new baby that is less light sensitive.
Old 02-02-2012, 05:44 PM   #27
VinceL
Spring, TX
Vehicle Specs
What can't you do with a little electrical tape?
__________________
She got the 2013 Ex
Best Tank: 26.5
Old 03-07-2012, 09:10 PM   #28
uncledub
Alabama, USA
uncledub's Avatar
2002 XLT
Vehicle Specs
Ever consider painting the light bulbs red? works well in conditions where you do not want your night vision disrupted.
uncledub is offline   Reply With Quote
Old 03-08-2012, 12:19 AM   #29
NAYDAMO
2011 FORD EXPLORER XLT
Vehicle Specs
Another reason not to have kids... I'm kidding of course, I like that idea painting the light red or blue....
NAYDAMO is offline   Reply With Quote
Old 04-06-2012, 01:26 PM   #30
Brad1976
2002 Eddie Bauer Explorer
Vehicle Specs
My Explorer is an '02. Unless it's something that they're taken away a decade later for yours Fred163, I have the dial / dimmer for the dash lights. If I dim the dash lights as low as they can go and then continue turning the little dial lower until there's a little light click, then all of the interior lights will be completely off, regardless if the vehicle is on / off, doors are pen / closed or any combination there of... They're just completely off... In order to turn them back on, simply turn the dial for the dash lights back up.
Wish I saw this earlier for you and good luck!
Brad1976 is offline   Reply With Quote
Old 04-06-2012, 02:08 PM   #31
peterk9
peterk9's Avatar
2011 Limited AWD
Vehicle Specs
Won't work on the new Explorers. No way to switch them off. I have no idea what the thinking was behind that. Perhaps the next model will have a $200 option to turn off interior lights.
__________________
Old 04-06-2012, 10:07 PM   #32
Brad1976
Vehicle Specs
Man what a busy day... This thread sounded familiar and didn't realize I already replied to it... ROTFLMAO
Old 04-08-2012, 12:36 AM   #33
Spengracin
Fairfield, Ca
2012 AWD Limited
Vehicle Specs
That's it, an option, rts make it a 400.00 option, it will take engineers awhile to figure this out.
__________________
2012 Limited EX. Tri-White plat. Dual panel sun roof, 302a package, bliss, pecan interior, 20" polished aluminum wheels, tow package, cross rails for roof rack, Aries Stainlees Nerf bars, upgraded LED interior lighting.
Spengracin is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
2002 Ford Explorer XLT -- side mirror courtesy lights don't work. jjetta1170 New Member Forum 3 11-14-2012 12:50 AM
Puddle lights don;t work w/ courtesy lights jjetta1170 Stock 2002 - 2005 Explorers 12 01-13-2012 08:56 PM
LED Lights in Insturment Cluster (Pics inside) King$nake Stock 1995 - 2001 Explorers 24 03-02-2010 07:05 AM
Custom tinted lights with designs diesel_s Body Work & Detailing 2 01-09-2009 10:54 PM
Auxillary Reverse Lights! taxx Performance Lighting 5 06-30-2001 12:28 AM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
