Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
steering problem
Reply
Thread Tools
Old 12-25-2011, 11:05 AM   #1
posmindset
02, Explorer 4.6L 4x4
Vehicle Specs
(Original Poster)
steering problem
My power steering on my 02 eddie bauer EX is hard to turn to the right sometimes. It is spotty, it will turn to the right smooth sometimes and have moments when the roughness is spotty.
Turning to the left is fine.
Check the power steering fluid, it was low, so i have filled it and the steering got a little better but the problem is still there.
Reading threads in here it sounds like i need to replace the rack and pinion.
With what i'm describing above does that sound like a possible solution or might there be something else?
Can I change the rack and pinion myself and if not what would it tyically cost to have it fixed???
Happy Holidays/Merry Christmas and thanks for any advice and help.
posmindset is offline   Reply With Quote
Old 03-21-2012, 10:50 AM   #2
posmindset
Vehicle Specs
(Original Poster)
I have noticed with this problem that if sitting in park and i turn the steering to the right and rev the engine (give it gas) the steering will turn easier to the right like it should.
Does that sound like a power steering pump could be going out?
Curious as to why the steering would be hard only to the right and not any direction i steer.
Old 03-21-2012, 12:05 PM   #3
jaydez
Hartford County, CT
2005 XLT V6 4x4
Vehicle Specs
How low was the fluid? You might have air in the system and it needs to be bled. It's easy to do. you just turn the wheel full lock in each direction a couple of times then check the fluid level. It might take a few cycle to get the air out.
If that doesnt fix it, you prob need a new steering rack.
__________________
Jay
2005 Explorer XLT "Sport" 4x4
Apexcone 4300k HID Kit|Airbox Mod|4th gen heated mirrors |Fusion Key|Nitto Terra Grappler AT 265/70R17|Dorman heated seats
jaydez is offline   Reply With Quote
Old 03-21-2012, 12:29 PM   #4
posmindset
Vehicle Specs
(Original Poster)
The fluid is at the right level. I added some a couple of months back when this problem started as it was slightly low and did just as you described by turning the wheel back and forth both ways for complete revolutions...that didn't solve the problem.
Reply
Tags
power steering, rack and pinion, steering wheel
Similar Threads
Thread Thread Starter Forum Replies Last Post
Project X = Power Steering with AGR Pump Tbars4 Under the Hood 111 12-11-2012 09:43 AM
Steering problem kona_mtb Stock 1991 - 1994 Explorers 1 12-27-2010 11:03 PM
Power Steering Problem rocco01 Stock 1995 - 2001 Explorers 0 06-01-2007 09:13 PM
Help! Major steering problem! ncc Stock 1995 - 2001 Explorers 4 06-19-2006 11:14 PM
Diagnose 93 Steering Problem cvxmike Stock 1991 - 1994 Explorers 6 03-05-2006 11:49 AM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
