The 0.061-0.068 gap comes from the Ford OEM Service DVDs for 2003, 04 & 05, for the 4.0L Explorer, Explorer Sport-Trac, Mountaineer & Ranger, originally equipped with the Motorcraft AGSF22PM plug. Interestingly, in 2005, the Mustang started using the same 4.0L engine. In that application, the engine was equipped with the AGSF24N plug (a hotter plug). The gap on the DVD is shown as 0.052-0.056 in.
Through 2002, all 4.0L SOHC plugs, according to the Ford DVDs, are gapped at 0.052-0.056, using AGSF22PP plugs as replacement plugs.
The 4.0L SOHC is a waste spark engine, which uses slightly different plugs on the left & right banks.
Replacement plugs are usually double platinum, suffixed PP so they can be
used on both banks.
On the 2006 and later Ford DVDs, all 4.0L SOHC plugs are gapped at
0.052-0.056 in.
On the Ford OEM parts site, the AGSF22PM plug isn't listed. The replacement
plug for 2003-05 4.0L engines is the SP400, which is shown as having a gap
of 0.052-0.056 in.
The sites for Autolite, Champion and Bosch all list replacement plugs, for
those years as having a gap of 0.054 in.
Bottom line, it looks like the original plugs in the 2003-05 engines, except
for the 2005 Mustang, were gapped at 0.061-0.068 in. Replacement plugs,
regardless of manufacturer, are gapped at 0.052-0.056 (0.054), regardless of
electrode type (iron, copper, platinum, double platinum, or iridium.
