| 2007 - 2010 Explorer Sport Trac All questions about the stock 2006- 2010 Ford Explorer Sport Trac. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Plattsburgh, NY
2010 STA Supercharged
Update on 08-10 STA Drop Springs.
I have been slowly getting some drop springs ready for production for RWD and AWD Sport Tracs.
I've done a 1.5" and a 2.0" for AWD only so far. This is a pretty damn expensive project and I'd like to sell some of the prototypes as I'm putting the project on hold until spring. http://www.explorerforum.com/forums/...93#post2873093 __________________ 2010 Ford Sport Trac Adrenalin 4.6L V8 AWD SOS COP 31850, Magnaflow 14236, DMH E-Cutout, SCT Xcal3 ECM Brenspeed Dyno Tune & TCM Tune By Torrie @ Unleashed, Saleen VI.5 Supercharger Conversion by Brenspeed 400RWHP 386RWTQ! |
#2 |
southern California
07 Sport Trac Limited V8
You had stated before that the springs are 15% ( I believe thats the amount ) higher rate over stock. Do you actually know what the rate is?
__________________ 2007 Limited 2wd w/V8 , 20 x 9 Shelby CS40 wheels - 265/50/20 Toyo Sport Truck II's, Brenspeed tune for K/N CAI, Fabricated exhaust - 2 1/2" from cats to single 3" with Magnaflow #12578. Zabtek throttlebody, Comp Cams #127100 ground with different lobe separation. Bilstein 5100 coil over dampers and Eibach springs. Newly installed 14" GT500 rotors and Ford "GT" brembo calipers. Next project fitting Coyote tubular manifolds and cats... Then to Brembo rear calipers and 14" rotors!!!
#3 |
Plattsburgh, NY
I can look up the exact rate but they are engineered to be 15% stiffer. I was not planning on publishing all the stats. I consider all of this propriatary information.
#4 |
southern California
The reason I wanted to know is because of the dampers I am having built. The factory ones are insufficient at best on rebound for the stock springs. I would like to know either the stock rate or your aftermarket springs in order to figure out the valving rates. If I can't get the info I can not buy them.
#5 |
Plattsburgh, NY
Front: 475#/in
Rear: 310/400/in The springs I have made now are setup for an AWD so I don't think you wil get the full drop benifit with your RWD. In the process of doing up a RWD 2.0" drop now. __________________ 2010 Ford Sport Trac Adrenalin 4.6L V8 AWD SOS COP 31850, Magnaflow 14236, DMH E-Cutout, SCT Xcal3 ECM Brenspeed Dyno Tune & TCM Tune By Torrie @ Unleashed, Saleen VI.5 Supercharger Conversion by Brenspeed 400RWHP 386RWTQ! |
#6 |
southern California
Thanks for the rate info. I presume the rear is a progressive rate. The problem lies in my quick on vehicle loaded measurements and specs from Monroe. A drop of 1" in the front is almost compressing the damper to near full compression. Hense no travel at ride height... I am working on a swap from an F150 for the front and possibly the rear also. I have the damper rates from Bilstein now. What differences do you see for rates between the AWD and RWD? Dampers are the same right? I have not been able to find any differences as of yet.
#7 | |
Plattsburgh, NY
Quote:
I can only assume that the dampers are the same for both vehicles as their suspension travel is the same. The only difference being weight in the AWD versus RWD variants. The rear springs on the RWD and AWD are the same part number from what I can tell. The fronts are different though. __________________ 2010 Ford Sport Trac Adrenalin 4.6L V8 AWD SOS COP 31850, Magnaflow 14236, DMH E-Cutout, SCT Xcal3 ECM Brenspeed Dyno Tune & TCM Tune By Torrie @ Unleashed, Saleen VI.5 Supercharger Conversion by Brenspeed 400RWHP 386RWTQ! |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Questions about Navajo rear leaf springs | brisray | Modified 1991-1994 Explorers | 1 | 08-14-2008 09:10 PM |
| SAS Coil Springs | rguy | Explorer - Ranger Shocks, Suspensions, Lift Kits | 2 | 04-01-2008 05:32 PM |
| TTB springs too stiff. What else is there? | rguy | Modified 1991-1994 Explorers | 7 | 05-10-2007 12:58 PM |
| Drop leaf springs | Hartman | Seriously Lowered Explorer - Ranger Suspension Tech | 11 | 07-03-2002 09:04 PM |
| 98 Drop options | Bumpin97Ranger | Seriously Lowered Explorer - Ranger Suspension Tech | 4 | 05-02-2002 05:32 PM |
| Thread Tools | |
