| Stock 2011 - 2014 Ford Explorer Discussion 2011 - 2013 Ford Explorer problem solving, maintenance, TSB, service bulletins, owner reviews, specifications, Ecoboost. |
Thread Tools |
#1 |
Wannabe Elite Explorer
NJ
2012 Explorer Base
Cracking noise when heater is on
I have a 2012 base and it seems when the heater is on around every 15 minutes I get a cracking sound similar to the sound of having a rock/pebble hit the windshield.
I sat in a parking lot trying to isolate the location. It is located behind the radio, heater controls area. Does anyone else have this strange cracking noise? Thanks, |
#2 |
12 explorer
I've got the same issue here on my 2012 xlt without the MFT and I can't seem to pinpoin the location either and its driving me crazy!!!!
#3 |
Minnesota
2012 Ford Explorer Base
Hey,
I have a 2012 Ford Explorer base that has this same cracking noise. I was told today by the service department when I brought it in... "The noise that you are hearing is the heater going in to sleep mode, and is normal" They were able to re-create it using my instructions: turn the car on - put the heater to medium settings and drive with it. So that is the answer I got! |
#4 | |
12 explorer
Quote:
#5 | |
Minnesota
Quote:
I also had it in today because water is held in the doors. Example: If I get the car washed on Friday and wait a week, then roll the windows down and back up, they are still covered with water and streak, and then dry with a film on the window, requiring you to clean it every time you use your window. the dealer also told me that "This is perfectly normal with this car" wonderful. |
#6 | |
12 explorer
Quote:
#7 | ||
Official Ford Rep
Dearborn, MI
I’m sorry I missed this thread before, BruceF. I wanted to check in with you to see if you’re still hearing the noise. If so, I can help by forwarding the info to the Customer Service Manager in your area. Be sure to shoot a PM with your VIN, contact info, mileage, and dealer name/state.
Quote:
Quote:
Cory __________________ FORD SERVICE p: 800.392.FORD t: @FordService @Ford f: facebook.com/FordExplorer facebook.com/Ford |
#8 | |
Toronto, Ontario
Limited 2012
Quote:
#9 |
12 explorer
i wonder if everyone has this problem. as long as i document it at the dealership that i complained about it, and ford states this is perfectly normal, if it does get rusty over time, that's on them to have to fix/replace parts or whatever....
#10 | |
Minnesota
Quote:
When asked about corrosion, they said "Well that is why you have a corrosion warranty of course!" (they are talking about the 5 year warranty) So there you have it. It's a 5 year car. |
#11 |
Fairfield, Ca
2012 AWD Limited
Not normal
__________________ 2012 Limited EX. Tri-White plat. Dual panel sun roof, 302a package, bliss, pecan interior, 20" polished aluminum wheels, tow package, cross rails for roof rack, Aries Stainlees Nerf bars, upgraded LED interior lighting.
#12 |
NJ
2012 Explorer Base
The cracking poping sound is not normal. This is just typical Ford BS. Some unknowledgeable customers accept it, but I will not give up.
If the A pillars are happening on most of the Explorers this should also be seen as normal, but enough people complained, and they fixed the problem. I have a second appointment on Monday for a second evaluation after they replaced the Front Control Panel one time. The cracking popping sound is a lot more annoying then the buzzing that I was getting from the A-pillars. Stand up to Ford to get this problem resolved. |
#13 | |
12 explorer
Quote:
#14 |
NJ
2012 Explorer Base
MTZ,
I will keep the group updated as I continue to go through the process. Please do the same. Jonredcorn, Take some time to think about what the dealer told you. "The noise that you are hearing is the heater going in to sleep mode, and is normal" Should we expect this when the A/C goes into sleep mode as well? What other modes should we expect cracking poping sounds when our cars decide to go to sleep. Do not let them take you for a fool. You work hard for your money and spend it wisely and expect a product to perform correctly. Ford braggs how quiet the car is. Well to me, cracking poping sounds is not very quiet. |
#15 |
NJ
2012 Explorer Base
Went to the dealer today for the cracking popping sound coming from the FCIM.
The dealer called Ford engineering, and the engineering group asked the dealer to test like vehicles. The dealer drove two brand new base models. 3 hours later.... Well it seems that base models were designed to make cracking popping sounds when the heater is on. Can you imagine. It is not over. |
#16 | |
12 explorer
Quote:
#17 | |
Minnesota
Quote:
The problem is - I don't know what else we can do. I will keep bringing it up every time I bring it in for service, but if it's supposedly a "normal" thing, the best I believe we can do is: 1) Let others know who are considering purchasing this vehicle. 2) make sure that there is a record of it so in case of failure, you are able to prove that this was malfunctioning before the warranty was up. I am open to any other ideas, but I think we might be stuck. How did the A-Pillar issue become prevalent enough to warrant a TSB?
#18 |
NJ
2012 Explorer Base
MTZ,
I believe that you were going to take a test ride with the dealer today concerning the Popping/Cracking sound coming from the FCIM when the heat is on. Any luck? Bruce |
#19 |
12 explorer
going to the dealer to pick it up tonight. I had to wait for parts for the TSB roof fix. I should get the complete run down of things today. Will keep things updated.
#20 |
12 explorer
Update on the noise from the dash...they couldn't reproduce it. 5 minutes out of the dealer, I heard again. So I'm back square 1 and I guess I'll have to make alternate arrangements and bring it back in. so frustrating on a $35K truck.
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| TSB's, Where to get them free? | nevr1zenuf | Under the Hood | 16 | 11-15-2012 01:30 PM |
| What makes a grinding noise like a bad wheel bearing other than a wheel bearing? | jayton | Stock 2002 - 2005 Explorers | 23 | 09-23-2012 10:18 AM |
| Front end noise | Ford5.0V8 | Stock 1995 - 2001 Explorers | 7 | 11-04-2010 11:03 PM |
| 1991-1994 Heater Core Replacement Diary | Glacier991 | Explorer, Ranger, A/C & Heater systems HVAC | 1 | 05-03-2006 01:16 AM |
| 1991-1994 Heater Core Replacement Diary | Glacier991 | Technician's Tips and Tech | 1 | 04-28-2006 08:33 PM |
| Thread Tools | |
