Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Aerostar Tech Forum > Aerostar Forum
Notices
Aerostar Forum The Ford Aerostar shares a lot of common parts with the Ford Explorer. Besides that a lot of our members own an Aerostar and an Explorer.
What's the difference between Mercon and Mercon V transmission fluid?
Reply
Thread Tools
Old 01-07-2012, 12:29 PM   #1
speleopower
cocoa bch
1997 Aerostar
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Question What's the difference between Mercon and Mercon V transmission fluid?
Recently I did a trans fluid change along with a new filter.
I've been changing the trans fluid every summer for quite a few years.
Immediately after changing the fluid this time my van started coming out of drive for a couple seconds. The engine will rev up if I give it gas like it is in neutral. A second later the transmission catches and away I go. This only happens one time after starting up and driving in the morning when the van is cold. It can happen again after the van sits all day at work.
What I just realized it I have a 1997 with and automatic transmission and it is supposed to get Mercon V. I checked the ATF fluid bottles I got and I was sold Mercon not Mercon V.
What is the difference between Mercon and Mercon V. I'm planning on draining my transmission and replacing it with Mercon V tomorrow.
Thanks-Scott
speleopower is offline   Reply With Quote
( Join the Elite Explorers )
Old 01-07-2012, 08:18 PM   #2
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 415 Post(s)
You could add a friction modifier instead of draining the fluid. Lubegard makes one for this purpose. You could keep the fluid in there with the additive, but in the future always remember to use Mercon V ATF.
BrooklynBay is online now   Reply With Quote
Old 01-08-2012, 08:56 AM   #3
speleopower
cocoa bch
1997 Aerostar
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Ok thanks. In super simple terms Mercon is more slippy than Mercon V.
I changed out the trans oil/filter yesterday to Mercon V.
Hopefully it wont' slip out of gear anymore.
-Scott
Old 01-08-2012, 09:20 AM   #4
corkey
Moderator Emeritus
Elite Canuck,multiple ifs offender,, and musky maniac,, i wheel and i fish,,
corkey's Avatar
99 xls,96 xl,91,08 Ranger
Vehicle Specs
Quoted: 93 Post(s)
mercon is real trans fluid,
mercon v is synthetic,,
it calls for synthetic as it has the lubricity and friction qualities required by the auto trans ,,
like slipping or gripping clutches,,
corkey is online now   Reply With Quote
Old 04-11-2015, 11:12 PM   #5
trozei123
1992 Explorer XLT 4x4
Vehicle Specs
Quoted: 8 Post(s)
i know this post is kinda old, but maybe my question can be answered. i have a 92 xlt that has had tranny fluid leaking out slowly for the past few months. i have been going to walmart and buying supertech dexron/mercon fluid. it doesn't say its rated for mercon v. if i did a fluid change and put in mercon v, would that maybe stop the leak?
trozei123 is offline   Reply With Quote
Old 04-11-2015, 11:15 PM   #6
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 415 Post(s)
Mercon V isn't supposed to stop a leak. You have to find out where the leak is coming from, then replace the damaged seal or gasket.
Old 04-12-2015, 12:11 AM   #7
trozei123
Vehicle Specs
Quoted: 8 Post(s)
oh. i thought maybe that would help. i took it to a local trans shop and they think its the front pump seal based on the leak being between the engine and transmission. would putting in a bottle of lucas treatment help it? i don't make much money, so i am trying to figure out all possibilities to fix the tranny.
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
5R55W Fluid Fill FordSploderXLT Explorer & Ranger Transmissions, Transfer Cases, & Differentials 123 05-14-2015 08:56 PM
Official Mercon Fluid for A4LD Automatic Transmission Roadrunner777 Stock 1991 - 1994 Explorers 1 11-07-2011 08:28 AM
Pump out all tranny fluid? socci Stock 1995 - 2001 Explorers 8 10-29-2011 11:21 AM
Explorer Auto Transmission Diagnosis - Q & A FAQ Glacier991 Explorer & Ranger Transmissions, Transfer Cases, & Differentials 30 08-10-2009 11:05 PM
Boycott Valvoline (Personal Experience) X6StringerX Exploring every thing under the sun!! 11 07-15-2006 12:29 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
