Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood > Explorer, Ranger, A/C & Heater systems HVAC
Notices
Explorer, Ranger, A/C & Heater systems HVAC Ford Explorer, Ranger, Mountaineer, Bronco II, Air Conditioning and Heating Systems.
help, blower only works on high.
Reply
Thread Tools
Old 01-10-2012, 09:30 AM   #1
GLICIOUS21
somewhere n front of a cop
1996 EXPLORER LIMITED
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
now i already assume this problem is usually caused by a blower motor resistor. problem is i work for advance auto parts and cant find the one i need. my explorer is a 96 explorer limited ohv 6.the resistor that comes up for mine is a smaller one with a different plug and springs on the inside.my original one is a lil bigger and shapes different with a different plug and looks more like a module with a chip on the inside instead of springs.but i pulled it from the location where the blower motor should be.has any came across this problem before and how did you find the right resistor?
GLICIOUS21 is offline   Reply With Quote
( Join the Elite Explorers )
Old 01-10-2012, 05:20 PM   #2
albi1cnobi1
Elite Mountaineer
South Jersey
albi1cnobi1's Avatar
99 Mountaineer V6 4x4
Vehicle Specs
Quoted: 116 Post(s)
If you have a Limited than you have Automatic Climate Control(EATC). That system takes a speed controller not a blower motor resistor. It goes in the same place, it's just electronic. When you look it up check under Auto not manual control.
__________________
Al
99 Mountaineer 4.0 SOHC. 2013 F150 SuperCrew 4x4
TT/F-150 Leaf Spring Mod, 2" BL, 32x11.5/15 BFG A/T's, Rancho 5000's, Gibson Catback, Coilover conversion(in process), Electric Fan Conversion, AVM Manual Lockout Hubs, Dual Battery System. EATC Mod. BW1354 swap. My 4405 To 1354 Swap Thread Support your own economy, Buy American, all of our jobs depend on it.
albi1cnobi1 is online now   Reply With Quote
Old 01-11-2012, 10:59 AM   #3
GLICIOUS21
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Ok thanks for the info.but at work my computer catalog doesnt show that option. It only shows blower motor, blower motor resister or blower moter switch which i checked out all and cannout find this speed control part.
Old 01-11-2012, 01:09 PM   #4
snoranger
Jackson, NJ
snoranger's Avatar
94 limited on 35's
Vehicle Specs
Quoted: 68 Post(s)
Try Ford p/n xl2h-19e624-ab. I just got the whole set-up from Al (the previous poster) and I happen to have the motor controller on my desk, in front of me.
__________________
94 limited: 4.0l, 5spd swap, 6" skyjacker lift, 35x14.5 thornturds, 4.56s. 5.0 swap started (94 cobra 5.0, zf 5spd, np205)
95 xlt: stockish (SOHC swap, 30,000miles and I blew up the 3rd 4r55e...now collecting parts for a Cummins swap.)
Cummins 4BT swap thread
Ranger bed trailer build
snoranger is offline   Reply With Quote
Old 06-19-2012, 08:18 PM   #5
Colorado Great
Colorado Springs, CO
2004 Limited
Vehicle Specs
Quoted: 0 Post(s)
Exclamation IF you have Automatic Climate control get RIGHT part.
1st problem is finding the thing - normally in back of glove compartment left of blower motor - I found that taking off glove compartment fully gives you much more room and doesn't add lot of time. I then undid the 1 or 2 8MM screws and allowing it to be pulled out gave you much better access to pull off connector. PLEASE NOTE that if you have a "Automatic" system the parts houses will not give you the correct part!!!! I called Ford and got a part number then crossed to a BWD part. On a 2004 Explorer you need a BWD RU1267 about $60 Ford wanted $140. As a side note (fan does not work) - their is a 30A "square" fuse in engine compartment which should be checked -0n a 2004 Explorer I think #36.
Colorado Great is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Is your blower motor going bad, and how to replace Kamel Explorer, Ranger, A/C & Heater systems HVAC 4 03-31-2016 01:10 PM
2000 Ranger with no 4 low. High works great. jordanb Explorer & Ranger Transmissions, Transfer Cases, & Differentials 4 02-20-2010 08:21 PM
Blower Motor only runs on high pugsy Stock 1991 - 1994 Explorers 1 10-10-2005 02:49 PM
2000 blower motor high only Joebob22 Stock 1995 - 2001 Explorers 3 08-24-2005 08:01 PM
A/C works on High only Alto Under the Hood 15 09-19-2004 03:19 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
