#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
door lock wiring diagram
Reply
Thread Tools
Old 01-14-2012, 08:28 PM   #1
lynnie
South Australia, Australia
Ford explorer 1998
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
hi i was wondering if anyone has the door lock wiring diagram for my Ford explorer 1998, i dont have remote door locking so i bought one of those bulldog units and im going to try and put it in myself.
lynnie is offline   Reply With Quote
( Join the Elite Explorers )
Old 01-14-2012, 08:48 PM   #2
asafley
Pikes Peak Region, Colorado
'97 XLT - 4.0L SOHC
Vehicle Specs
Quoted: 1 Post(s)
I am assuming that you have at least power locks. Horizontal button on the front driver and passenger side doors to unlock and lock. If so, I believe you can go through the RAP module to control the door locks from your Bulldog module.
Here is a website for the RAP module. It has pinouts and the locations of all the wires you should need.
http://mysite.verizon.net/respkm62/v...orer/id33.html
__________________
1997 Ford Explorer XLT - Rebuilt 4.0L SOHC - RP Caster Supercharger Kit - 2.8" Supercharger Pulley - Methanol Injection - 2.5" Custom Magnaflow Exhaust Side swept on both sides - JBA Performance Headers - Brown Wire Mod - 3" Body Lift - Coming Soon: Coilover Conversion
2013 Nissan Sentra SV - Daily Driver
asafley is offline   Reply With Quote
Old 01-14-2012, 09:07 PM   #3
budwich
Ottawa, Ont
96 XL
Vehicle Specs
Quoted: 0 Post(s)
You will be successful going directly from the bulldog module to the lock/unlock relays in the rear quarter panel. There is also room there for the module / power close by. even though the instructions with the module say DON'T use "punch / fork type" connectors to connect to the existing wire (thru the insulation).... they worked fine for me.... :-)
budwich is offline   Reply With Quote
Old 01-15-2012, 04:49 PM   #4
lynnie
Ford explorer 1998
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Smile
Thanks guys ill give it a go :-)
Old 01-15-2012, 05:06 PM   #5
lynnie
Ford explorer 1998
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
ok its not a bulldog one its a universal one and it didnt come with instructions :-( so i need to know where the central control lock wires are
Old 01-15-2012, 09:41 PM   #6
asafley
'97 XLT - 4.0L SOHC
Vehicle Specs
Quoted: 1 Post(s)
The RAP module is the part that controls the door locks and even has the factory alarm disarm wire too. In my earlier post I have provided the pinout of the RAP module.
The RAP module behind the left rear quarter panel. There is a door with two twist locks. This is the same compartment that has the factory bottle jack. Here is a link that describes where the module is at.
http://www.explorerforum.com/forums/...ght=rap+module
__________________
Old 01-16-2012, 01:28 AM   #7
lynnie
Ford explorer 1998
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
hi its says 1995 ford explorer mine is a 1998 is it still the same?
Old 01-16-2012, 01:33 AM   #8
lynnie
Ford explorer 1998
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
sorry i think ive got yous confused, i dont have the keypad entry its a key entry the thing i bought that im trying to install is a remote keyless entry system that apparently you can hook up to the door wires in the car.
Old 01-16-2012, 08:12 AM   #9
asafley
'97 XLT - 4.0L SOHC
Vehicle Specs
Quoted: 1 Post(s)
The RAP module controls the alarm, remote entry, keyless pad entry, and etc. on the truck. So the RAP module does more than just the keyless pad entry. Do you know if you have the RAP module in the back quarter panel? The 1995 Explorer wiring diagram is very similar minus your 1998 may have the PATS system. But the wiring will be the same. Pink/Yellow is lock and Pink/Light Green is unlock. The reason I refer to the RAP module is it is a lot easier to tap into and avoid mistakes... Otherwise you have to remove the driver side kick panel and fish through the bundle of wires to tap into.
The 12Volt Link for a wiring schematic.
http://www.the12volt.com/request/98explorer.asp
__________________
Old 01-16-2012, 09:03 AM   #10
budwich
Ottawa, Ont
96 XL
Vehicle Specs
Quoted: 0 Post(s)
Quote:
basically the "sam ting".... there is a wire for the "lock ground action" and wire for the "unlock ground action". the ground is put on as a result of the wireless signal from the remote being received by the "control module". You just need to connect those wires to one in the back quarter panel that run to each of the activation coils in the appropriate relay (ie. lock / unlock).
Old 01-17-2012, 02:37 AM   #11
lynnie
Ford explorer 1998
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
ok great ive got the RAP module and ive found the wires, do i need to connect positive power and negative earth to get it working if so where are they located?
Old 01-17-2012, 09:00 AM   #12
budwich
Ottawa, Ont
96 XL
Vehicle Specs
Quoted: 0 Post(s)
perhaps "we" don't understand.... but if you have the FORD RAP module in the quarter panel... you don't need to do any wiring, you just need the keyless remotes (fobs) and program them appropriately... check the "stickie" on this forum.
Old 01-17-2012, 05:15 PM   #13
bobflood
Powder Springs, GA
1997 Eddie Bauer V8 2WD
Vehicle Specs
Quoted: 89 Post(s)
Here is a great source for wiring diagrams:
Auto - Online Repair Info
http://search.ebscohost.com/
PW: rebsco
Select: Auto Repair Reference Center
Fill in: Find Your Vehicle
Follow prompts down to Wiring Diagrams.
__________________
1997 Ford Explorer, Eddie Bauer, 5.0L V8, 2WD, 285K+ miles, starting to show its age!
bobflood is online now   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Wiring diagram explorer/ Mustang TPS Swap RubySlow Modified 1995-2001 Explorers 4 03-18-2009 02:14 AM
Does anyone have a wiring diagram for a 93 Explorer 4.0 JLangkiet Stock 1991 - 1994 Explorers 1 10-15-2007 04:34 PM
Need wiring diagram for '99 Stereo 99SportUte Explorer Audio & Navigation 4 07-19-2007 01:29 AM
Wiring Diagram for 01 Sport Abraxsis Explorer Audio & Navigation 0 09-25-2005 09:05 AM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
