Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Slow shifts out of first, flashing OD light
Reply
Thread Tools
Old 01-24-2012, 06:54 PM   #1
ophidia
Fargo, ND
1999 Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
1999 Mtneer 4.0 SOHC 4x4. 158000 miles. A few weeks ago, it started doing a thing where it would occasionally free rev in drive unless you put it in 2nd or neutral and back in drive. At that point, I checked the transmission fluid, and it was about a quart low. I topped it off and forgot about it.
This past week it started doing that again, so I checked the transmission fluid level again, and it was fine. I dumped in a can of Transx, and figured it might just be the cable out of adjustment since bumping it into neutral and firmly back in drive solved it for that trip. I also tested engine braking, and it does not have engine braking in 1st, but does at speed if you turn off O/D. Reverse works fine.
Now it's taking a long time to shift out of first (seems to be at least 3k RPM's at the minimum) and, after a few of those, it takes off in 2nd and the O/D light flashes. I'm sure this means there's a code, but of course my Bluetooth OBD adapter doesn't read those.
Based on the symptoms, does this seem like something involving dirty internals/solenoids that could be addressed by using a cleaner in the transmission, or does it sound like something more serious? I can't afford to have the thing rebuilt (or even replaced with a junkyard transmission) right now, so if there's anything I can do to extend it's life at this point, it would be great. Up until tonight, when it started the slow shift out of 1st, it shifted fine, no delays or flares.
Thanks for reading.
ophidia is offline   Reply With Quote
( Join the Elite Explorers )
Old 01-24-2012, 07:03 PM   #2
fled
Brooklyn NY
fled's Avatar
'02 XLT
Vehicle Specs
Quoted: 3 Post(s)
Common problem is failure in solenoid b in your transmission. Dealer sells as solenoid pack only. Part, fluid and filter. Run for around $400.00 plus labor. Theres a really good doit yourself thread on here to replace solenoid pack. Check it out.
fled is offline   Reply With Quote
Old 01-24-2012, 07:28 PM   #3
daveleeander
Marietta, OH
02 XLT
Vehicle Specs
Quoted: 0 Post(s)
One other possibility is the OD servo worn out. Don't know about your year. Worth using as search word and checking out. I just did my 02 Explorer and fixed mine. The 5R55W tranny uses the OD band when taking off. If the band doesn't tighten (servo doesn't provide pressure) then there is a slip in first and the high revs. If you don't have a drastic drop in RPM when OD kicks in (or if it's slipping) then you may have a worn servo cavity.
D
daveleeander is offline   Reply With Quote
Old 01-24-2012, 08:03 PM   #4
ophidia
Fargo, ND
1999 Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Can either of those fixes be accomplished lying under the vehicle in my garage w/o removing the transmission? How complicated is the job? My most complex thing that I've done was a lower intake gasket on a 2000 Grand Am-- involved removing pretty much all the accessories, upper intake, valve covers, rocker arms, push rods,etc. down to the heads...
Is the O/D solenoid part of the solenoid pack?
How likely is the transmission to go completely to hell if I don't do this immediately? Winter in ND is a bad time to work on vehicles w/o a heated garage, even being an unseasonably warm 14 degrees today... :P
Old 01-25-2012, 06:47 AM   #5
drdoom
VA
2005 Eddie Bauer 4.6L 4X4
Vehicle Specs
Quoted: 343 Post(s)
Take it in and get the codes read, then post back up.
drdoom is offline   Reply With Quote
Old 01-25-2012, 08:55 AM   #6
joecrna
Las Flores, CA
98 XLT 4X4 sohc
Vehicle Specs
Quoted: 28 Post(s)
Valve body and selonoids are easy enough to replace in garage. Not too expensive compared to a rebuild. Run them long with problems and hard parts start to wear. Then the only fix is a rebuild. Once all is considered, price/time/space/experience/weather, I would buy a rebuilt valve body from Central Valve Bodies and a complete selonoid pack and new style braket from Ford. Drop the pan, change those, the fluid, filter and the foreward/reverse servo gasket and call it a day or three (I work slow). This will fix 99% of all problems in the 5R55E transmission. It will also cost $750-$1000 plus your labor but far cheaper than a rebuild and you will probably get better parts/solutions than from the local transmission shop.
__________________
Joe
98 XLT 4X4 sohc
TT, Custom Deaver leafs, 31x10.5 BFG's
Custom skid plates, recovery shackles
Defender rack, Warn transformer mount
and winch
joecrna is offline   Reply With Quote
Old 01-26-2012, 12:26 AM   #7
JTH0714
1995 Ford explorer
Vehicle Specs
Quoted: 0 Post(s)
It is the tps! throttle positioning sensor! I promise you! I had that problem. get it at autozone for about 40 bucks. takes three inutes to replace with a screw driver. easiest thing in the world! let me know if that was it. i bet it is. I had that problem a few weeks ago. the OD light flashing means that the tps sensor is broken.
JTH0714 is offline   Reply With Quote
Old 01-26-2012, 07:09 PM   #8
ophidia
Fargo, ND
1999 Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Replaced the TPS tonight since 24.99 and 5 minutes is better than the alternative, and it might work. It still seems to be shifting late into 2nd, though, but seems better. I've disconnected the battery and am letting it sit for a while. I've wasted 25 bucks on a lot worse. I'm not expecting that it'll resolve the problem, but it is something that crossed my mind to try.
We shall see.
Old 01-26-2012, 07:36 PM   #9
ophidia
Fargo, ND
1999 Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Nope, didn't fix it. Time to search out the how-to for replacing the solenoid pack.
Old 01-26-2012, 07:53 PM   #10
ophidia
Fargo, ND
1999 Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I don't seem to be having any luck finding that how-to thread. Anyone have it bookmarked by chance?
Old 01-26-2012, 11:55 PM   #11
fled
Brooklyn NY
fled's Avatar
'02 XLT
Vehicle Specs
Quoted: 3 Post(s)
http://www.explorerforum.com/forums/...d.php?t=164055
Old 01-27-2012, 09:02 AM   #12
ophidia
Fargo, ND
1999 Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
That actually looks pretty easy. Thanks!
Old 01-27-2012, 10:57 AM   #13
ophidia
Fargo, ND
1999 Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I can't seem to find a part number for the solenoid pack-- looked on fordparts.com and the Tousley ford websites. Can anyone help with that?
Old 01-27-2012, 11:23 AM   #14
fled
Brooklyn NY
fled's Avatar
'02 XLT
Vehicle Specs
Quoted: 3 Post(s)
Quote:
Ihad the part number but cant find it. I think you should get it from dealer. Motorcraft tranny fluid is recomended as well.
Old 01-27-2012, 05:55 PM   #15
ophidia
Fargo, ND
1999 Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I'm going to drop the pan, change the filter, and get some fresh fluid in it tonight. Gonna be a week or so before I can get a solenoid pack, so I figure it can only help until then. Hopefully I don't find any ominous metal chunks lying in there...
Old 01-27-2012, 09:09 PM   #16
ophidia
Fargo, ND
1999 Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I did not end up dropping the pan, as the jug of fluid I got was not Mercon V compatible. I did notice that now it does not shift into overdrive anymore. This seems to point to the overdrive servo. Is this something that can be replaced with the transmission in the truck? Is it part of the solenoid pack?
Thanks!
Old 01-30-2012, 11:54 AM   #17
fled
Brooklyn NY
fled's Avatar
'02 XLT
Vehicle Specs
Quoted: 3 Post(s)
Thanks!
Search for threat to service servo. Theres good explanation there.
Old 02-06-2012, 04:00 PM   #18
ophidia
Fargo, ND
1999 Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I brought it in today to get the codes read and have a trans tech test drive it. The codes were 2nd gear ration wrong, and 5th gear ratio wrong. It also is having trouble engaging the forward clutch (both first and reverse don't always have much right away) and often when you coast the clutch doesn't reengage unless you put it in neutral and back in gear.
Rebuild?
Old 02-07-2012, 07:01 AM   #19
italianbigsky
Lecco, Italy
'96 4.0 V6 limited
Vehicle Specs
Quoted: 0 Post(s)
Rebuild?
I rebuilt the transimmion (the previous owner did) 2 years ago, and I drove it for about 20k miles, but I'm experiencing similar problems today.
I don't think you have to rebuild the whole thing, but if it will be easier than wasting time and money trying to fix each part one by one, as soon as you have the money rebuild it.
Thats' just my 2 cents.
italianbigsky is offline   Reply With Quote
Old 02-07-2012, 07:08 PM   #20
cakeboy06
dayton, ohio
2000 limited
Vehicle Specs
Quoted: 0 Post(s)
A used one is a lot easier on the wallet! Gille Auto in Valley City has one with 75,000 miles for $650, already out of the truck, sitting on a warehouse shelf. Including fluid and labor, you should still come in right around $1,000. A "standard rebuild kit" usually doesn't cover a new valve body, solenoid pack, torque converter, or trannsmission case.
Just an idea?
cakeboy06 is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
My 95 Explorer has a flashing O/D light, and the shifts are hard. wormdigger Stock 1995 - 2001 Explorers 2 09-16-2010 09:01 PM
5r55e Flashing O/d Light bustdnukls Explorer & Ranger Transmissions, Transfer Cases, & Differentials 1 01-04-2008 09:07 AM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
