Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Ranger - Mazda B-Series Forum > Ford Ranger - Mazda B-Series Forum
Notices
Ford Ranger - Mazda B-Series Forum Ford Ranger and Mazda B Series forums. The Mazda B2300 B3000 and B4000 are clones of the Ford Ranger, with all systems the same. The only differences are trim and a few body parts. This forum discusses Ford Ranger and Mazda B series specific issues. Owners of the older Mazda B2000 B2200 and B2600 are welcome as well.
Please Help: How to disable anti-theft?
Reply
Thread Tools
Old 01-25-2012, 07:01 PM   #1
93liftedXLT
left coast
93liftedXLT's Avatar
92 xlt
Vehicle Specs
(Original Poster)
Hey guy's.
I need some major help ASAP.
I have a 2000 ford ranger 2wd 4.0L. I drove down the the post office to get my mail and came back out and my truck would not start. I have narrowed it down to the stupid factory anti-theft alarm that will lock the ignition out and the power will not go to the starter. It's just a LOUD clicking noise. I had the truck towed to my house just now.
I checked the battery and it has 13 amps. It's just this dumb anti theft stuff that puts the truck in limp mode and tells the computer to disable starting the truck....The little red alarm light flickers really fast when I turn over the truck and makes that loud clicking noise.
How do I disable the factory alarm so I can drive to work in the morning?????
PLEASE HELP ME
__________________
loves you parent's, before its to late..
93liftedXLT is offline   Reply With Quote
Old 01-30-2012, 07:32 PM   #2
SamMorgan
New York, NY
1997 Ford Explorer XLT
Vehicle Specs
Disable Anti-Theft
Hey just read your thread. I had a similar problem, 97 Ford Explorer anti-theft activates randomly cutting off power to the starter, fuel pump, whatever...(I'm not a mechanic, just a hack....) Anyway, what worked for me was disconnecting negative battery terminal a few minutes. Hook it back up, play with the locks, with the door open seeing if "theft" light goes on and off accordingly. Try to start it. You may have to do this a couple times so be patient. Anyway, once I was able to start it, I located my anti-theft module, rear driver corner panel. I shut off the engine, then unplugged the smaller of two sets of wires leading to the module. Bingo, anti-theft disabled. All went well a few months until I decided to install new pcv valve. I unhooked the negative battery terminal to work on the car, and when I hooked it back up, car dead. I realized computer must get a read from anti-theft module before it will start again. Sure enough, plugged anti-theft back in, went through the whole process again, started it, shut it off and then unplugged anti-theft module. Car running fine for a couple weeks now. Hope this helps.
SamMorgan is offline   Reply With Quote
Old 07-27-2012, 08:25 PM   #3
showpony2010bc
sioux falls, south dakota
2000 explorer
Vehicle Specs
hey, I just had a major headache with my 2000 explorer.... anti theft blinking, wouldn't start...
after spending $350 on a pats module replacement I got stranded again... not fun..
Finally got it fixed, it turned out to be a simple $20 relay switch that was sticking.
(under hood, drivers side... about 1" square, #FOAB-14B192-AA)
repair sheet states that it was PCM power relay switch. sticking...
works perfect now... good luck.. hope this helps someone..
showpony2010bc is offline   Reply With Quote
Old 07-30-2012, 09:42 AM   #4
Joe Dirt
Living in Greenland
Holland, MI
Joe Dirt's Avatar
'00 V8 XLT
Vehicle Specs
Good info, showpony...
__________________
Quote:
Originally Posted by FIND View Post
Also, every time you use an apostrophe for a plural, Jesus kills a kitten.
My registry
Joe Dirt is offline   Reply With Quote
Old 03-26-2013, 12:01 PM   #5
matbrandt
1999 Ford Explorer
Vehicle Specs
Thanks
Your post saved me a lot of money!! Thanks!
Was having the same problem on my 1999. Anti Theft blinking, ocasionally won't start. Pissed me off! Tryed to buy a new PATS key, not worked. Now with the new relay the problems are gone!
matbrandt is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
2004 Ford Ranger anti theft disable. applepiebb Ford Ranger - Mazda B-Series Forum 5 10-11-2011 02:11 PM
anti theft starting/stalling problems? radioiowa88 Stock 1995 - 2001 Explorers 4 06-20-2011 04:41 PM
Anti theft system. Jad Stock 1995 - 2001 Explorers 1 02-26-2011 09:30 PM
How do you disable the anti theft system on a 94 Explorer? rkw Stock 1991 - 1994 Explorers 6 04-27-2009 12:00 PM
How to disable anti theft in 97 penn28 Stock 1995 - 2001 Explorers 5 12-31-2008 08:10 AM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
