Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2006 - 2010 Explorer Mountaineer 4th Generation > Stock 2006 -2010 Explorers
Notices
Stock 2006 -2010 Explorers Stock 2006 -2010 Ford Explorer Forum. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
08 4.6l exhaust manifold leak, snapped bolts
Reply
Thread Tools
Old 01-31-2012, 11:14 AM   #1
pjw73nh
08 LTD
Vehicle Specs
Quoted: 14 Post(s)
(Original Poster)
Greetings,
See my earlier post here:
http://www.explorerforum.com/forums/...d.php?t=331412
I use my 08 'splorer Ltd with 4.6l primarily for towing a 6000 lb (true weight) trailer. I tow about 2500 miles per summer, and drive it about 2000 miles the rest of the year. a low-use vehicle.
The upper exhaust manifold bolt from the #1 cylinder is missing.
https://picasaweb.google.com/lh/phot...eat=directlink
My guess is that it was there when I bought the vehicle In April of last year with 63k miles on it and it snapped off sometime since. Now I have 67k on it. And of course I hear the tick tick tick at cold start up. It goes away after 45-90 seconds depending on ambient temp.
Looked at the job. Though fairly mechanically inclined, I don't want to do it. Very close quarters, I have no lift to speak of, snapping more bolts off, drilling, welding, chance of water jacket perforation. All of this adds up to me not wanting to do the job. That said, I don't want to pay a buttload (dealer) to have it done either.
The only way I would consider repairing this is if I KNEW for certain what the underlying cause was and that it was fixed before going through the trouble of removing and reinstalling the manifold. No one seems to know what the root cause is. Defective manifold? Bolts? Head? poor assembly skills? etc.
My main question is: What is the risk if I do nothing? Will it get worse? How much worse? Will it cause any FURTHER damage? What are the consequences of doing nothing?
Thanks.
pjw73nh is offline   Reply With Quote
( Join the Elite Explorers )
Old 01-31-2012, 11:48 AM   #2
EX-SV
northern California
owned a 07 EBV8 4x4
Vehicle Specs
Quoted: 0 Post(s)
What is typical cost of having this fixed at dealer?
__________________
S.
previously owned a 07 X EB -->13 CX-5
07 IS350
08 C300
EX-SV is offline   Reply With Quote
Old 01-31-2012, 11:52 AM   #3
pjw73nh
08 LTD
Vehicle Specs
Quoted: 14 Post(s)
(Original Poster)
I guess that's part of my question. I can't seem to get a straight answer. Until we know if it's a bad manifold, bad assembly process, defective bolts it's hard to tell. I had one place tell me that R&R manifold and drill out *one* bolt was about 8+ hours labor.
Old 01-31-2012, 03:43 PM   #4
Explorer_PL
Rockland County, NY
2006EB,V8, Fisher plow
Vehicle Specs
Quoted: 123 Post(s)
I have had it for about 10-15 k miles. Drives me nuts sometimes but goes away like you said after 30-45 seconds.
Mine is 06 V8, 129k miles.
Explorer_PL is offline   Reply With Quote
Old 02-01-2012, 08:59 AM   #5
feetwet
Maple Grove, MN
2006 XLT V8
Vehicle Specs
Quoted: 0 Post(s)
keep me in the loop if anyone gets an estimate... mine is leaking at startup too.
The potential risks I see this exposes are :
1> hot exhast gas in the engine compartment blowing on things not intended for the heat
2> potential for Carbon Monoxide to be ingested into cabin vents
feetwet is offline   Reply With Quote
Old 02-01-2012, 09:07 AM   #6
bojans
McHenry, Il
2006 Explorer Limited
Vehicle Specs
Quoted: 0 Post(s)
I decided to let the ticking occur when the shop gave me the times to pull the head on that motor. Book time is only 1 hour more to pull the whole engine...
bojans is offline   Reply With Quote
Old 02-01-2012, 11:21 AM   #7
EX-SV
northern California
owned a 07 EBV8 4x4
Vehicle Specs
Quoted: 0 Post(s)
^ Is pulling head part of process to fix?
__________________
S.
07 IS350
08 C300
Old 02-02-2012, 02:19 PM   #8
Explorer_PL
Rockland County, NY
Vehicle Specs
Quoted: 123 Post(s)
I am waiting (really hoping it will be a long while) that when I need to do the exhaust manifolds, I'll do also the timing chain with guides and probably pull the engine then, or pull the heads off. I am not sure you can drill and tap the holes in the head thru the wheel well, but I may be wrong.
Old 02-03-2012, 02:48 AM   #9
va2explorer
Hillsville,VA
va2explorer's Avatar
03EX4.0,06EX4.6
Vehicle Specs
Quoted: 2 Post(s)
My 06 4.6 has the same exhaust leak problem w/2bolts broken on the right side and 1bolt broke on the left. It was already like that when I bought it with 52k miles on it, and I am now @ 103k. The leak has never gotten any worse and it still goes away after 45 seconds or so. There has been no mechanical related problems because of the leak, and a CO test indicated CO levels were normal in the passenger compartment.
__________________
03 explorer, 4.0, 4X4, Cold air induction, Left and Right catalytic hollowed out, last catalytic removed 3"exhaust inlet/outlet series 40, SCT X3 programmer(BamaTune) 06 explorer,4.6l ,3" EXH. JLT CAI & SCT livewire programmer(BamaTune), Ford racing traction loc., Accel SuperCoils,Ford racing HiPo Intake,BBK twin 62mm TB, and more to come..
va2explorer is offline   Reply With Quote
Old 02-03-2012, 08:51 AM   #10
bojans
McHenry, Il
Vehicle Specs
Quoted: 0 Post(s)
Quote:
If they can't drill out a broken bolt due to engine compartment interference, yes.
When I trade it in I will just make sure it is good and warm....
Old 02-03-2012, 09:24 AM   #11
pjw73nh
08 LTD
Vehicle Specs
Quoted: 14 Post(s)
(Original Poster)
Quote:
Va2, This is good to know. As long as I am sure it won't get worse (I have already tested in-cab CO levels... (0 ppm)), I am going to let a "sleeping dog lie".
And like Bojans said, when I trade, give it back them nice and warm. Not that they care. the repair cost to them is negligible.
Old 02-03-2012, 11:28 AM   #12
grandmasterlarry
Washington MI
2008 Explorer Sport Trac
Vehicle Specs
Quoted: 0 Post(s)
does the manifold use bolts or studs off the head? giving i have heard this happening a lot it might be a good idea to look into getting some ARP bolts and replacing them before they brake.
grandmasterlarry is offline   Reply With Quote
Old 02-16-2012, 04:59 PM   #13
saefjordan
Royal Oak
'07 Sport Trac Limited
Vehicle Specs
Quoted: 0 Post(s)
Hey all, I just got my 2007 Explorer back from Royal Oak Ford for having #1 cylinder bolt cracked off and leaking. They ended up breaking two more bolts off in the head and werent able to get one out when trying to replace the manifold. But, I guess they acutally got 10 threads deep into it and JB Welded it for a fix. 4 days in the shop. Anyways, I got whammyed with $642 in labor charges. It wouldve been 1100 if I hadnt bought the new manifold from fordparts.com for the 2009 explorer which is the same as the 07 and 08. You can get the manifold for only $130 on there. Im sure it will go up once they realize it though. This was not fun....
saefjordan is offline   Reply With Quote
Old 02-16-2012, 06:03 PM   #14
EX-SV
northern California
owned a 07 EBV8 4x4
Vehicle Specs
Quoted: 0 Post(s)
^ saefjordan - Thanks for useful report. Sounds like a $1000 in round numbers would be typical repair cost, wonderful.
__________________
S.
07 IS350
08 C300
Old 02-16-2012, 08:35 PM   #15
resq302
Boonton, NJ (Morris County, NJ - 45 mins West of New York City)
2008 explorer eddie bauer
Vehicle Specs
Quoted: 2 Post(s)
Our 05 Explorer limited had the same issue with a couple studs breaking off on the pass side. We just ended up trading it in on a 08 Eddie Bauer V-6 that had 15,000 miles. The 05 had 117,000 when we got rid of it.
__________________
Brian
Boonton, NJ
resq302 is offline   Reply With Quote
Old 02-22-2012, 02:14 PM   #16
scubat
west palm beach, fl
scubat's Avatar
2006 Eddie Bauer V8
Vehicle Specs
Quoted: 0 Post(s)
Getting ready to bring in my 06 Eddie Bauer V8 with 75k on it that I have owned since new to have the Ticking noise looked at again as I am 99% sure it is a leaking manifold. I brought it to the local dealer 6 months ago and they said the Ticking noise is normal and that nothing could be done to fix it! I am sure they just didn't want to deal with it as it is not an easy job.
I am still under Fords Premier Extended Warranty and want it taken care of before the warranty runs out. I am taking it to a different Ford dealer this time and hopefully they will take care of it. Any advice as to how to argue my case with the dealer to get this fixed? I got Ford Corporate involved last time and they scolded me for calling them and also told me it is a normal Ticking noise.
If the truck is in park and simply idling, yes the tick goes away after a minute or so but as soon as you put it in drive and pull away with the windows down you can still hear the Ticking for another couple minutes echoing off buildings and houses. The Ticking does eventually go away but probably because the metal or gasket expands and closes the leak. This is not normal though! Will keep you all posted as to how this other dealer handles it.
scubat is offline   Reply With Quote
Old 02-22-2012, 02:18 PM   #17
EX-SV
northern California
owned a 07 EBV8 4x4
Vehicle Specs
Quoted: 0 Post(s)
I'm pretty sure if I took my out of warranty Explorer went into Ford service department with a ticking noise, they would quote a nice big number to fix it.
scubat - Looking forward to seeing how other dealer handles it.
__________________
S.
07 IS350
08 C300
Old 02-22-2012, 05:32 PM   #18
vipersinu2
The Big City of Orange City, Florida
vipersinu2's Avatar
97-03 4.0 exp 07 mount v8
Vehicle Specs
Quoted: 11 Post(s)
my manifold is getting worse, has anybody had suscess with out breaking off studs? any tips? I really want to change manifold and gasket. any advice would be great.
vipersinu2 is offline   Reply With Quote
Old 02-22-2012, 07:55 PM   #19
resq302
Vehicle Specs
Quoted: 2 Post(s)
hate to say it but if you are getting a leaking manifold already, chances are you already have at least one broken stud.
__________________
Brian
Boonton, NJ
Old 02-23-2012, 02:54 PM   #20
scubat
west palm beach, fl
scubat's Avatar
2006 Eddie Bauer V8
Vehicle Specs
Quoted: 0 Post(s)
No doubt about that! Will keep you posted on my outcome.
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Jakee's 4.0 SOHC Build up discussion and motivation thread Jakee Need for Speed! 1549 04-09-2013 07:22 PM
Ford Explorer Exhaust Manifold 1ATony Explorerforum Vendors 0 11-12-2009 01:48 PM
Exhaust leak, but NO exhaust leak? YourNameHere Stock 1991 - 1994 Explorers 18 04-15-2009 09:34 PM
PLEASE HELP!! Stuck exhaust manifold bolts USAFEXPLORER Under the Hood 8 07-20-2000 01:20 AM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
