Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Front Stabilizer Bar End Link Replacement
Reply
Thread Tools
Old 02-05-2012, 02:43 PM   #1
FordFool2
Cedar Rapids, IA
04 Eddie Bauer & 13 Ltd
Vehicle Specs
(Original Poster)
Wife complained of a clunking noise from the front end of our '04 EB 4x4. Test drove thinking maybe ball joint or strut problem but would only hear an occassional light clunk but not associated with bumps or turns. Crawled under and found the upper nut and bushing gone/broken from the passenger side front stabilizer bar end link.
Ordered 2 new ones from Tousley and they arrived quickly. Set out to replace them but struggled to be able to remove the old one. The link is basically a long 5/16" bolt with a bushing at the top and bottom and a bushing/sleeve in the middle. Turns out that the middle sleeve area bonded to the bolt. I tried to get a drift in to drive the bolt out but no luck. Ended up taking a Sawzall and cutting it a couple inches above the bottom mount. Then I used a pickle fork to wedge to break the subby section of sleeve free from the bolt. I had to do the same on the drivers side.
Thought the links would take me 20 minutes to replace but ended up taking a little over and hour. Hope this technique helps someone else down the road.
FordFool2 is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
2001 Ford Explorer Sport Ball joint replacement 4X4 Torsion Bar Front Susp. Rteas48192 Stock 1995 - 2001 Explorers 1 07-25-2010 12:29 AM
Question about front end squeak and sway bar... epv02 Stock 2002 - 2005 Explorers 6 09-24-2009 04:03 PM
Superlift front sway bar link help!! Jamieh560 Explorer - Ranger Shocks, Suspensions, Lift Kits 4 06-01-2006 03:30 PM
96 sway bar link replacement Arnold D. Explorer - Ranger Shocks, Suspensions, Lift Kits 0 07-20-2000 03:54 AM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
