Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Heater makes popping sound
Reply
Thread Tools
Old 02-05-2012, 07:02 PM   #1
taburch
Richmond, TX
2005 XLT Sport 4x4
Vehicle Specs
Quoted: 2 Post(s)
(Original Poster)
hello,
I dont know if this has already been discussed before but when the wife turns on the heat to max when first start up it makes a popping sound when you turn it down some it stops making the sound and then once warmed up it also no longer makes the popping sound. Have any one of yall ran into this problem if so did you fix it and how?
taburch is offline   Reply With Quote
( Join the Elite Explorers )
Old 02-06-2012, 02:00 PM   #2
Exproblems
Orchard Park, N.Y.
'05 Explorer XLT 4.0L
Vehicle Specs
Quoted: 85 Post(s)
Quote:
Originally Posted by taburch View Post
hello,
Yes, this issue has been discussed many times before if it is your "blend door actuator". Does it sound more like a "clicking or clunking " sound when you turn the temp control knob to the hot side? When you switch the temp control knob back to the cold temp side does the noise stop? Do you still get heat inside of the vehicle or does it stay cold even though you set it to the hot temp side? If so on the noise issue or stays cold in vehicle, your "Blend door actuator" maybe starting to break on you. See below:
Previous post>>>>>>>>>>>>"Sounds like you have a bad "blend door actuator". A cheaply made, small plastic gear inside of this actuator breaks off a few teeth and stops rotating the blend door when you switch from cold to hot temp settings. From many of the comments in here, it is best to buy a replacement Ford Blend Door Actuator, not an aftermarket one. Use you vehicle VIN number when ordering part. Expect to pay around $80-$90 for the actuator.>>>>>>>>>>>>>>>>>>
Blend Door Actuator repair link below, give thanks to "BigRondo" for the repair post!
http://www.explorerforum.com/forums/...d.php?t=294140
Exproblems is offline   Reply With Quote
Old 02-06-2012, 02:13 PM   #3
taburch
Richmond, TX
2005 XLT Sport 4x4
Vehicle Specs
Quoted: 2 Post(s)
(Original Poster)
Thanks that helps out alot looks like an easy fix
Old 02-06-2012, 03:41 PM   #4
Exproblems
Orchard Park, N.Y.
Vehicle Specs
Quoted: 85 Post(s)
No Problem, takes around and hour or so to do. Just make sure that is your problem and follow those directions.
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
94 grand am makes grinding noise and can hear a popping noise from left front tire 97xxxploder GM - Buick, Cadillac, Chevy, GMC, Hummer, Pontiac, Saturn 1 11-22-2011 12:17 PM
Heater Makes clicking sound under dash harrisgroup Explorer, Ranger, A/C & Heater systems HVAC 3 05-12-2010 11:28 PM
Dripping/gurgling sound from heater core? 35Remmy Under the Hood 1 02-25-2009 08:04 PM
Audio Geniuses! Help, speaker popping then no sound. Big Green Explorer Audio & Navigation 11 10-07-2003 09:35 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
