| EF Swag Store | 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Missouri
99 Mercury Mountaineer
Control arm caster bolts?
I am putting on new balljoints, inner and outer tie rods, brake pads, shocks, and control arms.
My problem is on the driver side control arm. I have the new control in place, but I am having trouble getting the caster bolt back through the rear most part of the control arm bushing. There is what appears to be a fuel line in the way and I can't seem to move it. It was pure luck the bolt ever came out. My question is, can I put the bolt through the rear side of the bushing and the caster towards the front of the vehicle. It was opposite of this when I took it off, but I can't seem to get it back the way it was without possibly rupturing that fuel line. This is the only thing holding me up. I have tried it both ways and the rear part of the control arm doesn't appear to "adjust" like the front side does. So does it really matter which side the bolt goes through? |
#2 |
Old and in the way
Humboldt, Kansas
2000 Mounty
Those are "camber bolts" not caster--the difference is huge.
You really should install an adjustable camber shim kit while you have it apart, as the factory ones do not allow much adjustment. You should put them in the way they came out for ease of alignment tool fitment. |
#3 |
High Point, NC
2000 EB 5.0
I've done a few of them, the rear bolt is as tight as old nick's hatband but it will go. Putting in an aftermarket adjustable bolt does make a lot of sense, it's easier and will allow adjustment.
#4 |
Torsion Bar Free
since 2010
94 XLT-95 FX4
Those are the brake lines in the way. You can move them if they are giving you too much trouble. There are a few plastic xmas tree holders that can be removed, and the lines pushed back a bit for room to work.
I would replace those stock bolts with an aftermarket set that allow more camber degree adjustment. Moog makes a set sold at auto parts stores and can be found all over the net. |
#5 |
Missouri
Thanks. I finally got them out. I did have to remove those plastic trees so I could move the line. If that bolt was a little shorter it could be put back in with no problem.
I'm also looking at that camber kit mentioned before. As I recall, there was a problem on a 97 Explorer I had before. I went to get an alignment and the mechanic said he couldn't align the passenger side wheel due to a limit in the camber adjuster, so instead of leaving one wheel slightly off he adjusted both the same so they would wear evenly with each other. |
#6 |
Bristol, Va
2000 Explorer, 95 Ranger
I am replacing some of the suspension on my 2000 Sport this week. I bought the camber kits on ebay. The big washers move on the bolt, where as the stock washers do not move. They went on alot easier than trying to install the stock camber setup.
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Lower control arm removal | casey_wa | Elite Explorer 911! | 5 | 03-14-2013 11:25 PM |
| There are 2 lower control arm mounting bolts in each front control arms?? | JarvisB | Modified 2002 - 2005 Explorers | 16 | 03-14-2010 09:43 PM |
| Alignment needed when Upper Control Arm replaced? | quick2scramble | Stock 1995 - 2001 Explorers | 9 | 08-01-2009 05:20 PM |
| Lower control arm replacement? | ernaldmerican | Stock 1995 - 2001 Explorers | 3 | 05-30-2007 07:31 AM |
| Upper Control Arm Bolts | bob944 | Explorer - Ranger Shocks, Suspensions, Lift Kits | 2 | 02-24-2002 06:16 PM |
| Thread Tools | |
