| Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Red Bank NJ
96 Explorer XL
Misfire/Lack of Power/CEL
If anyone could read these problems over and try to help me figure out what is wrong with my truck, it would be a great help
'96 Explorer, 4.0 OHV. ~235k miles DTCs P1405 DPFE Sensor Upstream Hose Off/Plugged *Solved* P0420 Bank 1 CAT Efficiency Below Limit P0301 Cyl 1 Misfire P0305 Cyl 5 Misfire Symptoms Lack of Power
Misfire
Notes
Hypothesis
Any input would be greatly appreciated Last edited by CubicInch; 02-13-2012 at 10:21 AM. |
#2 |
Supercharged OHV
Winnipeg, Manitoba
00 Explorer XLT 4.0 OHV
do you know where your coolant is going? This could be another symptom of the big picture.
__________________ Rebuilt 4.0 OHV with about 6000 kilometers. M90 Supercharged. Tuned by James Henson. 422 cam, dual rate springs, si valves, polished combustion chambers, Rebuilt lifters and 30 thou shaved heads. Headers, and custom exhaust. Water/meth injection. Aftermarket projector headlights w HID's. Electric fan. DELTA RV CAM FOR SALE. low miles on it. |
#3 |
Red Bank NJ
96 Explorer XL
Ya - its going all over my driveway lol. I don't know exactly where its coming from, however my radiator does seem to be covered in coolant. I've also been told that one of the many sounds coming from the engine could be the water pump, however I have not been able to figure anything out in that regard
#4 |
Supercharged OHV
Winnipeg, Manitoba
Sounds like you have multiple issues. Is this your daily driver?
You might want to do a compression test, on the offending cylinders, for sure. You might have blown lower intake gasket. The coolant might be leaking inside the motor, and outside the motor. When you have a look at the spark plugs on the cylinders that are not firing, can you see a slight crack in the porcelain? When you put a fresh plug in, do the cylinders work ok for a while? Could be injector issues, but two cylinders? Fuel pump?? Maybe check fuel pressure, but it also seems odd that only two cylinders are affected. Original heads on the motor? __________________ Rebuilt 4.0 OHV with about 6000 kilometers. M90 Supercharged. Tuned by James Henson. 422 cam, dual rate springs, si valves, polished combustion chambers, Rebuilt lifters and 30 thou shaved heads. Headers, and custom exhaust. Water/meth injection. Aftermarket projector headlights w HID's. Electric fan. DELTA RV CAM FOR SALE. low miles on it. |
#5 |
Red Bank NJ
96 Explorer XL
Yes original heads as far as I know. Today, i fixed error 1405 and the engine sounds alot better and is running much smoother, however is still misfiring. Also found today that plug wires are shot, gonna replace them and see what happens
#6 |
Supercharged OHV
Winnipeg, Manitoba
lets hope thats it!
#7 |
Red Bank NJ
96 Explorer XL
So today i ran it with $20 Premium, and it feels now like the misfire is the only problem...When I go back to regular it will run like shit again. Any thoughts?
#8 |
Supercharged OHV
Winnipeg, Manitoba
nope. pretty odd. do you have a compression tester? it sure would be nice to know for sure that you have good compression. i kinda doubt it will be an issue, but it would help rule out valves as an issue.
#9 |
Red Bank NJ
96 Explorer XL
No i dont but my old votech does. Also want to check the fuel pressure at the rail, but i need a right angle connector to get to it
| Thread Tools | |
